Start to Finish
  • Please log in to reply
24 replies to this topic
#1 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 02 July 2008 - 02:58 PM
I found the original thread pinned here, I didn't remember that I gotten quite as far as I had. I'm going to put this here as well, Don you can pin or not as you like.
Ok folks, here we go. BTW, feel free to kibitz or jump in with your own processes at any step. There is nothing here that is hard and fast, itís just the way I do it, most of the time.
Attached File  BBBlank.jpg   38.61K   53 downloads
This is the piece of steel I started with, itís a piece of 1 Ĺ x ľ , 1084 from Aldo about 7 inches long. It was cut off from another project and was lying under the forge when I decided to start this project.
Attached File  BBTip1.jpg   38.82K   27 downloads
Iíve started forging down the tip, this is heat 1. You can just as well clip the tip off to get started, but the end product is just a bit different. A forged tip is longer (at least for me).
Attached File  BBTip2.jpg   43.12K   28 downloads
Second heat. The thing to remember is that part of every heat needs to be spent forging the upset out of the work. As you forge the edge down, it get thicker (all of that mass has to go somewhere), and if you donít want a really thick tip, you have to forge back to the ľ inch dimension.
Attached File  BBTip3.jpg   42.14K   24 downloads
Heat 3 plus one more to clean everything up. This is the basic preform for most everything I do. If I was going to do a dagger or a spear point Iíd adjust the final position of the tip, or if I were doing a Seaxe, Iíd leave well enough alone.
Attached File  BBTaper.jpg   47.02K   27 downloads
Iíve taken a heat or two to forge in some distal taper, you can see the ripples from the hammer blows along the edge. At this point I decided that I wanted more length and less width in the piece, so I took a couple of heats and forged the width down just a bit, forged in more taper and cleaned up the surface. Most of this was done on the hammer, so it went pretty fast.
Attached File  BBStretch.jpg   44.78K   26 downloads
I decided to start the tang, just because it makes holding the piece a bit simpler. I start with a top and bottom fuller to set the notch, and then one heat on the hammer.
Attached File  BBStub.jpg   41.91K   26 downloads
Having gotten everything pretty much where I wanted it, I started in forging the bevel. I start at the tip and with a combination of forging the bevel and forging down on the edge I moved the tip into line with the spine. I could have just flipped the whole thing over and forged the edge from there, but again, it make a difference in the final look. I find it hard to get rid of the square corner, and it tends to make the tip longer and swoopier, not what I wanted for this knife.
Attached File  BBEdge.jpg   44.81K   28 downloads
Here Iíve used a new tool to set the plunge cut. Iím still figuring it out, but it does seem to make this part go a little faster. Iíve also extended the edge bevel back along the blade. There are 3 or 4 heats involved between this picture and the one before it.
Attached File  BBPlunge.jpg   44.57K   28 downloads
Here Iíve set the ricasso, I also have a tool for this step. You can use the edge of the anvil or a square hardy tool, but I find you get some deformation of the spine, which you then have to forge back out. You can also see that the tool has taken some of the curve out of the spine. Since I wanted a flat spine, thatís good, if you liked the curve, youíd do this step a bit earlier, so that as you forged the bevel you could keep the curve you are creating.
Attached File  BBRicasso.jpg   46.92K   27 downloads
At this step I took a mild heat and started tuning up the blade. Making things straight, taking out lumps and bumps, that sort of thing.
Attached File  BBTuneup.jpg   45.33K   23 downloads
I took a nice bright heat on the tang and drew it out with the hammer, and then did one final tune up.
Attached File  FinForg.jpg   44.17K   24 downloads
Next I fired up the horizontal forge and took 3 normalizing heats and buried the blank in vermiculite overnight. Total forging time was about 40 minutes. After the blank had cooled overnight I took it to my grinding shop and scrubbed most of the scale off with an angle grinder. Then I profiled the blade and ground the blank with a new 36 grit belt.
Attached File  BB36grit.jpg   70.54K   26 downloads
At this point the blank is clean except for the tang, distal tapered, and the plunge cuts and ricasso are roughed in and the edge is ground to about a nickels thickness. I cleaned up the plunge cuts with a file and filing guide. Iíve got another couple of hours in at this point. I will grind to 120 grit next and then itís ready to heat treat. I probably wonít start on the false edge until after the heat treat.
"The worst day smithing is better than the best day working for someone else."
I said that.
If a thing is worth doing, it is worth doing badly.
- - -G. K. Chesterton
So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy.
Grant Sarver
#2 cdent
cdent
  • Supporting Member
  • 220 posts
  • Gender:Male
  • Interests:hobbyist
Posted 02 July 2008 - 05:24 PM
Thanks for taking the time Geoff.
Take care, Craig
#3 Bob Ouellette
Bob Ouellette
  • Members
  • 2,530 posts
  • Gender:Male
  • Interests:I like hitting hot metal, and things that go boom.
Posted 02 July 2008 - 06:26 PM
Nifty thing. I'd like to get a look at that tool you've got to set the plunge cuts. Thanks for sharing.
Bob O
"When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints."
My Website
#4 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 07 July 2008 - 05:43 PM
Ok, just a couple of more pictures. First, the blade at 120 grit, ready to heat treat, with the notch cut in. I haven't cut the shoulders yet, I'll do that after I get closer to finished surface. Because that part of the blade doesn't get hardened, I can still do it after heat treating. If you full harden, you'll want to cut those sooner.
Attached File  BB120.jpg   42.09K   19 downloads
Next, a picture of the tool I made to forge in the start of the plunge cuts. With this tool, having used it once< I think you need to go around to the other side and hit it again to even things up. The tool is a guillotine fuller, with the blades cut at 15 degrees (7.5 degrees each side). I made it out of heavy truck leaf spring, heated, flattened, but not re-hardened.
Attached File  Fuller.jpg   51.66K   17 downloads
Geoff
I said that.
Grant Sarver
#5 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 16 July 2008 - 01:11 PM
Here is the blade, post HT. This was normalized 3 times after the last picture, twice for drill and to get my eye calibrated to the color and the last time to HT. The proper color in daylight is gray, barely red, in the dark after sunset it's bright orange. Edge quenched in mineral oil at 100 degrees. The black mark on the blade is where the tang of one of the other blades (which were quenched in veggie oil) came to rest on it.
Attached File  BBHT.jpg   60.68K   17 downloads
More soon.
Geoff
I said that.
Grant Sarver
#6 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 19 July 2008 - 12:30 AM
Ok, boys and girls, more updates. This is taking forever, I'm really sorry.
Here is the blade at about a 150 finish (actually a 100 grit Gator belt, what ever the equivalent is). I usually stop here and do file work and guards, since the blade gets beat-up on the bench.
Attached File  BB220.jpg   40.67K   17 downloads
I've ground down to within a few 10 thousand of sharp, then I chopped some 2 x 4, just to check the edge. I've only ever had one fail this test, and it was a piece of mild that some troll snuck into my steel pile. The final finish grind should take it right down to a razor.
Here is the rough guard. I cut a slab of NS from a brick of the stuff I bought, about .300 thick. The outside surface has this strange look to it, so I know that I'm going to have to take it down quite a bit, so I cut it thick. I roughed it out on the mill, and I've just begun to file to shape.
Attached File  Grd1.jpg   48.64K   13 downloads
Someone asked if it was possible to forge (or at least hammer) NS. Here you can see that I've hammered the neck and end of one arm and thinned it down a lot. I did it cold with frequent annealings (heat and then quench). I've never tried to hot forge this stuff, but I'm betting it's red short, so you'd have to be carefull.
Attached File  Grd2.jpg   50.54K   17 downloads
Attached File  Grd3.jpg   51.68K   14 downloads
Here I've done a bunch of steps. I've hammered both ends out, surfaced the flats, domed the ends, and cut the hole for the tang.
Attached File  Grd4.jpg   43.57K   13 downloads
This shot shows the back side of the guard. You can see that I've relieved the back side of the hole. This way, when you are filing to fit, you don't have to take off as much material. When the handle gets fitted, that space will fill up with epoxy, so as long as you don't overdo, the handle will cover the hole.
Attached File  Grd5.jpg   49.4K   16 downloads
This is the guard mostly done. I decided to do shell ends (something I've never tried before) but at this stage the guard is still flat. That makes getting your tool marks out somewhat easier. I ground everything I could reach on my belt grinder, then spent an hour with a dremel tool. Then I buffed everything.
Attached File  Grd6.jpg   52.57K   14 downloads
Here is a closeup of the guard bent to shape. For this stage I padded a vice with some leather, heated each arm with a torch and hammered on a wood block to bend it to shape. If you have tapered the arms, then when it is hot, it will hammer to a nice curve. I did have to flatten the body a bit. I did that cold with a wooden block on the top surface, hammering on the block.
Attached File  Grd8.jpg   55.83K   15 downloads
Here is the knife with the guard just slipped on. I'm of three minds as to the handle right now. I have a nice piece of stag, but the texture seems too much for this piece. I'm also considering a coke bottle frame handle, with either white bone slabs, or perhaps some nice desert ironwood slabs. The ironwood will give it a substantial look, very masculine and businesslike, while the bone will give it a Gents SF look. I've got a paper template cut, and I'll lay out some pieces of both and see what I like. I also ask my creative consultant what she thinks (my wife, Marianne :lol: ). She has a very good eye.
Attached File  BBFitup.jpg   39.71K   15 downloads
I often get stalled right here for a time. Lots of paper gets used up and bits and pieces of wood and bone get scattered around my chair in the livingroom. I think this time I've got a pretty good idea of what I want. This will likely get a filed spacer behind the guard, and a butt cap filed to echo the shell ends. It also looks like I need to kick the tang down just a bit.
Thanks for looking,
Geoff
Edited by Geoff Keyes, 19 July 2008 - 12:34 AM.
I said that.
Grant Sarver
#7 Bob Ouellette
Bob Ouellette
  • Members
  • 2,530 posts
  • Gender:Male
Posted 19 July 2008 - 07:54 AM
That looks good! I really like those shell ends on the guard. I look forward to seeing more.
Bob O
My Website
#8 Bob Ouellette
Bob Ouellette
  • Members
  • 2,530 posts
  • Gender:Male
Bob O
My Website
#9 David D.
David D.
    Forum Board
  • Super Administrators
  • 750 posts
  • Gender:Male
Posted 19 July 2008 - 08:33 AM
That is sweeeet! :)
Lookin awesome thus far!
I do not love the bright sword for its sharpness, nor the arrow for its swiftness,
nor the warrior for his glory. I love only that which they defend"
J.R.R. Tolkien
www.CedarloreForge.com
#10 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 19 July 2008 - 11:15 PM
I spent all day doing fiddly stuff.
Attached File  Handlebits.jpg   42.96K   13 downloads
At the top is a paper template that took four tries and much fussing to get even near what I wanted. Paper is good when you are after symmetry, since you can draw half of what you want, fold it over and cut it out, and get fairly close.
On the right is a maple mock-up, which told me that the handle is a bit fat in the center. That piece might get used as a handle at some point.
The cat hair is just for show. My old cat (he's 17 or so) thinks anything layed on a flat surface is for him.
At the bottom are a pair of ironwood slabs. I will probably do another one like this with ironwood instead of bone, but I got them out to see if I liked the look.
In the middle is the product of about 4 hours work, two bone slabs, surfaced, a slot milled down the center (for epoxy and the tang), and all but two pin hole drilled. Between them is a NS frame. The frame started as a piece .250 thick, which I milled down to about .180. I was sure that there was a piece of .1250 sheet around but I couldn't lay my hands on it.
Next I scribed my shape on the frame and ground it out. I don't have a metal cutting bandsaw, but for small stuff and curves I don't find that they work all that well. Then I got a piece of 1/4 by 1 1/8 NS stock and made two pieces for the butt cap. Working slowly I marked all the pieces right and left (since they are never quite symmetrical). After drilling two holes in the butt of the frame, I superglued each of the cap pieces (one at a time) to the frame and drilled the holes in the caps. I assembled the pieces and drove and peened pins in the holes and then ground the end of the frame to fit.
Using the same technique I glued and drilled each of the slabs. The pins for the handles are 1/16th but the holes in the frame are 3/32nds. That way I get a bit of slop on the position of the frame, but the pin holes in the handle are tight.
So, after working all day I've got most of the handle bits prepped, and that is about it. This is probably the most complex handle I've done. If I had opted for the stag, I'd be ready to do the final polish and glue up. I'm still trying to decide if it needs a spacer between the handle and guard.
Thanks for looking,
Geoff
I said that.
Grant Sarver
#11 DFogg
DFogg
  • 2,813 posts
  • Gender:Male
Posted 20 July 2008 - 08:22 AM
Nice tutorial Geoff. This piece is coming along very well and I really appreciate your taking the time to document it. I have pinned it so we can all find it quickly. Good work.
Don Fogg
#12 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 22 July 2008 - 08:14 PM
Thanks Don, I really appreciate your comments. And thanks as well for providing a place for us to do this.
On to the latest. Here is the handle frame pommel applied and rough filed. Having done it this way makes me wonder is there isn't a better way to do this sort of thing. Once the pommel is fixed, everything has to match up to it. If the slabs don't quite fit and need to be adjusted, you are in trouble. At a couple of points glue built up on the ends of the slabs and getting it off without disturbing the fit was hard. Likewise, once you drill the pin holes for the tang into the slabs, nothing had better change dimension. It takes some thought, and since this is the first of this kind of construction I've attempted, it was harder than I would have liked.
Attached File  Hndlframe.jpg   56.89K   16 downloads
Here are the bone slabs glued to the frame and pinned. I drilled some short holes through the black liner and just into the bone to give the epoxy somewhere to go. The pins were just dipped in epoxy and tapped through. Then I clamped everything up and left it overnight. There was hardly any glue to clean up and most of what there was I took off with the grinder.
Attached File  Glueup.jpg   56.48K   11 downloads
I ground the slabs to the shape of the frame, and then tweaked that for feel. There is a historical bowie (I can't remember which one) where the handle material, which I think was ivory, was left wider in all dimensions than the pommel, and then sort of rolled down to fit. I thought about doing something like that, but the bone was just too irregular to pull it off.
Attached File  Grind.jpg   43.88K   12 downloads
When I had everything pretty much where I wanted it I put all of the pieces together to see what the final shape was going to look like, not too bad, I think.
Attached File  Mockup.jpg   48.31K   13 downloads
So, as I writing this I've done a bunch of final adjustments, caught a couple of rough spots, and glued the whole thing together. I should have the final comments and pictures tomorrow.
Thanks
Geoff
I said that.
Grant Sarver
#13 maolan
maolan
  • Members
  • 67 posts
  • Gender:Male
  • Interests:Knives, swords, metalwork in general.
Posted 23 July 2008 - 09:14 PM
I love that hand guard, beautiful design! Thanks for sharing.
Edited by maolan, 23 July 2008 - 09:15 PM.
#14 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 24 July 2008 - 01:09 PM
So here we are, at the end of the project. I did a rough count of time spent and came up with something like 25 hours. I am not the fastest worker in the pack, and this one went a bit slower than I would have liked due to some new processes. If you care it breaks down about like this.
1 hour for forging, and an overnight normalize cycle.
3 hours on the profile, de-scaling, first grind, plunge cuts, and Spanish Notch.
1 hour for the heat treat, plus three, 4 hour temper cycles.
3 hours to grind to about 150 grit, (36 grit down to very near the edge, 60 and 120 to chase scratches, 100 grit Gator Trizac).
4 hours on the guard, including roughing on the mill, rough filing, hammer work, more filing, guard ends filed, cutting and fitting the tang, bending to shape, and sanding and buffing.
4 hours making the template for the frame, choosing handle materials, shaping the frame, fitting the pommel, fitting the slabs, filing the pommel.
5 hours finishing the handle, finish grinding the blade to 45 Gator, then hand polish 220, 320, 400, 600, 1200, and glue up.
2 hours removing glue, hand sanding the handle, fussing over the last small details.
So with a fudge factor built in, 25-30 hours. Still, I think this one fulfills my "Next one better than the last one" credo.
A couple of last pics.
The finished piece. I still have to do the last bit of work on the edge, to bring it to a real razor. It also needs a scabbard.
Attached File  Done1.jpg   50.49K   14 downloads
And here is a shot down the handle. In the end I opted not to do a spacer between the handle and guard. I did a black spacer between the handle and the frame, which I really like the look of.
Attached File  Done2.jpg   62.31K   15 downloads
So there you have it, done at last. Thanks to everyone who peeked in and left comments. If there are any questions I can answer, please feel free.
Geoff
Edited by Geoff Keyes, 12 August 2008 - 11:28 PM.
I said that.
Grant Sarver
#15 maolan
maolan
  • Members
  • 67 posts
  • Gender:Male
Posted 25 July 2008 - 08:20 AM
Very nice work Geoff thanks for taking the time to document all your work. It looks like time spent very well ! :lol:
#16 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 12 August 2008 - 11:26 PM
So here is the finished product, well photographed by Mitch Lum.
Thanks for looking in,
Geoff
Attached File  gk_sguard8x10.jpg   87.63K   14 downloads
I said that.
Grant Sarver
#17 Byron Reeves
Byron Reeves
  • Members
  • 83 posts
  • Gender:Male
Posted 05 December 2008 - 02:49 PM
So thats what a mortiose tang construction is? Nice work btw.
Edited by Steele Hound, 05 December 2008 - 02:50 PM.
"The most rewarding things in life are often the ones that look like they cannot be done."
Make do with what you have, if at all possible.
#18 Geoff Keyes
Geoff Keyes
  • Supporting Member
  • 2,871 posts
  • Gender:Male
Posted 05 December 2008 - 03:19 PM
Thank you. I would call that a frame handle, but it pretty much the same thing. You split the handle material (though in this case it was two slabs) create a pocket in the material and assemble the handle around the tang.
Geoff
I said that.
Grant Sarver
#19 Byron Reeves
Byron Reeves
  • Members
  • 83 posts
  • Gender:Male
Posted 05 December 2008 - 04:03 PM
Alright,thanks, never really knew what that type of design was called till now.
#20 Jared Stier
Jared Stier
  • Supporting Member
  • 1,114 posts
  • Gender:Male
  • Interests:My profession - archeology
Posted 05 December 2008 - 04:05 PM
Geoff
Thank you so much for sharing your work and your progression. Its always nice to see a start to finish.
Practice random acts of Viking
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
