Folder Process- Tutorial?
  • Please log in to reply
51 replies to this topic
#1 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 10:35 AM
I have been messing with making folders for years. Most were crap. I decided this year to take the leap. I have had many requests for cable damascus in a folder. All efforts to get the cable down that thin were failures. Finally got it going. Forged, then ground to .185. Decided on titanium for the liners, bought all the toys to get this going. This is all my design, forging, heat treat, finish. I had help with waterjet cutting and grinding. Could not get flat to tolerances using my stuff. Sent out to a flat grinder, had Great lakes Waterjet cut the liners and blades.
Would anyone be interested in following this journey as I try to get this together? My be educational, maybe comical. I am far from knowing in this area, but learned much in the last 15 years trying to make one that works. I have only a drill press, so my work will be basic, but available to anyone. You CNC guys, no SNICKERING.
This is the collection. Cable damascus flat ground, bolsters will be of mosaic damascus cable, some Ironwood, and the bits and pieces. First step the pivot fit. The blade is of logging cable at .185, polished to 1000. Not etched.
Attached File  DSC_0225.JPG   291.64K   53 downloads
Attached File  DSC_0229.JPG   403.17K   33 downloads
Jim Allen
Three Sisters Forge
Bend, Oregon
http://www.threesistersforge.com
#2 matt venier
matt venier
  • Supporting Member
  • 577 posts
  • Gender:Male
Posted 05 April 2009 - 11:32 AM
I'm interested!! I'm not sure I'll make any but would like to see the progression.
Matt
There's no kissaki like an O-kissaki!
http://www.venierdes...c./Welcome.html
#3 Wade Hougham
Wade Hougham
  • Supporting Member
  • 1,223 posts
  • Gender:Male
Posted 05 April 2009 - 11:46 AM
Jim,
All of my education has been comical :rolleyes: , let's do it. I have been asked by several people if I make folders and to this day have never even attempted one. You have been a great teacher on other tutorials I am sure this one will be no different. Wade
Wade
Jos et löydä rauhaa itsestämme on turhaa etsiä sitä muualta.
If you can not find peace within yourself, it is useless to look elsewhere.
Visit my website http://www.wadesknives.com
#4 atakach
atakach
  • Members
  • 139 posts
Posted 05 April 2009 - 11:48 AM
Good luck bro, this was my first attempt at a cable folder, real PITA, but thats probably because it's the first i ever actually completed.
Id be interested in seeing your creation come to life.
Attached File  firstfolder__1_.JPG   1.18MB   26 downloads
#5 Art Lawrence
Art Lawrence
  • Supporting Member
  • 366 posts
  • Gender:Male
I'd like to see it. -Art
"My sword and my shield are at your command"
#6 Bart Y.
Bart Y.
  • Members
  • 23 posts
  • Gender:Male
  • Interests:Material Science (steel alloy mostly), Computer science, Hunting, Fishing
Posted 05 April 2009 - 01:02 PM
I would most definitely read.
"He didn't die of old age, either. He was poisoned, stabbed, shot, hung, streched, disembowled, drawn and quartered. And dig this, there was a prophecy. Just before his head died. His last words were, "Death is but a door. Time is but a window. I'll be back."" ---- Ray from Ghostbusters II
#7 Jared Stier
Jared Stier
  • Supporting Member
  • 1,114 posts
  • Gender:Male
  • Interests:My profession - archeology
Posted 05 April 2009 - 01:26 PM
I have wondered about this for a very long time, please post your process! :)
Practice random acts of Viking
#8 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 02:31 PM
Ok, here we go. Turn me off anytime. Let me know what works for ya all.
DESIGN: Many projects lack direction. Get a couple of folder kits, put them together, make careful notes of what goes well, what is a pain. Take the liners and blade, put them on a copier (Flat Plate type) and make some copies. Now make changes to what you want. Change curves, blades, screw holes. Leave it, then go back and refine the DETAILS. Look at screw sizes, head shape, lengths, width of blades.
Materials: I went with Ti & Cable damascus. Handles will vary.
Model: I took heavy paper museum board and made a knife, worked the angles, open-close, check distances. Just laid the copier paper on the museum board and traced out.
Drawings: Blade. All these aspects need to be located and sized
-Outline
-Edge location, false edge
-Ball Detent to lock in closed (1/16)
-Thumb Knob hole
-Lock face
-Pivot hole (3/16)
Drawing: Liners
-Outline
-Back Spacer location/ Spacer
-Lock outline
-Pivot size and plcement
-Lock Bar location
-Detent ball size and location.
Much thanks to Dave at Great Lakes Waterjet for guidance.
Edited by Three Sisters Forge, 07 April 2009 - 10:55 AM.
Jim Allen
Three Sisters Forge
Bend, Oregon
#9 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 04:27 PM
Blade Details
There are three holes:
-Detent ball bearing, less than 1/16 and the hole goes all the way through. This way I cam make a L or R handed blade.
-Pivot hole will be 3/16. Note drill and reamer. This has to be perfect.
-Thumb Stud hole for 2-56 threaded rod. I thread this hole, run the screw in, then the stud. This double locks down the stud.
Attached File  DSC_0230.JPG   330.08K   36 downloads
Liners
-Pivot hole-3/16.
-Stop rod & back spacer holes are 1/8. The spacers have shoulders that fit into this, held down with 2-56 screws. These are drilled and reamed.
-1/16 ball detent hole, ball is pressed in this, hole is just under 1/16.
-Bronze 3/16, ,30, .020 bushing.
Attached File  DSC_0233.JPG   303.84K   26 downloads
Confused yet ??
Jim Allen
Three Sisters Forge
Bend, Oregon
#10 Jared Stier
Jared Stier
  • Supporting Member
  • 1,114 posts
  • Gender:Male
Posted 05 April 2009 - 04:33 PM
Confused yet ??
:( a lil
#11 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 04:37 PM
:( a lil
Jared my friend, let me know if I am leaving too much out. Happy to go back and clarify. This folder stuff is out there, so don't worry. May ruin my life, my wife is packing.
Wife: "It took you three hours to drill 4 holes ??"
Me: " Yep, and they are perfect !! "
Wife: "Dinner's in the oven, good luck."
Jim Allen
Three Sisters Forge
Bend, Oregon
#12 josh powell
josh powell
  • Members
  • 122 posts
  • Gender:Male
Posted 05 April 2009 - 05:12 PM
Don't forget to mask off the detent balls path during the etch, otherwise the folder will feel like it has gravel in it.
How did you cut the lock bar into the liner? I've been looking for a good way to do this for a while.
#13 Jared Stier
Jared Stier
  • Supporting Member
  • 1,114 posts
  • Gender:Male
Posted 05 April 2009 - 05:21 PM
I guess i just dont know what those two smaller holes are for above where the larger hole is. Is this going to be a locking blade?
#14 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 09:13 PM
The largest hole is for the pivot. The hole towards the spine is for the thumb stud and the lower smaller hole is the detent for the ball in the liner. There is a 1/16 ball that is pressed into the liner lock arm. This ball engages the blade "detent when closed to hold the blade in the liners.
I'll get some more pictures as I go. Better understanding? Here to help.
Jim Allen
Three Sisters Forge
Bend, Oregon
#15 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 05 April 2009 - 09:15 PM
Good item to watch. I punch out electrical tape with a pipe to cover this. The liners were cut using waterjet.
Jim Allen
Three Sisters Forge
Bend, Oregon
#16 charred
charred
  • Members
  • 297 posts
  • Gender:Male
  • Interests:I'm particularly interested in anything that involves fire.
Posted 05 April 2009 - 09:39 PM
oh man oh man. thanks alot, I'm looking forward to this.
#17 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 06 April 2009 - 01:49 PM
The parts must be FLAT and the holes must line up. If not, it will not move smoothly, it will bind and possibly result in a failed marriage or the dog recieving a beating.
I place the liners on sandpaper on a glass slab. Gently polish to remove burs and get flat. The liners are stacked one on top of the other. I drill the holes through both liners one at a time and ream out to 1/8". Placing a brass rod through BOTH of the liners. This holds them tight and keeps the holes alighned. Drill the next hole, place the rod in the next hole. Keep tight and then drill the last hole for the spacers. I only have a drill press and must take great care to keep flat and alighned. I use brass rods, soft enough to not mangle the holes, yet will fit tight. Drill the pilot hole, then ream to exact diamater. Perfect hole size and aligned perfectly
Attached File  DSC_0229.JPG   237.94K   32 downloads
Attached File  DSC_0230.JPG   325.89K   29 downloads
Jim Allen
Three Sisters Forge
Bend, Oregon
#18 Three Sisters Forge
Three Sisters Forge
  • Supporting Member
  • 901 posts
Posted 07 April 2009 - 09:23 PM
Fitting the parts. We have flattened the parts, drilled and reamed the holes, now time ot pre-fit the entire folder. All of the parts should be size checked, fit and threads checked.
These are the liners and blade, bronze washers and there is a 2-56 tap through the thumb stud hole. The pivot is in place.
Attached File  DSC_0231.JPG   457.08K   25 downloads
This is the backside showing the screws in place.
Attached File  DSC_0232.JPG   443.06K   24 downloads
The folder is together, now make sure that it is even in the liners. Should be equal space, tight, blade swings freely.
Attached File  DSC_0237.JPG   149.21K   31 downloads
Thub stud and screw fit, not trimmed.
Attached File  DSC_0240.JPG   289.65K   28 downloads
It is VERY important that everything be fit perfect at this stage. If not all hell will break loose when you go fit the lock and stops.
Anyone still out there? Is this boring yet ?
Jim Allen
Three Sisters Forge
Bend, Oregon
#19 Jared Stier
Jared Stier
  • Supporting Member
  • 1,114 posts
  • Gender:Male
Posted 07 April 2009 - 09:25 PM
speaking for myself, i am following great now lol! Keep the pics coming, its always good to have walkthroughs for others to follow. Nice work
#20 Greg Thomas Obach
Greg Thomas Obach
  • Members
  • 3,459 posts
  • Gender:Male
  • Interests:steel forgings, melting steel and iron
Posted 07 April 2009 - 10:11 PM
looks good to me
its encouraging... i've never made a folder... alway wanted to...
nice tutorial
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
