Helve hammer
  • Please log in to reply
19 replies to this topic
#1 Jameasun
Jameasun
  • Members
  • 23 posts
Posted 17 January 2010 - 01:40 PM
Doing some research building a helve hammer. For now I plan on making it foot operated. I think I have have a design I like. I figured there had to be someone around with more experience than me. I was trying to figure up an weight of the hammer head. I know it is as big as I make it. Although there has to be a balance between expended energy and desired effect. What do you think is a reasonable weight I should aim for? I was thinking along the lines of 10-15lbs. The intended use will be for blades and small blacksmithing projects. I dont forsee using stock larger than 1"
A pic if the intended design...
#2 Sam Salvati
Sam Salvati
    Fourm Board
  • Supporting Member
  • 5,132 posts
  • Gender:Male
Posted 17 January 2010 - 02:07 PM
I have never seen that picture before. That's a good design other than the treadle to arm connection, on the hammer arm it should be closer to the pivot.
#3 Forrest
Forrest
  • Members
  • 177 posts
  • Gender:Male
Posted 17 January 2010 - 10:35 PM
Is the point where the treadle - hammer arm connection connects to the hammer arm adjustable?
Josh Forrest
Persistence is to the character of man as carbon is to steel.
#4 K Freier
K Freier
  • Members
  • 192 posts
  • Gender:Male
  • Interests:bladesmithing lockpicking reading good books and being out doors
Posted 17 January 2010 - 11:26 PM
How are these hammers supposed to work? i dont understand :( .
Karl
a tall glass of milk... just a quenching medium for hot cookies.
#5 Alan Longmire
Alan Longmire
    Forum Board
  • Super Administrators
  • 12,274 posts
  • Gender:Male
  • Interests:World Domination
Posted 18 January 2010 - 10:34 AM
They're pretty simple. You stomp on the foot pedal and the hammerhead comes down. They have an advantage over hand hammers for some things that would otherwise require three hands, and there are those who use them to do light drawing-out of billets, but they really excel at hot-stamping or cutting.
#6 Steve Seib
Steve Seib
  • Members
  • 18 posts
  • Gender:Male
Posted 18 January 2010 - 01:19 PM
Jameason,
The Clay Spencer designed, IN-LINE TREADLE HAMMER is a bit more complicated but if this is a tool you intend to keep, I think it's worth the extra effort. The main advantage is the hammer and anvil faces are always parrallel reguardless of stock thickness. The plans are for a 65 lb hammer but I think you could scale it for any weight you desired. ABANA has the plans for $15 plus shipping.
http://www.abana.org.../Products.shtml
#7 K Freier
K Freier
  • Members
  • 192 posts
  • Gender:Male
Posted 18 January 2010 - 07:27 PM
Does the foot pedal to arm connection move? Or do the foot pedal and hammer arm move in a 1:1 ratio?
Karl
#8 Sam Salvati
Sam Salvati
    Fourm Board
  • Supporting Member
  • 5,132 posts
  • Gender:Male
Posted 18 January 2010 - 07:41 PM
Karl, look at it. There is clearly pivot pins and pillow block bearings on the end of the hammer arm and foot treadle.
#9 K Freier
K Freier
  • Members
  • 192 posts
  • Gender:Male
Posted 18 January 2010 - 07:57 PM
so the piece thats on the hammer arm slides? im sorry sam, i have a hard time figuring out pictures from one side.
Thanks for the help.
Karl
#10 Forrest
Forrest
  • Members
  • 177 posts
  • Gender:Male
Posted 18 January 2010 - 08:09 PM
My guess is that it does by the look of those bolts sticking into the sleeve that it seems to be attached to.
If it is adjustable would the hammer come down faster if the arm connected closer to the pivot point?
Josh Forrest
#11 Jameasun
Jameasun
  • Members
  • 23 posts
Posted 19 January 2010 - 02:01 AM
The connection to the arm is adjustable. But the trade off is the speed and force the hammer is able to achieve. Its a lever just like your arm.
Thank you Steve, you did bring up a good point that I had not fully considered. Larger stock would cause the angle of the head to change. In turn it could change the desired effect intended.
#12 Jameasun
Jameasun
  • Members
  • 23 posts
Posted 19 January 2010 - 02:09 AM
As you move the peddle to arm connection closer to the pivot you can gain more speed and force but you can loose fine control. As you move the connection to the hammer head closer; you will loose speed and force. Although you gain more fine control.
#13 john marcus
john marcus
  • Supporting Member
  • 644 posts
  • Gender:Male
Posted 19 January 2010 - 09:25 AM
here is a helve i made for sheet metal.
power driven :)
infinite edge cutlery
#14 Greg H.
Greg H.
  • Members
  • 345 posts
  • Gender:Male
Posted 19 January 2010 - 11:09 AM
snip
Posted Image
I have to admit, unlike some hammers that look fairly complicated, this one does have the look of being easy to make.
Once you can accept the universe as matter expanding into nothing that is something, wearing stripes with plaid comes easy.
#15 Matt Bower
Matt Bower
  • Supporting Member
  • 978 posts
  • Gender:Male
Posted 19 January 2010 - 11:27 AM
Helves are really nice for their simplicity, as long as you don't mind the fact that the hammer head and anvil are only parallel at one particular stock thickness. It's when you try to get truly linear motion that things start to get complicated.
I wonder if you could partially -- just partially -- make up for the parallelism problem with interchangeable flat dies (if that's the right term) of slightly different thicknesse that fit either the hammer or the anvil. By changing dies you could change the distance between the hammer and anvil at parallel, which'd let you adjust somewhat for different thicknesses of material.
#16 Greg H.
Greg H.
  • Members
  • 345 posts
  • Gender:Male
Posted 19 January 2010 - 11:54 AM
I'm not sure how changing the dies would work, but if you could adjust the hight of the anvil, that would most definitely allow you to keep the face of the hammer parallel with the anvil for different work thickness - I suspect that you would only need a couple of inches of adjustment for most needs.
But how to be able to make those adjustments and still keep the design simple is a whole 'nother ball game. :unsure:
#17 Matt Bower
Matt Bower
  • Supporting Member
  • 978 posts
  • Gender:Male
Posted 19 January 2010 - 01:46 PM
That's the idea: the different thicknesses would vary the height of the working surface of the anvil.
#18 Sam Salvati
Sam Salvati
    Fourm Board
  • Supporting Member
  • 5,132 posts
  • Gender:Male
Posted 24 January 2010 - 12:07 AM
For forging blades I don't think it would be much of a problem. You could forge in the edge bevels, forge in tapers, forge in the point, in fact I think it would be more suitable than an inline design.
#19 C Daniel
C Daniel
  • Members
  • 383 posts
  • Gender:Male
  • Interests:bladesmithing, rune reading.
Posted 24 January 2010 - 11:09 AM
i think if you made a guide h-frame from the hammer to the flat, 2 slides, one on the arm and the other on the guide itself, that would make it in-line, right?
then just take it off and fix the head for bevels, maybe?
i don't really know what i'm talking about, just throwing ideas out there.
i only need 3 things to be happy: my girlfriend, my forge, and fruit juice.
Casey W Daniel
#20 Sam Salvati
Sam Salvati
    Fourm Board
  • Supporting Member
  • 5,132 posts
  • Gender:Male
Posted 24 January 2010 - 02:57 PM
Casey, yes but the more friction you introduce IE the guides the more efficiency you lose. That and complicating what is a very simple tool, you may as well build a power hammer then. Helves are the ultimate KISS tools.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
