Why do blacksmiths use a post vice rather than a conventional vise?
  • Please log in to reply
6 replies to this topic
#1 Brandon Buford
Brandon Buford
  • Members
  • 523 posts
  • Gender:Male
Posted 01 August 2012 - 01:36 PM
What is the reason blacksmiths use a post vice rather than a conventional vice? I am sure that there is a reason, I just can't figure it out.
I have several conventional vices that I could mount on any kind of stand. What would I gain from a post vice?
#2 jake cleland
jake cleland
  • Supporting Member
  • 2,343 posts
  • Gender:Male
Posted 01 August 2012 - 01:40 PM
conventional vises really don't stand up to heavy forging operations - they're not designed for the hammering and bending forces that post vises are regularly subjected to, plus the jaws tend to be hardened and can crack from a stray hammer blow.
Jake Cleland - Skye Knives
www.knifemaker.co.uk
Albert Einstein
#3 Brandon Buford
Brandon Buford
  • Members
  • 523 posts
  • Gender:Male
Posted 01 August 2012 - 01:44 PM
Okay, thanks. Does the stand up nature of the post vice lend itself to being stronger in the twisting?
#4 Greg Thomas Obach
Greg Thomas Obach
  • Members
  • 3,484 posts
  • Gender:Male
  • Interests:steel forgings, melting steel and iron
Posted 01 August 2012 - 01:53 PM
yes
leg vise is bolted to the table or post... twistin is no prob
leg vise are almost alway made of wrought iron or mild iron ...
so far conventional vises that i've run up on are mostly cast iron ... good for boat anchors or use for hand filing blades
just look at the size of the acme screw on a 4 inch leg and compare it to a conv vise... tells alot
G
#5 pieter-pauld
pieter-pauld
  • Members
  • 283 posts
  • Gender:Male
  • Interests:bladesmithing, swords, history, blacksmithing,
    death and black metal, playing bass, doing metal vocals and reading fantasy books.
Posted 01 August 2012 - 02:18 PM
also a post vice is in direct contact with te ground, making it behave a bit like an anvil and giving it a bit of rebound.
this is what i learnt anyway.
My Facebook page: https://www.facebook.com/Pieter-Paul-Derks-Bladesmith-525128730911334/
#6 Alan Longmire
Alan Longmire
    Forum Board
  • Super Administrators
  • 12,274 posts
  • Gender:Male
  • Interests:World Domination
Posted 01 August 2012 - 03:02 PM
On top of all the above, a post vise is designed so the screw is free-floating in the frame, and thus takes no shear forces when hammered on. A regular bench vise is held together entirely by the screw, which takes all the load no matter what.
#7 Brandon Buford
Brandon Buford
  • Members
  • 523 posts
  • Gender:Male
Posted 01 August 2012 - 03:32 PM
See, I knew that all you experts would have the answer!
