Oyster Knife
Thoughts on optimum hardness?
  • Please log in to reply
3 replies to this topic
#1 Ben Noffsinger
Ben Noffsinger
  • Members
  • 227 posts
  • Gender:Male
  • Interests:Kitchen knives, early European happenings, Wood carving, fermentation, primitive knowledge.
Posted 22 December 2013 - 11:22 AM
Hey Gents,
I am making a oyster shucking knife for a guy and I'm considering how far to temper the blade back.  I know I don't want it as hard as my kitchen knives, but I don't want it to deform under usage.  I am using what I believe to be 5160 (piece of coil spring).  I am thinking somewhere around 50-54 RHC?  Any advice or thoughts would be much appreciated.
#2 shawn patterson
shawn patterson
  • Members
  • 440 posts
  • Gender:Male
  • Interests:family, friends, hiking, music, pets, Kun Tao Dumpag, JKD, buying tools i cant afford. HAMMERS
Posted 22 December 2013 - 11:39 AM
My guess would be flexible over hardness but, I'm guessing.
#3 Tyler Miller
Tyler Miller
  • Members
  • 455 posts
  • Gender:Male
Posted 22 December 2013 - 01:02 PM
I would think 5160 with a spring temper would give it all the performance you need.  Maybe something slightly more stain resistant due to their brininess?
#4 Stephen Olivo
Stephen Olivo
  • Members
  • 131 posts
  • Gender:Male
  • Interests:too many to name
Posted 22 December 2013 - 02:22 PM
Forge one and use it without anything but normalizing cycles.  This may give you the springiness you need.  Then if it doesn't hold up/isn't like a fillet knife springy then try hardening in oil temper to 425 for at least an hour.  Then put it into use again.  repeat adnausium changing variables till you get what you want.  With unknown steels its hard to give you specifics but I have worked with steels around this kind of found type and I find cooking oil quench from bright red after 3 normalizing cycles and immediate tempering cycle at between 400 to 450 gives me a pretty good tool.  You may need to draw the temper more than that but then all you have to do is repeat the tempering in the oven at a slightly higher temp and then test it again to see if it is as springy while still hard enough for you.  If at all possible it is better to work with known steels when making things for someone else.  Just more consistent results.
"Remember to live life to the fullest and without regret for the joy of life is that it ends." Me http://ipneto.deviantart.com/
