what oil should i use?
Ethan B. A. Jackson
I use Veterinary grade mineral oil. I get it at my local feed store. Dirty 30 works, but it stinks.
I said that.
- - -G. K. Chesterton
Grant Sarver
As an absolute last resort you can use a hot chunk of steel and a color draw, but this take practice and the results are....uncertain.
Any oven will do, including the one in your kitchen, since you rarely have to go past 500 degrees to temper a knife. A toaster oven will work, thought temperature calibration is an issue. A couple of cheap oven thermometers takes care of that.
Using the kitchen oven is one reason I went to mineral oil, much less stink than 30 weight, and so many less complaints from the other members of the household :rolleyes: .
I found a giveaway oven on Craigslist, and I keep that in my shop as a tempering oven.
I said that.
Grant Sarver
Just how long is that string? :D
Are we talking a razor, a sword, an axe? What steel, 1095, 5160, 52100, W1? How is it going to used? Is hard more important than edge wear?
These are just some of the questions that need to be answered, before we go on.
I said that.
Grant Sarver
Well, whatever you are doing. I like 5160, it was the first steel I had extensive exposure to. I'd do at least 3 normalize steps before the HT, a single HT, and triple draw at 400F. Unless you are doing a dagger, I'd do a differential HT, no clay. I don't think you'll get much added performance out of a clay coat (though some of the clay guys may want to weigh in on that).
This is just my .02, but the first several ABS test knives I made for the performance test were 5160. The final knife was 1084, but it's just that I've come to prefer 1084 as an everyday performer.
I said that.
Grant Sarver
