Quenching Liquids
Edited by Robert Kobayashi
the first couple of times i quenched 1095 in water, my blades took a bit of a nose dive. no idea why. this was meant to be a tanto, but once3 the tip dropped i finished it as a fighter. never happened again though.
Jake Cleland - Skye Knives
www.knifemaker.co.uk
Albert Einstein
1
Hello Robert,
I have been "playing" with some Admiral 1050 for a while, with a Paragon heat-treat kiln. What I have found necessary to get a good clay-following habuchi is about 1470-1480F @ 30 sec soak before quench. I do not have much experience with 1095, but plan to do so soon. Thank you for posting your test results.
Regards,
Brian K.
Brian K.
Rogue Amateur and Weekend Hobbyist
