Ethan B. A. Jackson Posted September 15, 2008 Share Posted September 15, 2008 i recently came across this book "the razor edge book of sharpening" the author has some good tips about sharpening but one or two things realy get to me. this guy says that your not suposed to use oil on your hone because it gives a "supuriore(sory about the spelling) edge" most profesional bladesmiths and knifemakers i have read about stress the point of using oil on your hone so help me sort out this mess that hapening inside my confused head viva whatever country this is Link to comment Share on other sites More sharing options...
Matthew McKenzie Posted September 15, 2008 Share Posted September 15, 2008 I wouldn't call what the author said pretentious so much as it's just his opinion. MacGyver is my patron saint. "There's nothing in the universe cold steel won't cut." -Conan of Cimmeria- Link to comment Share on other sites More sharing options...
Kristopher Skelton Posted September 15, 2008 Share Posted September 15, 2008 (edited) He actually says that using oil on the stone floats metal particles that act like an abrasive on the "up" side of the blade and the metal bits under the blade get pressed into the stone and clog it- he says you end up trying to shape the edge using metal flakes instead of the abrasive. His method of "dry" grinding and honing is supposed to allow the stone to wear away, exposing new abrasive while the metal flakes blow away. I've used his method (though I use a slightly modified version currently) and it does produce a razor sharp edge. His book is a "hard sell" for his line of stones and hones for use in the meat processing industry, but it's hard to argue with results. Just for another point of reference, the Japanese use water stones and pour water over them during the polishing process to keep them from loading (that is to say, they don't use oil). I haven't used oil on a stone in almost a decade and I have no problem with shaving sharp edges that pass the beloved ABS 2x4 test. Edited September 15, 2008 by Kristopher Skelton Kristopher Skelton, M.A. "There was never a good knife made from bad steel" A quiet person will perish ~ Basotho Proverb Link to comment Share on other sites More sharing options...
Doug Lester Posted September 16, 2008 Share Posted September 16, 2008 I love it when someone comes out with a method (especially when he makes tools used in the new method) that says the way people have been doing things for decades or centuries is all wrong. Rarely is it the case. It looks like he has a method (especially using tools that he has developed) that will work, but so will oil and water stones. Just my dollar's worth (that's two cents adjusted for inflation). Doug Lester HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
patrickrock Posted September 16, 2008 Share Posted September 16, 2008 You can use water with an oil stone (provided you haven't used oil on it yet). As Kristopher S. said, when using water you swish the stone in a bath to wash off the swarf. Oil has, or course, been used for centuries and clearly works. But if you want to avoid an oily mess use water. I won't comment on Juranitch's advice except to say that I've seen it elsewhere by people with no connection to him. So using a dry stone probably isn't as uncommon as we might think. Sharpening methods have always seemed to me like the ultimate "Your mileage may vary" situation. I think its best to keep an open mind, find a technique that works for you and your tools, and then stick with it. Link to comment Share on other sites More sharing options...
Jeremy Vaught Posted September 16, 2008 Share Posted September 16, 2008 I've always used oil on the premise that it kept the stone from loading up with metal. But I can see that on finer stones, it could retain metal particles that kept the blade from polishing to a smooth edge. I'm willing to try anything to see what works first hand. Link to comment Share on other sites More sharing options...
son_of_bluegrass Posted September 18, 2008 Share Posted September 18, 2008 I imagine a lot has to do with specific techniques and tools. At one time I had an oil stone I hod only used dry; no oil, no water. It clogged to the point of uselessness in a few years. It may be cleanable and I may still have it somewhere. I've never used water on an oilstone but have an old broken grinding stone that I've turned into bench and hand sized pieces and use with water. I do use oil on my oilstones. I can't comment on the text in question as I've never picked it up. ron Having watched government for some time, it has become obvious that our government is no longer for the people. If the current trend continues, it won't be long untill armed rebellion is required. Link to comment Share on other sites More sharing options...
Brian Vanspeybroeck Posted September 20, 2008 Share Posted September 20, 2008 Pretentious, not BS (jeez, the profanity kinda offends me...) and proof that there is often more than one way of doing virtually everything. I am always wary of folks who tout one way as "the only one best and proper way of doing this!" no matter if it is polishing, sharpening, forging, finishing, etc. There are usually viable alternative and not every tool can be driven to excellent results in the hands of every craftsman. "Imagination is more important than knowledge" - Albert Einstein "The innovator is not an opponent of the old. He is a proponent of the new." - Lyle E. Schaller http://home.mchsi.com/~hermits/BrianRVanSp..._Edged_Art.html Link to comment Share on other sites More sharing options...
Beau Erwin Posted September 21, 2008 Share Posted September 21, 2008 *nods* If they're saying it's the best way they should really say it's the best way they've found. Seems there's always other ways of doing things. Beau Erwin www.ErwinKnives.com Custom knives Bcarta Composites Stabilized Woods Link to comment Share on other sites More sharing options...
sandpile Posted October 1, 2008 Share Posted October 1, 2008 (edited) The swarf(sp) needs to be swept away from the cutting edge-----running Water----------Oil(change oil every little bit, to get metal shavings off stone). Water stones are easier to clean and unload. Stones load up the same as files. You can lift a lot of metal and oil in hot water and a good dish or laundry soap. chuck Edited October 1, 2008 by sandpile Link to comment Share on other sites More sharing options...
dennis mcadams Posted October 6, 2008 Share Posted October 6, 2008 I'm in agreement with Brian and others, one man's opinion... also, don't really think this forum is the place for that kind of language. Dennis Link to comment Share on other sites More sharing options...
Kevin Colwell Posted June 15, 2009 Share Posted June 15, 2009 (edited) Hello Everyone, I read this book, and studied it CAREFULLY when I was an adolescent and whiz at physics. I used to make my own hunting broadheads, and used a lot of this guy's stuff as a guide. What he actually said was that a stream, continually flowing, of oil or water is best; followed by dry (on a stone that wears easily and consistently); followed by standing water or oil on stone due to floating particles and clogging. The first post nailed this part of his argument. This guy is really opinionated, and probably deliberately to challenge or shock. However, I was 17 when I first read this (20 years ago), and I had the time to experiment with a lot of what he said. By and large, he was right. He provides ONE WAY THAT WORKS. Of course, there is more than one way to achieve MOST things in bladesmithing, so he probably overstated his contention that his system was the absolute BEST. But, it is simple and makes sense, and provides replicable results... I have used the ideas for 20 years (many of which were spent as farm boy/rancher/hunter). I am sure many of you can regularly do better than me (and probably than he is or was able). This is a pragmatic, simple, easy to learn approach for a person with new to intermediate skill levels. People with Mastery can usually achieve any given goal in a number of ways, that is part of having Mastery in the first place. Just my OPINION, Kevin Edited June 15, 2009 by Kevin (The Professor) please visit my website http://www.professorsforge.com/ “Years ago I recognized my kinship with all living things, and I made up my mind that I was not one bit better than the meanest on the earth. I said then and I say now, that while there is a lower class, I am in it; while there is a criminal element, I am of it; while there is a soul in prison, I am not free.” E. V. Debs Link to comment Share on other sites More sharing options...
blacklionforge Posted June 15, 2009 Share Posted June 15, 2009 Hello Everyone,I read this book, and studied it CAREFULLY when I was an adolescent and whiz at physics. I used to make my own hunting broadheads, and used a lot of this guy's stuff as a guide. What he actually said was that a stream, continually flowing, of oil or water is best; followed by dry (on a stone that wears easily and consistently); followed by standing water or oil on stone due to floating particles and clogging. The first post nailed this part of his argument. This guy is really opinionated, and probably deliberately to challenge or shock. However, I was 17 when I first read this (20 years ago), and I had the time to experiment with a lot of what he said. By and large, he was right. He provides ONE WAY THAT WORKS. Of course, there is more than one way to achieve MOST things in bladesmithing, so he probably overstated his contention that his system was the absolute BEST. But, it is simple and makes sense, and provides replicable results... I have used the ideas for 20 years (many of which were spent as farm boy/rancher/hunter). I am sure many of you can regularly do better than me (and probably than he is or was able). This is a pragmatic, simple, easy to learn approach for a person with new to intermediate skill levels. People with Mastery can usually achieve any given goal in a number of ways, that is part of having Mastery in the first place. Just my OPINION, Kevin that was really well worded...and kindly spoken kev...thank you All these things shall love do unto you that you may know the secrets of your heart,and in that knowledge become a fragment of Life's heart... Link to comment Share on other sites More sharing options...
john marcus Posted June 15, 2009 Share Posted June 15, 2009 i think this book may have been about the first book on sharpening.............it came out a long time ago and was for quite a while the only reference i was aware of. i think it pre dated the japanese waterstone popularity in the usa by quite a bit. taken it that context it was a great book...... taken today day with great waterstones and many books and dvd's it has lost its shine imho. infinite edge cutlery Link to comment Share on other sites More sharing options...
