Dennis K Posted October 19, 2008 Share Posted October 19, 2008 I scored a 50 pound bag of low temperature nitrate salts, so its time I build a salt pot. I've read everything I can find on salt pots but I still have questions. Stainless steel pipe is hard to find, can I use black iron pipe instead? How corrosive are nitrate salts? Would 3/8”wall x 4” ID aluminum pipe work for low temperature nitrate salts? Aluminum melts at 1218f, so if I temper 350 f to 585 f, with an adjustable low flame gas heater, theoretically a 3/8”wall aluminum pipe should work, or am I missing something? Any help on this subject would be appreciated. Dennis K Link to comment Share on other sites More sharing options...
Mike Blue Posted October 19, 2008 Share Posted October 19, 2008 My low temp salt pot is black iron (cold water casing). I used a black iron pan for bluing gun barrels for many years. I haven't noticed any corrosion to enough degree to worry about containment. The low temp salts are hygroscopic, they'll draw water from the air. Even in combination with the water there isn't any notable corrosion. The black iron will be fine. There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves. Will Rogers Link to comment Share on other sites More sharing options...
jhobson Posted October 20, 2008 Share Posted October 20, 2008 The black iron will be fine. How about for high temp salts . . . if I keep a close eye on things Link to comment Share on other sites More sharing options...
Mike Blue Posted October 20, 2008 Share Posted October 20, 2008 How about for high temp salts . . . if I keep a close eye on things That might work for a little while. I have no experience with the high temp salts in anything other than stainless pipe. Some of the new salts are less, um, active than the older recipes. I'd still opt for 316L tubing if you can find it. It'll be more durable all the way around. I hope Howard will jump in here too, because I know he's tried more things. I learned from some of the failures. I think the real reason to avoid black iron is the potential for scaling that will degrade that pipe quicker than stainless. The problem with the high temperature salts is that they are only easy to move around on two specific occasions. The first is when you buy them. They are soft, nicely granular, they flow easily when poured. The second case is when they are at temperature and return to a "pourable" state. Then you can dump the salt and save it for later and use a new tube. In between you will cuss and fume because they act a lot more like hardened concrete, or worse. I'd much rather build the tube to last the longest possible without having to fix things, or worry about when "things are going to go..." There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves. Will Rogers Link to comment Share on other sites More sharing options...
B. Norris Posted October 22, 2008 Share Posted October 22, 2008 I think the real reason to avoid black iron is the potential for scaling that will degrade that pipe quicker than stainless. I'd much rather build the tube to last the longest possible without having to fix things, or worry about when "things are going to go..." The same people that make ITC 100 also make a product intended to protect metal at high temperatures. I think it was developed to go on kiln heater elements originaly. A coating of this on the outside of your high temp. salt tube could make things last much longer. ~Bruce~ “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler Link to comment Share on other sites More sharing options...
Mike Blue Posted October 22, 2008 Share Posted October 22, 2008 The same people that make ITC 100 also make a product intended to protect metal at high temperatures. I think it was developed to go on kiln heater elements originaly. A coating of this on the outside of your high temp. salt tube could make things last much longer. ~Bruce~ Do you have a name or link? There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves. Will Rogers Link to comment Share on other sites More sharing options...
Alan Longmire Posted October 22, 2008 Share Posted October 22, 2008 Do you have a name or link? ITC-213, followed by ITC-296A. Short descriptions here. Who knows, they may work. I don't think I'd want to be the guinea pig with high-temp salts, though. Link to comment Share on other sites More sharing options...
B. Norris Posted October 22, 2008 Share Posted October 22, 2008 I don't think I'd want to be the guinea pig with high-temp salts, though. Yes. There is that! Thanks for jumping in with the link Alan. ~Bruce~ “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler Link to comment Share on other sites More sharing options...
Mike Blue Posted October 22, 2008 Share Posted October 22, 2008 I'm thinking that it would make a good coating for the outside of the salt tube to prevent scaling/corrosion from the gas atmosphere. The salts aren't going to do much to the inside of the tube compared to the more aggressive outside environment. Only one way to find out. LOL. There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves. Will Rogers Link to comment Share on other sites More sharing options...
