Andi B. Posted December 10, 2008 Share Posted December 10, 2008 Hello , I'm currently thinking about, how to quench a tanto sized stock removal blade made from carbon steel (C105, 1.05% carbon) creating a detailed and designed hardening line by using clay. [Probably I won't cover the back with clay to minimize the bending by creating a "martensite opponent" to the edge.] I waver between 1) quench completely in warm water Will the blade crack? How big is the risk? Is it calculated risk or suicide? I have quenched steel with 0,75% C successfully but never tried C105 in water. 2) quench completely in oil Oil will not crack the blade but the hardening line will be not detailed enough and too near to the edge. I tied this with a C105 blade three times and the line was nonsatisfying. 3) quench first in water, than quick change to oil This is what I have finally done with the first C105 blade. The result was a kind of double line - hard to describe and not really what I want. Maybe not long enough quenched in water? How long? Any suggestions? Or can it be, that steel with C > 1% is not suitable for detailed hardening lines because it requires oil as quenchant? Thank you! Andi B. ________________ www.Zatoichi.de www.Jogibeer.de Link to comment Share on other sites More sharing options...
kb0fhp Posted December 11, 2008 Share Posted December 11, 2008 I think that quenching 1.05%C steel in water is asking for cracking. As a general rule, steels with a carbon equivalent greater than 0.52 are prone to cracking unless special precautions are taken. What oil did you quench in? I would recommend a very fast oil - but even then the risk is large that the part will crack. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Doug Lester Posted December 11, 2008 Share Posted December 11, 2008 It depends on what else is in the steel. If it's a plain steel (just iron, manganese, and carbon) or a shallow hardening low alloy steel you could get by with water. I prefer brine, however, because it prevents bubbles of steam holding on to the blade causing uneven hardening, although brine is a harsher quenchant. Doug Lester HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
Jeremy Vaught Posted December 11, 2008 Share Posted December 11, 2008 I know a lot of more experienced guys/gals do it, but I have never been successful in water. Crack 'em every time. I've been doing nothing but vegetable oil for quite some time now and get a real nice quench line. I'm not familiar with your steel. Is there something else in C105 that might prevent the line from showing as well? If I was going to go with water, I'd probably want to bring it up to just below boiling before the quench. The most frustrating thing in knife making for me has been being happy/excited about a design and then cracking the damn thing. Good luck! JV Link to comment Share on other sites More sharing options...
matt venier Posted December 11, 2008 Share Posted December 11, 2008 Hey Andi I've done a a decent amount of W2 and W1 blades in the warm water for three to five seconds then into hot oil (300-400F) for an hour. I have cracked one or two blades out of maybe thirty so it isn't 100% safe but I have gotten some pretty detailed hamon. http://www.bladesmithsforum.com/index.php?sh...pic=9419&hl I also try to keep my austinizing temp low and soak for 10 minutes or so if you have the capability There's no kissaki like an O-kissaki!http://www.venierdesign.com/Venier_Design_Inc./Welcome.html Link to comment Share on other sites More sharing options...
jake cleland Posted December 11, 2008 Share Posted December 11, 2008 (edited) i would go with the two stage quench, hot water then a fairly slow oil. do you have a TTT diagram for your steel? the way i see it you want to get past the pearlite nose, and preferably to ms (the martensite start point) in the water and then straight into oil for the transformation. my guess is that if the hamon is low in oil, then you'll want about 3 seconds in the water. i quench 1095, which has almost as much carbon, nearly exclusively in water, without much of a failure rate. if you do water quench, you should shoot for the lowest possible astenising temp, and a long soak, to get a detailed hamon. you should also find out if your water supply is soft or hard, and if it's hard use rain water. obviously, get everything smooth and even, normalise thouroghly etc. it sounds like you're trying to get the hamon to follow a specific clay line? if so, and you're not bothered about surface phenomena like ashi or yo, you could try leaving your edge very thick, 3.5mm say, and hope this inhibits its desire to crack. alternitively, go with an oil quench, and bump the temperature up quite a bit - 75 to 100f. you want to soak at the lower temp and then go hotter for the shortest possible time, to try and prevent too much grain growth. i've had some success with this on 1095 and a couple of other steels which produce a low hamon in oil, but it never turns out as nice, and i only do it when i cant have sori. (oil will cause the blade to curve down, not up.) in oil, i leave off the clay wash on the edge, it doesn't seem to speed up the quench as it does in water, and ( i havent tried this, because it just occurred to me, but i plan to ) you could try just putting a bead of clay where you want your habuchi and not covering anything above it - the steel seems shallow hardening enough that it wont harden on the spine in oil no matter what you do, and i think the thermal mass of the clay is what stops it hardening as high as you want. these are only suggestions, and i am by no means an expert, but they might help. and remember that producing hamons is never guaranteed; embrace the fear, enjoy the process, never fall in love with a blade before the second temper, and have a couple of beers chilling for after the quench, however it turns out. good luck. Edited December 11, 2008 by jake cleland Jake Cleland - Skye Knives www.knifemaker.co.uk "We can't solve problems by using the same kind of thinking we used when we created them." "Everything should be made as simple as possible, but not simpler." "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein Link to comment Share on other sites More sharing options...
Mike Krall Posted December 11, 2008 Share Posted December 11, 2008 Have any of you who want very fast quench mediums tried ultrasonic vibrators on fast quench oil? Supposedly eliminates vapor stage. Would it be of any help? Mike Link to comment Share on other sites More sharing options...
Andi B. Posted December 11, 2008 Author Share Posted December 11, 2008 (edited) @ Jeremy: C105 is (www.metallograf.de): Material number 1.1545 - C105W1 / C105U Composition in % : C 1,00 - 1,10 Si 0,10 - 0,25 Mn 0,10 - 0,25 P max. 0,020 S max. 0,020 Range of application and heat treatment : Unalloyed Tool steel : stamp , planing tools , stamping dies , shear blade Hardening : 770 - 800 °C (water) Soft annealing : 680 - 710 °C Here some of my results: CK75 in hot water: CK75 in oil (or maybe water/oil - I'm not sure): C105 in oil: and same C105 blade in water, then oil: Edited December 11, 2008 by Andi B. Andi B. ________________ www.Zatoichi.de www.Jogibeer.de Link to comment Share on other sites More sharing options...
GEzell Posted December 11, 2008 Share Posted December 11, 2008 Have any of you who want very fast quench mediums tried ultrasonic vibrators on fast quench oil? Supposedly eliminates vapor stage. Would it be of any help? Mike I was planning something along those lines next time I quench 1095, Tai Goo has been doing it for awhile I believe. I have an old electric toothbrush, taped to the quench tank it should keep the oil agitated, at least. George Ezell, bladesmith" How much useful knowledge is lost by the scattered forms in which it is ushered to the world! How many solitary students spend half their lives in making discoveries which had been perfected a century before their time, for want of a condensed exhibition of what is known."Buffonview some of my work RelicForge on facebook Link to comment Share on other sites More sharing options...
jake cleland Posted December 11, 2008 Share Posted December 11, 2008 (edited) well, it looks to me like it'll quench well enough in oil, with a thinner clay coat (1/16th to 1/8th inch) and a slightly longer soak time. nice blades by the way, i really like the sugata on the 1st and 3rd. Edited December 11, 2008 by jake cleland Jake Cleland - Skye Knives www.knifemaker.co.uk "We can't solve problems by using the same kind of thinking we used when we created them." "Everything should be made as simple as possible, but not simpler." "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein Link to comment Share on other sites More sharing options...
Greg H. Posted December 11, 2008 Share Posted December 11, 2008 Noob question: What about just pouring the oil on the water. Then plunge the blade through the oil into the water, then pulling it up into the oil as needed? Once you can accept the universe as matter expanding into nothing that is something, wearing stripes with plaid comes easy. Link to comment Share on other sites More sharing options...
Mike Krall Posted December 12, 2008 Share Posted December 12, 2008 I was planning something along those lines next time I quench 1095, Tai Goo has been doing it for awhile I believe. I have an old electric toothbrush, taped to the quench tank it should keep the oil agitated, at least. I'd love to hear about that when it happens... Mike Link to comment Share on other sites More sharing options...
B. Norris Posted December 13, 2008 Share Posted December 13, 2008 Composition in % :C 1,00 - 1,10 Si 0,10 - 0,25 Mn 0,10 - 0,25 P max. 0,020 S max. 0,020 Most of what we get here in the States has higher manganese than your C105. 1095 C .90/1.04 Mn .60/.90 1075/1080 C .70/.88 Mn .40/.90 The least Mn I've seen has been around 0.25 - 0.30 but, you have to search to find it that low. ~Bruce~ “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler Link to comment Share on other sites More sharing options...
Eastvillage Posted January 25, 2009 Share Posted January 25, 2009 In Europe we have more low manganese steels. A very easy obtainable steel is 1.2210 (silver steel): C - 1.10-1.25 Si - 0.15-0.30 Mn - 0.20-0.40 P - less than 0.030 S - less than 0.030 Cr - 0.5-0.8 V - 0.07-0.12 Although it has added ingredients compared tot C105 it also produces some nice hamons. I water quench it. Greetings Toni http://www.eastvillageknives.com/ Link to comment Share on other sites More sharing options...
John Smith Posted March 3, 2009 Share Posted March 3, 2009 (edited) Maybe it is me but I quench all my blades in water, except O-1 and 5160 which go into oil. I have never done a double quench in water then into oil. I think where some go wrong when using water is they get the steel to hot. And this will lead to cracking and large grain growth. I really try hard to control my temps keeping the heat treat oven around 1550 F. Maybe I am just lucky, I do warm the water a bit to take the edge off so I am not quenching in 30 F water. Edited March 3, 2009 by John Smith John W Smithwww.smith-forge.orgFire and wind come from the sky, from the gods of the sky. But Crom is your god, Crom and he lives in the earth. Once, giants lived in the Earth, Conan. And in the darkness of chaos, they fooled Crom, and they took from him the enigma of steel. Crom was angered. And the Earth shook. Fire and wind struck down these giants, and they threw their bodies into the waters, but in their rage, the gods forgot the secret of steel and left it on the battlefield. We who found it are just men. Not gods. Not giants. Just men. The secret of steel has always carried with it a mystery. You must learn its riddle, Conan. You must learn its discipline. For no one - no one in this world can you trust. Not men, not women, not beasts.[Points to sword]This you can trust Link to comment Share on other sites More sharing options...
