kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 great info and chart thanks !! where did the chart come from ?? D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) is this a book ??? i didnt see it on amazon ?? I am trying to remember - I think it is in one of my books on quenching of aluminum - or heat treating of steel. It may be in both - I am shameless to use in multiple sources. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 Scott, Have you ever seen similar data on water quenches with ultrasonic aggitation... or any other medium with ultrasonic aggitation? Mike Ultrasonic quenching in water has been used - it was first cited by the Russians a long time ago in some post WWII literature. I had to strain to translate it. It has also been tried for aluminum with good results. Trouble is that you use a lot of energy to get the ultrasonic energy into the part. It is easier just to use an impeller. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 i have read the salt helps prevent a vapor barrier from forming Yes - salt acts as a nucleation site for bubble formation and makes the vapor phase less stable. Try a bit of surfactant in it (aka super quench) to make it faster. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 I'd love to hear Scott's take on this. Brine is faster, all else equal. I have read that it's also less harsh, and I don't think the two claims are necessarily inconsistent. The explanation I've read is that the vapor jacket phase of the quench tends to cause really uneven cooling, creating internal stresses. The salts in the brine disrupt the vapor jacket phase and eliminate those stresses. Or something like that. Scott? Brine is faster - the relative ranking can be done using Grossman H-Values: http://www.quenchtek.com/pdf_files/technic...y%20Factors.pdf It can be made faster with surfactants, etc. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Mike Krall Posted May 4, 2009 Share Posted May 4, 2009 Brine is faster - the relative ranking can be done using Grossman H-Values: http://www.quenchtek.com/pdf_files/technic...y%20Factors.pdf It can be made faster with surfactants, etc. Scott, Where would moving a blade in the quench and using an impeller in the quench fall on the severity factor chart? Mike Link to comment Share on other sites More sharing options...
matt venier Posted May 4, 2009 Share Posted May 4, 2009 I've been looking at this thread for a while and I have a question. By that chart it looks like a shallow hardening steel (W2 or 1095) Quenched in soft warm water might not harden, am I looking at this correctly? Matt There's no kissaki like an O-kissaki!http://www.venierdesign.com/Venier_Design_Inc./Welcome.html Link to comment Share on other sites More sharing options...
kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 I've been looking at this thread for a while and I have a question. By that chart it looks like a shallow hardening steel (W2 or 1095) Quenched in soft warm water might not harden, am I looking at this correctly? Matt Yep - I would probably say that - especially in the absence of agitation. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
kb0fhp Posted May 4, 2009 Share Posted May 4, 2009 (edited) Scott, Where would moving a blade in the quench and using an impeller in the quench fall on the severity factor chart? Mike Standard metallurgist answer - it depends. It depends on how rapidly you move the part or agitate the oil. Beyond the SA answer, I would relaistically expect most oils to fall in the .2 - .35 range. You can estimate the relative hardness from the correlations of H factor to equivalent round from the old Grossman charts (from Practical Guide for Metallurgists, by Timken - a wonderful text): Edited May 4, 2009 by kb0fhp D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
