I beam mini press
TJ Smith
Got it far enough along to test.
This is a picture of a 2x2 3 inches long being crushed.
I have applied all the pressure my 5 hp 30 gal compressor can put out and It held up.
It does have some flex on the base. I can't see any movement in the beam but the base has some. I used 4 inch channel for the base , 2 pieces side by side. not firm enough.
The slide moves up and down without any binding. I did change out the top anvil bolts to grade 8.
I think it will work as a lighter press and be fine for small billets of damascus.
need to fabricate some dies and a control.
I am going to try it with air on constant and open and close the bypass valve to move the anvil up or down.
Take care
TJ
Edited by TJ Smith
TJ Smith
Cool design. Much simpler than the other mini-presses I've seen.
Have you considered welding the anvil to the Ibeam instead of bolting it?
A sheared bolt with that kind of force behind it would probably leave a big hole in whatever (or whoever) it hit.
I'm not an engineer, so I'm speaking from pure paranoia here.
--Dave
http://stephensforge.com
--Dave
Yes I did consider welding the upper anvil to the I beam.
I have 3 different positions that are higher or give more gap so I can use the press for drifting shaft holes for hawk handles, or hand axes, or a wedge design for making feather damascus. or whatever.
Actually my bolting is a lot better than my welding.
Thanks for the comment
TJ
TJ Smith
Looks good, TJ! Be sure to update when you build your dies and get around to squishing some hot steel.
Dave,
Paranoia is good for you when you are building gadgets like this. I am a big fan of overbuilding wherever possible. Metal is good...more metal is better. Inefficient from an engineering standpoint I know, but good for my peace of mind. Besides, I'm not an engineer so it doesn't bother me much.
I wouldn't worry too much about the bolts going flying. They're in shear, not tension (well, except for being tightened). Any failure should result in the broken piece just tumbling to the ground since there is no force normal to the shear plane that would send it flying. Now, depending on the travel speed of that ram, the whole anvil and slide could come flying off the top of the rail. If one bolt breaks, they're all going to break.
Taylor Coleman Knife Works
"Trust, but verify." - Ronald Wilson Reagan
I could have saved ..... a buttload of money on steel if I had gone with an open frame design.
Oh well. Thats cool. What are you doing for die holders? That is the weak point of my h-frame press.
Edited by toxonix
JT' I have the HF jack but have not started on the frame yet. I would like to know how yours works out because I have enough metal laying aroud to build one like it. A nice video of you building some billets with would be great. {hint, hint} thanks for posting, Mike
