Gerbrand Nel Posted May 6, 2009 Share Posted May 6, 2009 I got my hands on an old band saw without a motor, and I also happen to have an old bench grinder that I want to use to drive the band saw. I went to the local engineering shop hoping they would know what wheel sizes to make to get the speed on the band saw right. They had a hard time figuring it out, so I was hoping someone here would know how to go about it. The wheel on the band saw that the blade runs on is 26cm in diameter, and the motor runs at 3000 rpm. Now I would like the blade to run at a speed of about 70fps or 2134cm/s. How do I calculate the sizes of the pulley wheels on the motor and the saw to get the right speed on the blade? Thanks Gerbrand Link to comment Share on other sites More sharing options...
john marcus Posted May 6, 2009 Share Posted May 6, 2009 (edited) I got my hands on an old band saw without a motor, and I also happen to have an old bench grinder that I want to use to drive the band saw. I went to the local engineering shop hoping they would know what wheel sizes to make to get the speed on the band saw right. They had a hard time figuring it out, so I was hoping someone here would know how to go about it. The wheel on the band saw that the blade runs on is 26cm in diameter, and the motor runs at 3000 rpm. Now I would like the blade to run at a speed of about 70fps or 2134cm/s. How do I calculate the sizes of the pulley wheels on the motor and the saw to get the right speed on the blade?Thanks Gerbrand i assume you meant a blade speed of 70 feet per minute ???? in which case a reduction from 3000 rpm must be very large the circumference of the band wheel is about 32 inches 70 fpm is 840 inches per min 840/32 is 26 rpm for the band wheel or a speed reduction of 3000/26 or 114 not easy to do with a single belt reduction Edited May 6, 2009 by john marcus infinite edge cutlery Link to comment Share on other sites More sharing options...
Ken Kelley Posted May 6, 2009 Share Posted May 6, 2009 Here's a handy dandy pulley and belt speed calculator. Plug in you numbers and out pops the speeds. You can switch the variables around to get where you want to go. http://www.csgnetwork.com/pulleybeltcalc.html Link to comment Share on other sites More sharing options...
Matt Bower Posted May 6, 2009 Share Posted May 6, 2009 (edited) Just to clarify, is this a metal- or a wood-cutting band saw? 4200 sfpm (70 feet per second) would be reasonable for wood (maybe a little fast, but not completely out of the ballpark), but it's way too fast for metal -- by a factor of more than ten Edited May 6, 2009 by Matt Bower Link to comment Share on other sites More sharing options...
Gerbrand Nel Posted May 6, 2009 Author Share Posted May 6, 2009 Just to clarify, is this a metal- or a wood-cutting band saw? 4200 sfpm (70 feet per second) would be reasonable for wood (maybe a little fast, but not completely out of the ballpark), but it's way too fast for metal -- by a factor of more than ten Wow. I thought under 100fps is good for stainless with 30fps being the sweet spot. Thats why I'm aiming for 70 You sure about this? Thanx for the replies everyone G Link to comment Share on other sites More sharing options...
Willman Posted May 6, 2009 Share Posted May 6, 2009 Some quick numbers, wood 2,700fpm bronze 80fpm 4130 steel 270fpm 1020 steel 330fpm “If I have seen a little farther than others, it is because I have stood on the shoulders of giants.”-Isaac Newton Link to comment Share on other sites More sharing options...
Gerbrand Nel Posted May 6, 2009 Author Share Posted May 6, 2009 looks like I got fps and fpm mixed up.. back to the drawing bord Link to comment Share on other sites More sharing options...
john marcus Posted May 6, 2009 Share Posted May 6, 2009 looks like I got fps and fpm mixed up.. back to the drawing bord my speed table shows SS between 50 - 150 fpm infinite edge cutlery Link to comment Share on other sites More sharing options...
