ROLLER MILL BUILD STARTING
  • Replies 134
  • Created
  • Last Reply
Top Posters In This Topic
ok .....thanks dennis.. this setup should be able to stabilize the bearings....much what hugh macdonald did in the green roller. :)
John , that's more like it but cut the top plate in three piece. Keep the ends and use the center piece for summing else, that way you will be able to see what's going on when you are rolling .
Hope this helps Dennis K
Edited by Dennis K
yes.......... helps a lot and thanks !!!!!!!
infinite edge cutlery
ok it is now fully functional.
i finished rolling out the slab of w2 and rolled out a damascus billet.....since i left the handle on i could not switch it end for end.......very happy with the whole project.
next will be some assembly photos of the second mill being put together. it will be painted bear brown in honor of its new owner :lol:
Edited by john marcus
Nice. :lol:
Thanks for the update John!
--Dave
http://stephensforge.com
searobin are you getting slippage on fluxed pieces or dry?
Dry with the scale brushed off.
I'm probably trying to reduce the billet dimension too fast, but I also think if both rollers were powered It would work better.
My shop is in South Mississippi,When the anbient temperature is above 100 F and when I light off my forge, the temp reaches about 120 F, so I'd like to speed up the process.
Edited by SeaRobin
ok.....now that i have some clue i have started the assembly of the second roller mill.
photo shows alignment of the basic frame which must be true with the top roller so it will run without binding. then the lower roller is fit and the verticals are snugged up to fit.
the camshaft holder can now be assembled and fit in place. once these pieces are welded together it will be time to install the foot pedal and pressure strut.
last pic is a 1.5 hp motor that can run on 110vac and a 60:1 reduction gear box.
motor and gear are suspended from chain hoist
shafts are marked to be trimmed to keep the motor close to the frame.
mount will be marked for a pass thru window, aligned and welded in place
Looks awesome John. I can't wait to see this thing working in person.
--Dave
Awesome work John! If you were to make another batch of these what would the running price be roughly?
turnkey with motor and drive around $2500.
i have enough machined parts for a third. :)
thanks for being curious !!
Damn that's not bad, if only I didn't get moved to part time at work.
roller mill 1.5 hp 110vac with 60:1 gear reduction, manual motor switch with motor overload protection.
rollers c1045, bearing are bearing grade bronze.
READY TO CRATE AND SHIP TO BEAR COUNTRY :)
That's GORGEOUS!
Well
Done
John!
Awesome! Can't wait to try it out.
--Dave
Looks like a good piece of machinery.
As a guy who just started tinkering with machining I envy your machining skills.
Great work, It looks a bit too Swedish though. ;)
Thanks for sharing.
Marius
Marius A. Bacher
"To learn and not think over what you have learned is perfectly useless. To think without having learned is dangerous." - Gore Vidal
Thanks for sharing.
Marius
its also the colors for university of california at los angeles........( bruins )
i have been making stuff forever and have a great shop at my disposal.......its not rocket science mostly patience and learning from mistakes :)
Nice job, John. If I didn't already have one, I'd want one of yours.
I wanna know where were you when I was building mine with old nail files and used sandpaper tho?!? :rolleyes: Na, I enjoyed the build, doing it myself, but I probably could have used your services for turning the rollers. Mine may need re-doing one day, I may look you up.
Dan
Dan Pfanenstiel
I'm Norwegian so I just had to, :P
I have a Chester Lathe/mill combo machine, so it's not the best but it's what I could afford and It's absolutely good enough for what I'll use it for.
No, it's not rocket science and I have a background in 3D modelling so I have an OK relationship with shapes and angles an stuff. It's more using the machine and seeing the optimal order of processes to get to the destination. And the setup, I think I have a 10:1 ratio of setup to actual machining. :blink:
Marius A. Bacher
