The Material, Manufacturing and Computer Simulation of the Quenching Process of a Japanese Blade
I have always had a problem with a silver (Ag) cylinder to calibrate the heat extraction rate. It is a very interesting bit of work though, to be sure.
I would like to embed fine wire thermocouples into a blade every couple inches or so of length and at different depths in from the spine and do a real time graphing of quenching a real sword. But my personal research budget will not support that at this time (largely due to hardware costs for the i/o board to get the t/c into the computer, and the graphing software). I would gladly donate the time and the blade and clay to do it, but have not been able to get that sorted, yet. Maybe someday.
You can get a cheap I/O board from Omega and use about a 50Hz acquisition rate then graph it in Excel....it works well
D. Scott MacKenzie, PhD
All my computer hardware is, at present, Mac OSX based. I do have a couple of PC laptops, but they are both old ones that need some work.
I was not aware that it could be done that way though, thank you, Scott ! I will look into it further. :)
I think they have some simple boards that would work thru a firewire or USB port....
interesting piece, particularly how dramatic the effect of the clay wash is on the rate of cooling in the first seconds. would there be a similar effect in an oil quench? sorry for my ignorance, but i'm not sure if a stable vapour stage is a factor in the (relatively) slow cooling rate of oil quenching?
Jake Cleland - Skye Knives
www.knifemaker.co.uk
Albert Einstein
Actually it does. You get a stable vapor phase with oil. Using surface roughness you can speed it up (or you can slow it down if the roughness is too much and the bubbles "stick"). I would imagine clay would do a similar thing.
