Niko Hynninen Posted August 16, 2009 Posted August 16, 2009 (edited) Hi All Here we go agane. I managet to get nice amount of materials for wootz and now it was first run whit these materials. I havent run furnace 2,5 month and had little difficult to get started. Plan was to make two similar charges. Material were pig iron + iron flakes+ clear glass. Total mass 2150g x2 ( per ingot) Here is pics Materials Pig iron nro I nro I / top shrinkage+ some porosity nro II in crucible right nro I Glass top nro II Nro II Nro I marco...fast cooling no dendrites in side ( if not looked in right angel...small dendrites) Cementite may be bit curly parts ( spark is good) I but this ingot in furnace over night whit nro II so stucrute of ingot is not raw. Nro II also faster cooling...Same dendtites seen from angel but dirrect grain and cementite needles. Pit of top hat effect in both...used crucibles has previous erosion in side the wall and I think it act as an mold?? Erosion is guite stong!! Why fast coolig... I have one ingot that i forge in to bar..."II fruit" in bloomer and buttons topic, if interested. It has bold pattern..so.. Could it be that if we have ingot that has C% wootz rate...faster cooling rate dosent form dendrites...and we have all ready ingot that has austenite grain + cementite + cementie in side the grain.... Maby we dont nessesary have to make diffusion heating to get rid of dendrites. So is the dendrites even key to patter?? I think no, right alloys, HT cycles and forging may be more effective. Im not sure how many of wootz makers look at raw ingot stucture...structure after diffusion heating...structure after one or several roasting cycles. I have learned lots of how steel acts looking structure at different states. Like raw ingot dendrites...and after diffusion heating. HT Cycles douring forging. BR Niko Edited September 30, 2010 by Niko Hynninen
Greg Thomas Obach Posted August 16, 2009 Posted August 16, 2009 Hi Niko good to see your back in the driver seat ! - funny how life can be so much better when your melting steel both ingots look to be top shape... when you say that they were quickly cooled... does that mean that they were just air cooled ? i'm excited to see how you make out with these... ... maybe figure out how to " Pringle pattern " the barstock... how was the color of the slag ontop... Greg North Shore Forge & Ironworks
Niko Hynninen Posted August 16, 2009 Author Posted August 16, 2009 Hi Greg Thanks. In both slag is green/grey...I think all most same as previous runs. I run first one 15 min and turned gar/air off...then let it cool to yellow and tooked it out ..air...bit windy. Second I run same ...but lef it in side furnace over night....it has bigger dendrites all over out side...but not that easy to see from in. Both have dendrites but its realy hard to see...in one angle yo just see them. But mostly is " Widmanstätten + grain boundrary cement" ...me thinks If I compare these to previous runs...whit dendrites in side....cooling rate liquidus to solid if totally faster. I sure hope that I can find something new...and reasons how and why I continue tomorrow. BR Niko
Jan Ysselstein Posted August 16, 2009 Posted August 16, 2009 (edited) Niko Niko, I believe both the slow and fast cooled ingots will form dendrites on cooling. Under some conditions the carbon migration is fast enough to change the appearance of the structure. The underlying grid ("the master pattern" of the wootz) is in place, regardles of the cooling rate. The experiment is a good idea, my "Best Wootz Ever" was quick cooled but the ingot (fragment) was too small to get the results I wanted. However now that someone has found the Persian process why are you even bothering, why not just watch (I think I got that from Peter Sellers as Chauncey Gardiner). Good luck Niko, I will join you again this winter in the wootz game. Jan Edited August 16, 2009 by Jan Ysselstein
Cyrus Posted August 17, 2009 Posted August 17, 2009 Niko, good that you start your experiments. I like number 2, there is already some swirls in the structure, I like it. Now try to forge them out and make lots of pictures. All the best, Cyrus Cyrus www.cyrusblades.com
Jeff Pringle Posted August 17, 2009 Posted August 17, 2009 Those are some good looking ingots! Jomsvikingar Raða Ja! http://vikingswordsmith.com
Niko Hynninen Posted August 18, 2009 Author Posted August 18, 2009 (edited) Thanks Guys I did some hard forging and method that I used was totally different than ever before. HT cycles before forging I did yesterday and initial forging today...now I have tow bars ~ Nro I 25x40x300 and Nro II 35x35x300 Nro I had two deep porosity holes, and I tryed to work whit those in bitter end...but I think I haveto cut ingot half..after all. ..BUT i have one grazy idea, and I try it tomorow....I post it..anyways IF it dosent work. Here is pic todays forging. Nro I stucture before forging Nro II stucture before forging Nro I left and II right Nro II Nro I porosity crack... Nro I Nro I Nro II Nro II Top I Top II Thoughts? BR Niko Edited September 30, 2010 by Niko Hynninen
Jeff Pringle Posted August 18, 2009 Posted August 18, 2009 I think your new materials make good ingots! Jomsvikingar Raða Ja! http://vikingswordsmith.com
Dmitry.M Posted August 18, 2009 Posted August 18, 2009 Very nice looking steel Niko! Congratulations. www.artandknife.com
Greg Thomas Obach Posted August 19, 2009 Posted August 19, 2009 yessir .... that is very nice Niko... if you can keep the top porosity in the center... of the bar... then it will be in the spine of the blade... and that is what many antique blades have... .. they'll also pound a soft iron wire into the crack to hide the porosity...... I've seen it alot... especially when you restore a blade it becomes obvious.. actually...i'm holding 2 tulwars at the moment and both have this.. by the way.....pattern is looking good Greg North Shore Forge & Ironworks
Cyrus Posted August 19, 2009 Posted August 19, 2009 Hi Niko, very nice steel that you are working on. I whish you best of luck to get some very nice patterns. Please continue. Regards, Cyrus Cyrus www.cyrusblades.com
Niko Hynninen Posted August 19, 2009 Author Posted August 19, 2009 (edited) Hi Guys. Thank you all for the boost, kind words...all. It means a lot...its not enough word even at this point. Im not sure but just maby, I have find something that will be ....least in my mind...Simply mind blowing ...at least its that to me Ok.. Today I forge Nro II just two cycles...so nothign to report on that one. But Nro I....this porosity ingot.. Im not sure is it big thing...or just nothing...but even I had guite nasty porosity in middle...that I indeed forge close... Now its Gone... But even Greg said ..its ok..it some how makes me bite my tongue...sorry Greg, I cant help my self! I wanted long bar...so I did not wanto cut it in half...I made something different...and now, I have full lenght bar in my hand...that has guite promising pattern..im so happy that I managet to work this out..this was a milestone for me..and it opens up lots of different ideas too. I in deed promised to tell what happend...but I need to download and resize lots of pics first...but here is something Agane....fire at will...thoughts in BR Niko Edited September 30, 2010 by Niko Hynninen
Dmitry.M Posted August 19, 2009 Posted August 19, 2009 You may have forge welded the porosity. It is not easy to weld wootz and keep the pattern, but some people managed to do that. To what temperature you heat when forge? I mean what color was the billet? Yellow, orange, red? www.artandknife.com
Niko Hynninen Posted August 19, 2009 Author Posted August 19, 2009 (edited) Hi Dmitry. I did not weld the porosity raw ingot it was 2x20mm deep ( tryed it whit mig wire...might bean longer...??) and I think this is the most ingteresting part of this all...like I said milestone for me. I reduce pics soon and it shows how I made it.....And heads up..I dont recomend this...HI risk of ruin the ingot...or some of it Day was good lesson of heat and force Niko Edited August 19, 2009 by Niko Hynninen
Dmitry.M Posted August 19, 2009 Posted August 19, 2009 May i ask you one more time about the same... What was the color of the billet or ingot when you were forging it? www.artandknife.com
Niko Hynninen Posted August 20, 2009 Author Posted August 20, 2009 (edited) Hi. Dmitry, you may! Colour was orange. ...and here is how I salvage porosity ingot to full lenght. ..and Nro II i think did had just bit higher C ( bit longer in crucible) and Kill was not success...microporosity..in side the cementite ...and my initial forging temp may have beam just over to this...so looks like bar is full off small cracks that show douring grinding. There is patter, sort ....so I try forge it out if it holds in on piece...if not..Another learnig point. Niko Edited September 30, 2010 by Niko Hynninen
Jeff Pringle Posted August 20, 2009 Posted August 20, 2009 Nice save, Niko You are too cool! Jomsvikingar Raða Ja! http://vikingswordsmith.com
Niko Hynninen Posted August 21, 2009 Author Posted August 21, 2009 (edited) Thanks Jeff Is was guite cool to find a way to salvage whole ingot. Forge bar full lenght cycles..and here is results Niko Edited September 30, 2010 by Niko Hynninen
Dmitry.M Posted August 23, 2009 Posted August 23, 2009 Now I need to catch the fast train or I'll be too late... Congrats Niko! www.artandknife.com
Niko Hynninen Posted December 11, 2009 Author Posted December 11, 2009 (edited) Here is some pic of this blank of wootz... I used Stainless steel paste as etch...it is harder to steel...and im not sure is it good to wootz etch after all... It can make small holes... I ad my finger as skale....I find that its guite difficult to say how big or small pattern is....I hoe this "finger" helps to see. Now is this small,medium,large???? I re etch it tomorow and show how it look like Nital....Its totally different. BR Niko Edited September 30, 2010 by Niko Hynninen
Jan Ysselstein Posted June 12, 2010 Posted June 12, 2010 Thanks Guys I did some hard forging and method that I used was totally different than ever before. HT cycles before forging I did yesterday and initial forging today...now I have tow bars ~ Nro I 25x40x300 and Nro II 35x35x300 Nro I had two deep porosity holes, and I tryed to work whit those in bitter end...but I think I haveto cut ingot half..after all. ..BUT i have one grazy idea, and I try it tomorow....I post it..anyways IF it dosent work. Here is pic todays forging. Nro I stucture before forging Nro II stucture before forging Nro I left and II right Nro II Nro I porosity crack... Nro I Nro I Nro II Nro II Top I Top II Thoughts? BR Niko Niko, Were the "before" forging pictures taken before any forging or after a little forging...and do they represent the sides, top or bottom of the ingot. I am trying to create a little library of pictures which will eventually allow me to predict the appearance of a blade based on the look of the ingot. What was your conclusion regarding these two ingots? Jan
Niko Hynninen Posted June 14, 2010 Author Posted June 14, 2010 Niko,Were the "before" forging pictures taken before any forging or after a little forging...and do they represent the sides, top or bottom of the ingot. I am trying to create a little library of pictures which will eventually allow me to predict the appearance of a blade based on the look of the ingot. What was your conclusion regarding these two ingots? Jan Hi Jan. First macro images are just after melt/cooling and next ones are after roast. The nro I is good material but II is totally skrap...if you look at first page you see that steel has some strange " craking, porosity,somethign" What you think it could be?? My thought is that I didint use enought force douring forging and grain just didint refine enough and maby grow too big / impuritys at grainboundary didint brake up and course that?? Also it could be graphitation?? Niko
Jan Ysselstein Posted June 14, 2010 Posted June 14, 2010 NIko, It is hard for me to tell as based on my record I have problems of my own. I have roasted some ingots and got a very quick conversion to a finer granular structure and some are slow to convert ( especially those with internal cracks resembling the layers of an onion. Heat doe not transfer well when there is nothing to conduct it..... . Jan
