Quick How to: Making Mokume
Dave Stephens
Okay, this was just a first attempt, but it seemed to go pretty well. I thought I'd share the experience.
Sorry in advance for the bad photos. I wasn't planning on doing this, so I just had my Iphone.
I had a bunch of scraps of brass and copper that I use as spacer material on hidden tang knives. I picked them up from a hobby store. Apparently they use them for building model airplanes. Anyway, they were very cheap.
They are so thin you can cut them into strips with scissors. I cut them into approximately 1" wide by 3" long strips.
I have a book on making Mokume, and the recommended method was to build a couple of plates with a handle on one and squish the cold billet in between with bolts. I almost built one. But then I thought, what the heck, let's try it the same way I do damascus.
I prepared this pretty much the same way I do a damascus billet, minus the welded handle. I sanded each strip clean, stacked and secured with bailing wire.
I turned the PSI in the forge down to 6 and choked the oxygen down way low so it was a low, reducing atmosphere. I let it soak, turning it occasionally, until I saw a drip of molten brass fall out one side.
Then I took it out and squished it on the press. No photo of that. Sorry.
Here it is after squish and cool.
Ground and polished. Looks pretty good. No inclusions that I could find. (The big groove is where the bailing wire was).
This yielded about a 1/4" thick chunk of mokume.
I'm going to go get some more material and make a thicker billet and put some pattern into the next one. If there is interest I'll post that process too. Let me know if you guys would like to see.
Cheers!
--Dave
http://stephensforge.com
Dave, that is awesome.
that looks lovely. certainly puts my mokume to shame!
jared Z.
lilzee on britishblades.
From now on, ending a sentence with a preposition is something up with which I will not put.
-Sir Winston Churchill
thank you for sharing this. I have a question, do you have to use a flux ? cant wait to give this a try, will have to hit the hobbie store for cheep thin metal.
chris.
i could complain but who would listen.
chris.
chris.
Chris,
No, I did not use any flux. I just reduced the oxygen intake of the forge so it was a pretty dramatic reducing environment (flames licking out of the mouth of the forge like crazy).
Although, I can't say for sure this made a big difference, as this was my first attempt. Maybe it would work in an oxidizing environment too.
Smiths with more experience making mokume might have a comment on this.
Luck!
-Dave
Awesome, Dave! Thanks for posting this. Copper/brass mokume has been on my "some day I gotta try that" list for a couple years now. Yours looks great!
Kurt Huhn
pipecrafter@pipecrafter.com
Dave ..Looks really great and your posts are always very informative..thanks..one question though, I've heard melting copper in a forge makes it harder to weld steel later.Is this an old wives [or blacksmiths] tale or was it something only true in coal forges...I've heard this from several sources..regards ,Arthur
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." — Mark Twain
