Mutt Posted August 27, 2009 Share Posted August 27, 2009 Hello all, I am new to forging and new to this forum. I was at a large gathering one weekend and saw a guy with a small homemade gas forge. After returning home, I went to our local scrap metal dealer and got an 18 inch long piece of 12 inch diameter water pipe from an aircraft carrier. Anyhow, I took the pipe and welded it onto a piece of u channel and left about 9 inches of channel sticking out for a shelf in the front of the forge. I welded a 1 and a half inch pipe to the side with a 90 degree bend and a gas fitting attached to the side of the pipe. I am using a shop vac for air and actually need to put a valve inline because it pushes too much air through the forge and puts it out. Anyway, me and my son fired it up and it worked. I am getting ready to put an inch of KAOwool and a couple of sacrificial bricks in the bottom. I had a local propane shop make me a fitting so I can hook it up to one of my camping hoses that I attach to my cook stove. The whole thing cost me about 40 bucks to build, minus the cost of the gas tank and insulation. Anyone have any suggestions that I haven't thought of??? Mutt Link to comment Share on other sites More sharing options...
Mike Barton Posted August 28, 2009 Share Posted August 28, 2009 Mutt, Use the search function and you can find more than you want to know about building forges. Here's a link to one topic Links to Forge Plans that has more links within the thread. Good Luck, this stuff is addicting! Mike Link to comment Share on other sites More sharing options...
