Plastic backing
guarnera
I've been told when using mammoth tooth or pearl for folder handles its best to glue spacer material to it as a backing. Well the spacer material from knife supply places is .030 thick. that's almost a third the thickness of the handle material. I've been trying to find a plastic in different colors that's .010 or less with no avail. I can find colored plastic shim stock, but its color coded, so each color is a different thickness. Does anyone know where I can get a spacer material that comes in different colors that under .010 thick. I thought plastic would be good, but I'm not having any luck finding anything under 1/32" thick. Any help would be appreciated. Thank you.
Tony G
PopsSuply has black and red in .10 size. If you have it available on the thicker stuff , glue the spacer to the handle material, flip it over and mill the spacer down to the size you want it.
Plastic coffee can lids or similar work well for spacer/liner material. Rough it up a bit w/ 120 grit so the epoxy sticks better.
--Dave
http://stephensforge.com
