Hurl Vreeland
Heat treating using heating elements
I was thinking of using these http://www.mcmaster.com/#3540k35/=53ss87 (scroll down to the bendable elements) and molding a cork screw type shape and insulating with kaowool on the OD of the elements. It can go as high as 1700 but I need only 1400 or so.
Coupled with a controller this would seem to work nicely.
Has anyone used or made someting like this?
I would go with a salt bath but it is too much money and time in relation to my limited use.
Edited by Hurl Vreeland
Go here tell them what size of furnace you want to build and let them recomend
the ellements you need for what you are doing. Saves a lot of guess work.
Bob
http://www.duralite.com/kiln-furnace-studio.htm
I feel it would work I just wanted to know if anyone has made this before. I was going to wrap the element around a 4" mandrel about a foot long. Wrap about 3 to 4" of Kaowool around that and sheath it with a piece of pipe.
I would be well within the temp range of the elements.
I don't see why it wouldnt work for a salt tank assuming the sheathing for the elements was rated for it. I would have the element coming out of the salt a bit though so you wouldnt get any bubbles.
The salt stuff is out of my realm though so its all a guess.
I just wanted something to use at work that is low profile and I could just plug it in and treat my blades.
OK, your idea suddenly clicked into place. I think that would work, though you might want to do it as a vertical, since the elements are live (electrically) and you don't want to get zapped. Another issue is the elements sagging and changing length as they heat and cool. Mostly people build a box of fire brick, with the elements channeled into the brick. It's a special purpose kiln, in effect. Dee did a how-to here a while back, a search should turn it up.
Edited by Geoff Keyes
Dee's Thread is a sticky at the top of this subforum click here for a shortcut Furnace Building
Mike
This is what I was looking for:
http://images.google.com/imgres?imgurl=http://www.mhi-inc.com/IMAGES/coil012.jpg&imgrefurl=http://www.mhi-inc.com/PG5/CoilQuote.htm&usg=__Fibk6eUNQ7nPa_xlfLcL7L8v2Yo=&h=229&w=320&sz=14&hl=en&start=131&um=1&tbnid=gGOoZVqipqTVAM:&tbnh=84&tbnw=118&prev=/images%3Fq%3Dcoiled%2Bheater%2Belements%26ndsp%3D21%26hl%3Den%26safe%3Doff%26sa%3DN%26start%3D126%26um%3D1
Rigid, just like an oven and like an oven if metal does contact the element no shorting. No sagging either and not as fragile as the wire element. I wondered if you could heat an element out of an old oven and remold it around an mandrel.
Thanks for all the replies!!
