WIP Damascus Billet
Gary Mulkey
I spent the morning yesterday making a damascus billet and thought it might be fun to make it into a WIP. It's a little difficult to run a forge and camera at the same time but I got these pics during the process. Hope you like them.
I started with 25 layers of 1080 & 15N20. This is the preheat.
Applied borax.
Bringing it up to welding heat.
First press. I do a light press the first time then back in the forge. The second time I will put a harder squeeze on it.
First cut.
Folded for the first time. :) I got a little off of dead center.
This is the billet after four folds & welds (200 layers). I stopped there. Haven't decided what pattern to put into it yet.
:D:D:D It's sure nice to have 40 degree weather to step into occasionally after being in front of the forge all morning.
Hope you enjoyed it.
Gary
Gary
ABS,CKCA,ABKA,KGA
I got started on the handle fittings. I decided to use an old wagon tire for both the guard & butt cap. This will be the first of this particular tire that I've used. Hopefully it will have some interesting character. I think that I will end up NitreBlueing them.
Hope you like.
Gary
Edited by Gary Mulkey
Gary
ABS,CKCA,ABKA,KGA
While doing the various normalizing & H/T to the blade I got started on the handle. I have been saving a pair of beautiful giraffe bones scales that I got from Sandy McClure that will be going on this one.
Glued scales being drilled for mosaic pins. I didn't trust the glue to hold them together and decided that mosaic pins might add something.
rough ground:
polished (side view)
top view (black spacer between scales visable)
Hope you like it.
Gary
Gary
ABS,CKCA,ABKA,KGA
This afternoon I worked on the handle fittings.
This is the forged bar from the antique wagon tire.
drilled handle spacer
ready to grind to shape
fittings ready to blue
I decided to NitreBlue both fittings
I stopped the process at 490 degrees which is the point where it changes from dark straw to blue.
I managed to get some of both colors. Hope that the photography shows it.
WIP%20finished%20guard%20&%20spacer.JPG]
Hope you like it.
Gary
Gary
ABS,CKCA,ABKA,KGA
I decided to add a little 3-D to the spacer today.
This gave it a little natural iron color to go with the NitreBlued finish.
Back to the KMG for post H/T profiling.
Ready to remove scratches from the blade.
Gary
Gary
ABS,CKCA,ABKA,KGA
Great post Gary,and Thanks...also a good looking knife..It's always fun and informative to see somebody else's techniques...many of us work alone and we get caught up in "our way"..I very rarely get a chance to see other smiths work and I don't think another knifemaker has ever been to my shop.I'm looking foward to watching your final steps.
At this point is your guard attached to the spacer?
Edited by Arthur
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." — Mark Twain
At this time they are separate. Before I attach the handle, I will pin the spacer to the handle. I normally don't attach the guard & spacer. I'll try to get pictures tomorrow which may explain more.
Gary
Gary
ABS,CKCA,ABKA,KGA
Since the guard had been NitreBlued, I didn't want to solder it to the blade and take a chance in scratching the surface while removing extra solder. So I decided to apply a moisture barrier of my own invention made from the following three ingredients:
Adding enough of the atomized stainless to make a thin paste (if you get it too thick you will reduce adherence). I like this better than JB Weld since it can be buffed shiny where JB Weld will remain an unattractive grey. It provides a very durable moisture barrier which is my main purpose.
After applying to both surfaces, it is placed in vice to cure. Extra is removed with q-tips & acetone.
Spacer is attached to handle with 3/32" pins
I will attach handle to blade & guard this afternoon.
Gary
Gary
ABS,CKCA,ABKA,KGA
That's a nice tip on the accraglas with stainless, thanks! B)
On the fittings, does the wrought iron grain show through the nitre blue? I can't tell from the pics. :huh:
Alan,
Since I forged the wrought iron, the pattern doesn't come through. I should have ground it to shape which would have shown the pattern better. (first time that I have tried forging it to shape) Oh, well. Live & learn.
Here's the final assembly:
Since I didn't give this one a butt cap, I have to attach it like a stag crown. (notice notches in tang). Once the AcraGlas sets and grabs those notches, it will be there forever.
And finally a large clamp. Remember, AcraGlas likes to be warm and won't set up in a cold shop.
I had fun with this WIP. Hope you did as well. Thanks for sticking with it and all of the nice words.
I'll post pictures of the finished knife tomorrow.
Gary
Gary
ABS,CKCA,ABKA,KGA
:D:D My way of keeping the AcraGlas warm on a cold winter night.
:D:D Too much effort in this one to have glue that doesn't cure. Luckily I don't have a wife to complain about bringing my work into the house.
Gary
Gary
ABS,CKCA,ABKA,KGA
Alan,
I get the pattern to show after forging by etching the living crap out of it, like say 20 minutes to an hour in 4:1 ferric chloride. Of course, then it'd be a pain to polish it back up for hot bluing... :unsure:
Thanks for the WIP, I like the knife! B)
Thank-You Gary
  • 4 weeks later...
Great WIP thread! Thanks for showing your process. The blade looks great.
Hogan Baker
"Stale water is poor drink. Stale skill is worse. And the man who walks in his own footsteps only ends where he began."
  • 1 month later...
gary, that looks great. I like the intermediate color on bluing, too. the professional photo is tops.
kc
