Forge
Isaiah Lake
Greetings one and all,
First, thank you for the vast wealth of information. I have been reading posts here for awhile, first as a guest now as a user. I'm Jason. I've been mucking about on my forge for a few years on and off. I've even managed to finish a few knives. I figured the forge thread was as good as any for an introduction. So, here is my forge:
It started out as a break drum forge, then I modified it as I used it more and more with refractory cement, fire bricks and eventually ended up in this configuration. The top is a cookie sheet with a hole punched into the center where the break drum is. The U channel and C clamps were going to be temporary while I added the refractory cement. but they work really well so I left them in place. The cement fills in all the space between the cookie sheet and drum and helps tie everything together. I think the fire pot might be a bit shallow, but I have been successful in welding up chainsaw blades, files, and anything else I can get my mitts on. I really like welding up chain. I use a $10 hair drier with a "cool" setting for my blower. So far I've had many issues getting the mix just right, but I recently installed rheostat. I can now fine tune the air flow and use it as a foot switch to turn of the air when I pull the work out of the forge.
For the longest time my forge was outside in direct sunlight. My shed is a recent addition, as in last December. this will be the first time I've used an indoor forge for welding.
  • 1 month later...
Guest stuartthesmith
Stuart's Shop
1. forge 1
2. forge 2
3. 700 lb. hay budden
4. 400 lb. Fisher
5. 150 lb. williams and white triphammer
6. 75 lb. Bradley triphammer
  • 2 months later...
Nice forges guys! here's mine just a 5 gal trash can with 2 inches of kao wool coated with satanite and ITC-100, home made 3/4 inch venturie burner. yes it will weld!!
A bad day forging... is still better than pretty much anything else
  • 3 weeks later...
