jarrett Posted July 8, 2010 Share Posted July 8, 2010 (edited) First, I'm not a rep for this company but wanted to let everyone know about this. They have this in stock and its readily available. Today though I came across Tulco Oils. They make a wide line of oils but what were interested in is their quench oils. I talked with one of their techs and he suggested two of their quench oils for knife making application. Indicated it is used and named several well established companies. One is a 16 second oil, with a viscosity of 104 SUS @ 104 F, flashpoint is 392. The other is a 9.5 second oil, with a viscosity of 90 SUS at 100 F, flashpoint of 365. I will be testing out the first one soon (using O1) because it was the slower acting oil. It also more resembles type A in color. The rep said the other is much much darker. I've not been able to find a spec sheet on Type A anywhere. Did notice the viscosity is identical to the Parks 400 at same temperature. If these test out I'll let everyone know. Or if anyone has prior experience with these, what is your experience/opinion. I've used Goddards Goop in the past and then switched over to used peanut oil. I wanted something more reliable and predictable so I've looked high and low for Texaco Type A and equivalents; no luck. Ellis Knifeworks site is currently out, and through the 6 different distro's I spoke with across the whole western half of Arkansas it can be got but only by special order and in large quantity from one distributor I found. The others were not so helpful. Edited July 8, 2010 by jarrett CUSTOM KNIVES BY JL RHODES JLRKNIVES ------------------------------------------------------------------------- God bless you. I thank God every day for the freedom to spend time with those I love, and time to pursue this craft. "Adversity is a test for strong men." "What one man can do, so can another." "NO excuses, just do better next time." Link to comment Share on other sites More sharing options...
bronzetools Posted July 8, 2010 Share Posted July 8, 2010 If I remember correctly Ed Caffrey uses Veterinary grade mineral that can be bought at most farm and feed stores . He says it is very similar to Texaco Type A. I uses peanut oil with good results. Steve Link to comment Share on other sites More sharing options...
Brian Shafer Posted October 13, 2010 Share Posted October 13, 2010 Well, any update? No Thor, no hammer. Know Thor, know hammer! Link to comment Share on other sites More sharing options...
jarrett Posted October 14, 2010 Author Share Posted October 14, 2010 Well, any update? Apologies for not following up sooner. The results are good. I've quenched about 6 knives so far; made of O1, 5160, and 1080, and 15N20. They have all turned out really well. I've tested them with rope cutting and slicing, hacking two by's, cutting leather, edge flexing, stabbing a board and chipping it out; you know, the usual stuff. The oil has not flamed up yet when doing multiple quenches. I'm liking it. The same company makes a faster quenching oil. I'm going to go back and get some of it soon just to do some comparisons of the two and try to learn a bit more about quenches and how much difference the "speed" of the oil really does make. I don't have a hardness tester, but the qualitative tests so far are good. I've not put a blade through a complete ABS test yet but will soon. CUSTOM KNIVES BY JL RHODES JLRKNIVES ------------------------------------------------------------------------- God bless you. I thank God every day for the freedom to spend time with those I love, and time to pursue this craft. "Adversity is a test for strong men." "What one man can do, so can another." "NO excuses, just do better next time." Link to comment Share on other sites More sharing options...
kb0fhp Posted November 18, 2010 Share Posted November 18, 2010 (edited) Apologies for not following up sooner. The results are good. I've quenched about 6 knives so far; made of O1, 5160, and 1080, and 15N20. They have all turned out really well. I've tested them with rope cutting and slicing, hacking two by's, cutting leather, edge flexing, stabbing a board and chipping it out; you know, the usual stuff. The oil has not flamed up yet when doing multiple quenches. I'm liking it. The same company makes a faster quenching oil. I'm going to go back and get some of it soon just to do some comparisons of the two and try to learn a bit more about quenches and how much difference the "speed" of the oil really does make. I don't have a hardness tester, but the qualitative tests so far are good. I've not put a blade through a complete ABS test yet but will soon. The slow oil is essentially a 100 SUS mineral oil with no additives. The second oil is a medium speed oil that gets its speed using an additive (the reason it is darker). There are a variety of quench oils available that would work well for your application. I am a bit biased in my choice but I work for one of the largest suppliers of quench oil in the world. For information regarding the effect of oils on hardness and similar things - I would suggest reading Houghton on Quenching (I can email you a copy if you want - just send me an email or note smackenzie@houghtonintl.com). There is another reference book which is really excellent called the Handbook of Quench and Quenching Technology by G. Totten. I am working with George now to rewrite that book and update it with the changes that have occurred in the past 20+ years. Scott Overview Quench Oils.pdf Edited November 18, 2010 by kb0fhp D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
dragoncutlery Posted November 18, 2010 Share Posted November 18, 2010 i do have a hardness tester and so far canola oil has been my favorite. olive oil was a whole point of hardness lower at the same oil temp and tends to thicken up if the shop gets cold never tried peanut oil Brandon Sawisch bladesmith eagles may soar but weasels don't get sucked in to jet engines Link to comment Share on other sites More sharing options...
Alan Longmire Posted November 18, 2010 Share Posted November 18, 2010 Good to see you back, Scott! Thanks for chiming in. Link to comment Share on other sites More sharing options...
Matt Bower Posted November 18, 2010 Share Posted November 18, 2010 Pardon me if I missed something, but where did you buy the oil? Direct from Tulco's website? Link to comment Share on other sites More sharing options...
Beau Erwin Posted November 18, 2010 Share Posted November 18, 2010 Anyone tried baby oil? Beau Erwin www.ErwinKnives.com Custom knives Bcarta Composites Stabilized Woods Link to comment Share on other sites More sharing options...
C.Anderson Posted November 18, 2010 Share Posted November 18, 2010 Anyone tried baby oil? If I recall, baby oil is little more than mineral oil and scent, correct? Cris Slow is smooth, smooth is steady, steady is fast, fast is deadly... Erik R. http://www.facebook.com/scorpionforge Link to comment Share on other sites More sharing options...
Beau Erwin Posted November 19, 2010 Share Posted November 19, 2010 From what I recall reading a bottle that's all it is. Plus it seems to be a different viscosity as it seems thinner than regular mineral oil. I could be crazy tho. Beau Erwin www.ErwinKnives.com Custom knives Bcarta Composites Stabilized Woods Link to comment Share on other sites More sharing options...
jarrett Posted November 19, 2010 Author Share Posted November 19, 2010 Pardon me if I missed something, but where did you buy the oil? Direct from Tulco's website? I found it at a distribution site in Fort Smith, Arkansas. CUSTOM KNIVES BY JL RHODES JLRKNIVES ------------------------------------------------------------------------- God bless you. I thank God every day for the freedom to spend time with those I love, and time to pursue this craft. "Adversity is a test for strong men." "What one man can do, so can another." "NO excuses, just do better next time." Link to comment Share on other sites More sharing options...
jarrett Posted November 19, 2010 Author Share Posted November 19, 2010 The slow oil is essentially a 100 SUS mineral oil with no additives. The second oil is a medium speed oil that gets its speed using an additive (the reason it is darker). There are a variety of quench oils available that would work well for your application. I am a bit biased in my choice but I work for one of the largest suppliers of quench oil in the world. For information regarding the effect of oils on hardness and similar things - I would suggest reading Houghton on Quenching (I can email you a copy if you want - just send me an email or note smackenzie@houghtonintl.com). There is another reference book which is really excellent called the Handbook of Quench and Quenching Technology by G. Totten. I am working with George now to rewrite that book and update it with the changes that have occurred in the past 20+ years. Scott Thank you for the input. I would like the information. I will contact you. CUSTOM KNIVES BY JL RHODES JLRKNIVES ------------------------------------------------------------------------- God bless you. I thank God every day for the freedom to spend time with those I love, and time to pursue this craft. "Adversity is a test for strong men." "What one man can do, so can another." "NO excuses, just do better next time." Link to comment Share on other sites More sharing options...
kb0fhp Posted December 18, 2010 Share Posted December 18, 2010 Thank you for the input. I would like the information. I will contact you. I can't recall - did I send the information to you? D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
jarrett Posted December 18, 2010 Author Share Posted December 18, 2010 Yes you did. If I did not thank you at the time, I am deficient. It was/is extremely helpful. Again, thanks. CUSTOM KNIVES BY JL RHODES JLRKNIVES ------------------------------------------------------------------------- God bless you. I thank God every day for the freedom to spend time with those I love, and time to pursue this craft. "Adversity is a test for strong men." "What one man can do, so can another." "NO excuses, just do better next time." Link to comment Share on other sites More sharing options...
Eastvillage Posted December 23, 2010 Share Posted December 23, 2010 Would Houghton Quench 100 be a good choice for steels like O1, O2 and 1.5052? Greetings Toni http://www.eastvillageknives.com/ Link to comment Share on other sites More sharing options...
kb0fhp Posted December 24, 2010 Share Posted December 24, 2010 Would Houghton Quench 100 be a good choice for steels like O1, O2 and 1.5052? I am not familiar with DIN 1.5052 - is it similar to AISI 52100? Or could you give me a composition? O1 and O2 should be hardenable in thin sections with Houghto-Quench 100. It is the extra V (O1) and Mn (O1 and O2) that makes it better than 1090 steel and more hardenable. It should work. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Eastvillage Posted December 25, 2010 Share Posted December 25, 2010 I am not familiar with DIN 1.5052 - is it similar to AISI 52100? Or could you give me a composition? O1 and O2 should be hardenable in thin sections with Houghto-Quench 100. It is the extra V (O1) and Mn (O1 and O2) that makes it better than 1090 steel and more hardenable. It should work. Thanks KB0fhp, you say houghton 100 will work, do you think there is another houghton product that will work better? I'm asking since I'm about to order some hougton 100. I'm sorry, I now see I totally misspelled one of the steels. should have been 1.2550: C:0.55/0.65, CR:0.9/1.2, V:0.1/0.2, T:1.8/2.0 Greetings Toni http://www.eastvillageknives.com/ Link to comment Share on other sites More sharing options...
kb0fhp Posted December 27, 2010 Share Posted December 27, 2010 Depends on what you want (see - you can never get a straight answer from a metallurgist ) If you are looking to get the O1/O2 hard I would suggest using Houghto-Quench 100. The steel that you just cited has a very high hardenability because of the Cr and V. The V and W (Tungsten) will make nice carbides and help retain a nice edge. However, if you ever want to do lower hardenability alloys you will have a problem getting the lower hardenability parts hard. You may want to consider Houghto-Quench G - this is a medium speed oil that will get the high hardenability parts hard and should get your low hardenability parts hard too. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Eastvillage Posted December 28, 2010 Share Posted December 28, 2010 Depends on what you want (see - you can never get a straight answer from a metallurgist ) If you are looking to get the O1/O2 hard I would suggest using Houghto-Quench 100. The steel that you just cited has a very high hardenability because of the Cr and V. The V and W (Tungsten) will make nice carbides and help retain a nice edge. However, if you ever want to do lower hardenability alloys you will have a problem getting the lower hardenability parts hard. You may want to consider Houghto-Quench G - this is a medium speed oil that will get the high hardenability parts hard and should get your low hardenability parts hard too. Thanks kb0fhp, I'm really looking for a good oil for O1/O2 and 1.2550. I do use simpler steels like W2 and 1.2210 (silver steel), but these steels I water quench (with an additive) so far never had a cracked blade. Thank you for your detailed answer! Greetings Toni http://www.eastvillageknives.com/ Link to comment Share on other sites More sharing options...
