Iloquench 395
Gday all,
Does anybody use or have used Castrol's Iloquench 395 quenching oil. It is supposedly a 9-11 sec oil and appears to be the only "quickish" quenchant available in Australia.
Cheers Bruce
Barnett Custom Knives
www.barnettcustomknives.com
Australian Knifemakers Guild Secretary/Treasurer
American Bladesmith Society Apprentice
  • 3 months later...
Gday all,
Cheers Bruce
There are a variety of fast quench oils available in Austrailia - look at Houghton K. YOu could probably contact a heat treater to buy some from them or you can try some local sources.
D. Scott MacKenzie, PhD
Been there done that. No body was interested in selling 5-10 galls of a quench oil, not even Houghton. The Castrol appears to work fine.
canola oil might be avalible there i have a hardness tester and frequently test to destruction and have been using it for years on my carbon steel and now on my air hardening stainless as well
or some ppl use straight hydrolic oil im sure you can get that in aus
Edited by dragoncutlery
Brandon Sawisch bladesmith
Sorry - unfortunately, that is one of the problems. However, if you need more, you could contact a local heat treater - they may have some old oil that you may want to try. Glad you found a source. BTW, vegetable oil is good too.
  • 3 weeks later...
Scott,
Do you have a rough relationship on the longevity difference between canola oil and commercial quench oils (like Houghto-quench "K", for instance)?
Mike
Scott,
Mike
It all depends on how hard you abuse them. As a general rule the oil would go rancid before it would not achieve metallurgical properties. A mineral oil, properly taken care of will last a very long time. Filter it occasionally using a good quality filter and mineral oil will last a long time. Even if it does get very oxidized, a mineral oil will tend to get faster because the shellac layer on the part. Vegetable oil would do the same thing.
Take care of it and they will both last - but I can't quantify how long each will last as it is so dependent on a whole bunch of things. But in general I would suspect that the mineral oil would last longer.
im still getting good readings from my canola and its been in the bucket for 3-4 years i only hobbie blade smith these days but for the cost even if it went bad its real cheep to go to the store and get some more
  • 3 weeks later...
Just letting you guys know that the Illoquench 395 works just fine on 5160 & 52100. I just recently did 2 ABS test blades in 5160 and successfully passed the ABS JS performance test with both of them, one a practice run at home and the second at Bill Burkes in Nov before the Boise Rocky Mountain Knife show. Also my 52100 blades just keep on cuttin on rope :D .
Cheers Bruce
