Jared Stier
Jafnadr, Colab be Kenon Rain and Jared Stier
Great stuff Jared! Cool carvings! Nice blade too, looks like its design has historical background? B)
Cheers
Cheers
Mostly no from what I gather. The blade, Kenon made it I believe when he was starting to weld up some twists and had no desire to finish the blade. That is my favorite part so I just told him to send it my way. The handle, at least the front part is from the osberg ship, poorly copied. Then I had to try and figure out what the rest would look like it the lines went around. I wish I could get a good book on norse line work but they are more than I have free to spend. I will hopefully be able to make a sheath that is historic though as well as some nice knot work and symbols for the silver castings.
Thanks for taking the time to respond :)
He's got it right, I've really got to send you a nice 4-5bar blade to deck out.. maybe do some inlay even :)
I want to see what you can do dude
Whatever you want to send I will be glad to fit it out
and thank you raymond
Handle is done with sanding, at 2000 grit. I will wait until everything is mounted to oil it.
Here is the top spacer. Carving knot work this small is very tedious. Good thing I have time to kill at the office
Thank you Petr, Love your new profile picture by the way
waiting for the oil to dry and then add about 10 more coats
wow - the finish really brought the carving to life. Nice job. kc
That looks great! Can you show it fitted to the blade?
yeah i will snap a pic tomorrow. Thanks everyone
So yeah... sorry about that, its a little past tomorrow :)
Here is what it looked like before I carved. So I did not take a more recent picture. the bottom wax is much smaller now that was just a blank I had
Plaster is drying now, hopefully get it cast tomorrow.
casting sort of failed. It cast the basic shape but I believe that air bubbles got into my small holes so they did not cast the design on the outside. Now time to crave a new one and for some anti-bubble solution
shoot! you might consider making a centrifugal caster.. basically just spins the crap out of the mold forcing all the molten metal into all the details :) pretty simple things too..
What stops it from throwing molten metal all over the place?
Centrifugal Force =P
Also it can be built into a box just incase.
Seems like I remember Jake Powning had a tutorial on his site once that showed one.
what metal is it that you are trying to cast the pieces out of?
Yep Edgar said it, centerfugal force :) same as when you swing a bucket of water over your head it stays in it.
One of the ones I've seen was a T shaped rod mounted vertically with some sort of bearings in the center of half a 55gallon drum, with the crucible thing on one arm of the T, and a spring and counterweight attached to the other.. just wind it up, melt the metal and let it go
Interesting. I will look up how to make one or just buy one if its going to be a safety issue
and Dee, silver :)
silver can be very annoying to cast .. especially with vacuum casting.
id say that it might be porosity thats your enemy here.
centrifugal might be the way to go, considering its a small piece.
or else you can look at using a degassing flux .. or adding zinc to the silver alloy .. which will help in vacuum castings.
just my thoughts.
just my thoughts.
well I dont do vacuum casting as I dont have the machine and the one I made was way too strong. I will look into those things though, thank you :)
New one carved. I made it larger so hopefully my small casting operation will work better
