What I have been up to lately
kb0fhp
As you can tell, I have been absent a lot lately - I have been doing a lot of traveling all over the world working with heat treaters and forge shops. I just thought I would post a few pictures.....
All these parts are forged so should be of interest.
D. Scott MacKenzie, PhD
awesome.
Jake Cleland - Skye Knives
www.knifemaker.co.uk
Albert Einstein
are those windmill gears do you know? Very cool .... thanks for showing ... jaw dropping
Dick
Nice to get some size perspective about "big" parts for quenching. :)
Are the gears case hardened and quenched with martensite on the surface, and pearlite cores ? Or is it something different ? I would think martensite hard to get with that large a mass unless it is a special alloy ?
I want to know how they do something that big, with precision gears already cut, without any warping whatsoever. I would have thought the blank drums would be HT'd, and then cut.
Respect.
The Tidewater Forge
Christopher Price, Bladesmith
Respect.
Typically the gears are forged then machined. They are then austenitized and caburized for a case of 0.18 to 0.25 inches deep. The cycle takes up to 7 days. The parts are then quenched and tempered. Distortion is an issue - that is why they take care with the type of agitation and racking. Usually they are ground slightly after tempering - but it is kept to a minimum because it is so expensive. The case is martensitic with a pearlitic core.
Dick
Yes - they are the gears for the windmill transmission. These are 1.5MW wind turbines - the 5MW wind turbines are larger. The diameter of the blades is typically about 6+ feer in diameter - I can stand in the middle of the blades - they are also about 90 feet long. The pod at the top of the mast is about the size of a tractor trailer. Typical quench tank size is about 40,000 gallons, with many of the quench tanks being 60,000 gallons. These pictures were taken in the US, Brazil and China. One of the problems is that there is a shortage of qualified heat treaters with knowledge of quenching and control of distortion.
One thing I saw was quenching a 800T part into 1,000,000 gallons of quench oil - very impressive. The forges are amazing from the basic shaping of the billet to the actual forging of the blank. Typical weight of the hear treated gears is 25,000 pounds each. Ring rolling is used extensively for the large bearings used for yaw and pitch of the turbine blades. I have more pictures if anyone is interested. But I thought you would be interested in seeing how forging a small blade is related to larger industrial applications.
Edited by kb0fhp
That is basically correct - they use special alloys - think 4320 for the core, and carburized. Distortion can be an issue but is generally controlled by racking and control of agitation (they also use our oil :) for precision quenching).
It is very cool to see them quenching these gears, bearings and big shafts. It is the reason why I love heat treating.
Cool Scott.
Yes , I'd like to see more... Do you have any shots of them being forged? Thanks for showing ... it is really nice to have an industrial expert add his two cents to a bunch of bladesmiths.... we really appeciate your input and insight... it's invaluable.... Thanks,
Dick
Can you do me a favor and stick a few blades inside one of those things when no one's looking? ;)
Thanks for posting that. I'd love to see a video of the actual quench. I bet that's exciting!
Next time I am there I will try and take some video. Lots of flames and stuff.
Cool Scott.
Dick
I have the pictures on my work PC - I will try loading some from work.
Scott, thank you so much for sharing! I am very jealous of your journey!
  • 3 weeks later...
Scott,
Hope you can scrape together some of those pics... Perhaps you can't show some cause of info protection? but we'd like to see ones that you could show.... Time flies and I understand how busy you must get with your traveling.. I thought I would bump this to see if it jogs your memory..smile.gif
Thanks,
Dick
Scott, What is the personal and company (as a rep expert) pucker factor when you have gone all that way to "watch"?
Ric
Richard Furrer
Door County Forgeworks
Sturgeon Bay, WI
Ric
There is always a "pucker" factor - Hopefully whenever I do a fill like that I have looked at all the mitigating factors like quench rate, part alloy, thickness, agitation, quenchant used - and how to control the concentration (if polymer). Luckily I have only had one failure and that was because of agitation issues. I thought it was stronger than it was - after we corrected it, it worked like a champ.
Regardless of what you are doing - there is always a risk - that is why they pay me the big bucks :) - to minimize risk to the company; the customer, and to the part.
One I get to the actual load - it is more of excitement and celebration than anything else.
BTW, I am trying to put together some additional pictures. But to give you an idea of the size of the wind turbines - here are some small blades for 1.5MW turbines:
Now each of these blades has a yaw and pitch bearing - that means numerous parts from rolled rings that bust be heat treated (typically either 52100 or carburized 9310). The rings, races and bearings (the balls) must be heat treated.
Those are cool pics Scott. A friend of mine that is an iron worker erects these wind turbines he has some amazing pics.
Bob
Thanks Scott,
that one is a "small one" eh? It's cool to see how fast the technology has ramped up both in size and the "tech development" side of it...
Dick
  • 6 months later...
Thanks Scott,
Dick
Wind turbines are really a favorite of mine. They have to be forged, machined, heat treated and then assembled. Good solid manufacturing work. It is really cool when they are quenched and knowing that you had a part in it when you see them erected.
