FIGHTING WITH STYLE... ;-)
hi all,
here is a new knife for my next show in solingen:
ART-NOUVEAU FIGHTER
W1 forged and clayhardened
bronze-guard
seacow-rib
leathersheath
total 35cm
blade only 21cm
thickness 6.0-2,0mm
thanks for looking!
gerhard
Edited by wieland
It's astounding. I love it... The fit and flow is something I aspire to and this is a humbling inspiration.
WIELAND---Mighty fine!! Every part of it is just right for the rest.
The blade, the hamom, the solder, carving, fitting, sheath, the carving on the sheath all are just right.
Great job.
chuck
very nice - as always. I really enjoy studying your work. It is quite elegant.
any tips on how you polish to bring out those lovely hamons?
thanks for showing us this!
kc
thank you all for your kind posts, I appreciate it, that you like my knife!
@tonn,
I use an industrial coating/isolation from a supplier for quenching gear (oven, other hardware and quenching oils and heat-treatment tools).
it´s name here is `LENIT`. normally used, where drilled holes in a part must stay soft for tapping a winding after the quench. it has a very fine grain for good forming.
you should find a sort of it in estonia too.
@kevin,
activity begins long before polishing- you know of course ;-)...
my polishing : sanding to 2000, then with ´chrome-polish´ from a carbody- supplier,
then some etchings in Fe3Cl, in between polish with `WIENER KALK`, similar to a fine pumice, finally with a very fine metall-polish.
best regards
gerhard
Once again I am not sure what to say , you make elegant look easy and I know it isn't. I just checked out your website again and it is inspirational to see your "Old Iron" section and see your evolution as a artist. - Todd
