Twisted Stag
Karl B. Andersen
One for the upcoming Blade Show in Atlanta:
A high layer Twist blade in a fixed assembly with crushed Ws fittings and a stag handle.
Everything hot-blued.
"Bolted" together internally.
Come see me at 14-O!
Thanks for showing the knife Karl. Fits in nicely with the bluing writeup you did down in 'fit and finish'. I see you can catch a bit of that chatoyance in your pictures. Gotta ask, does internal bolting mean 'I think I have some epoxy around here somewhere'.
Nice work, Craig
Nice work, Craig
It IS epoxied to a degree, Craig, but is it also double pinned from guard to stag, and the butt cap is double pinned as well.
The tang is also threaded.
I created two "steps" inside and across the handle from one another.
And then, across them, I placed a steel "bridge" with a hole in the center, through which went a tapped finial to thread ONTO the threaded tang and pull everything together.
It IS bolted.
If you need pictures - I have them.
Edited by Karl B. Andersen
