danpiotte Posted June 9, 2011 Share Posted June 9, 2011 I have access to liquid nitrogen at work now and was wondering if a dunk would do my 5160 blade any good. I also have a CRKT m-21 0-4 with a aus 6 (I think)blade. The folder has an anodized aluminum handle. Is there any harm risked if the handle gets dunked? Thanks Daniel WAXING MOON FORGE The blacksmith and the artist reflect it in their art they forge their creativity closer to the heart. Rush Link to comment Share on other sites More sharing options...
Greg Thomas Obach Posted June 10, 2011 Share Posted June 10, 2011 5160 + liquid = a nice cold blade Aus 6 + liquid= a chance that it will trip off some RA and turn it to untempered martesite ---- then it should be place in oven and retempered to reduce the chance of brittleness theres alot of hype with undercooling steel.. North Shore Forge & Ironworks Link to comment Share on other sites More sharing options...
Doug Lester Posted June 10, 2011 Share Posted June 10, 2011 Maybe I should let one of the real metallurgists answere this but 5160 is not a real complex steel and I don't know if the real Mf point is below room temperature. None of the info I have from ASMI gives that data. Most ITT diagram only list the M90point. It won't hurt anything if you do it but you might only be making the steel cold. It could help if you measured the HRC before and after the cryoquench to get an answere. Some heat treaters go from the normal quenchant to the cryoquench and then to tempering oven. I know from data on cryquenching a stainless steel that you cause less stress by going from the quenchant to the tempering oven, to the cryoquench, then back to the tempering oven. Doug HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
kb0fhp Posted July 8, 2011 Share Posted July 8, 2011 Maybe I should let one of the real metallurgists answere this but 5160 is not a real complex steel and I don't know if the real Mf point is below room temperature. None of the info I have from ASMI gives that data. Most ITT diagram only list the M90point. It won't hurt anything if you do it but you might only be making the steel cold. It could help if you measured the HRC before and after the cryoquench to get an answere. Some heat treaters go from the normal quenchant to the cryoquench and then to tempering oven. I know from data on cryquenching a stainless steel that you cause less stress by going from the quenchant to the tempering oven, to the cryoquench, then back to the tempering oven. Doug Download Timken Practical Guide for Metallurgists - lots of good data there and free. There is a new edition out there - just go to the Timken site and download it. Timken Practical Data for Metallurgist.pdf D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Robert George Posted July 16, 2011 Share Posted July 16, 2011 My understanding matches Doug -- that cryo converts retained austenite on high alloy steels (stainless, D2, 1V, 3V,...). The low alloy tool steels like 5160 won't have a bunch of retained austenite if heat treated correctly. More importantly, the heat treat sheets from Carpenter, Crucible et al indicate that cryo has to be done on high alloy tool steels almost immediately after quench to be effective. Link to comment Share on other sites More sharing options...
kb0fhp Posted January 24, 2012 Share Posted January 24, 2012 My understanding matches Doug -- that cryo converts retained austenite on high alloy steels (stainless, D2, 1V, 3V,...). The low alloy tool steels like 5160 won't have a bunch of retained austenite if heat treated correctly. More importantly, the heat treat sheets from Carpenter, Crucible et al indicate that cryo has to be done on high alloy tool steels almost immediately after quench to be effective. What will happen when you quench steel in liquid nitrogen is that the LN2 will immediately turn to vapor and you will get a very persistent vapor phase - it is a very slow quench. Only vigerous agitation will break up the vapor phase. Another thing to concern yourself with is that all the LN2 will also turn to gas and create a suffocation hazard. This was well documented about 30 years ago when several people died when a manufacturer tried it. D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
