Samurai Stu
Fresh from the forge
Some medium bowies fresh from normalising and grinding
... and their larger brothers at about 12" blades for the three big ones
looks like a nice batch... !
now all the fun is done.. thats alot o handles to get together
cool stuff
I always love seeing new stuff from you, eye-pleasing as always.
Looking good Stu. I'm a fan of the big Bowies. I will be following this to see them finished, thanks for sharing.
Jerry Fisher
Polished and etched/ Blacked
With Their respective handle materials
Pieces drilled and tapped
Checking fit
Dry fit
All glued up
Sizing up the teeth.
After some stressful drilling I managed to get neat holes that fit the tangs well.
Guard filed and fitted. Also some pre shaping done. The guard will get hot and the tooth could crack if shaped when its all glued together first.
Back of the guard. Tapering of the quillions also done.
Final fit of guard
Checking surfaces are flat on handle
Dry Fit
Pre shaping the handle. Comparison with other piece.
Handle roughed to 240 grit
Next Bowie ready for a handle. This one is K600 and elephant bone
Preparing the threaded rod for the tang
Welded and tempered.
Checking the fit.
All glued up.
The next bowie already glued. Handle from K600 and red bush willow.
I pre shape the Pommel and guard to avoid over heating of the handle pieces.
great photos and work!
Indeed! Do those cracks in the one ivory handle make you nervous, or have you stabilized them? And if so, how? I use superglue on cracked antler (hippo teeth being in short supply in East Tennessee!).
This is such a good step-by-step I think it might be worth pinning. What do the rest of you think? B)
Those are natural cracks which I fill with superglue. Difficult to impossible to stabilized Hippo teeth because of its high density. It does crack a little a tthe ends if the guard or pommel are over heated when grinding. I would trade hippo for some decent antler crowns. They are in short supply in SA too.
Rough profile on handle
Rough contouring
top view of palm swell
Smoothed out with a soft 60 grit belt
Guard taped up and handle polished
All my babies in a row.
The spec on these two are basically the same.
Blade forged from 1070 high carbon steel with Hamon
Handle from Hippo tooth and nickel silver.
Blade length 310mm x 50mm x 8mm
Handle 135mm x 30mm x 20mm sculpted
OAL445mm
Blade forged from 1070 with hamon ans etch.
Handle from Red bush willow and K600 tool steel (Blackened)
Blade length 250mm x 45mm x 7mm
Handle 130mm x 30mm x 20mm sculpted
OAL 380mm
Blade forged from 1070 high carbon steel with gun black finish.
Handle from Elephant bone and K600 tool steel (Blackened)
OAL 380mm
Blade forged from 5160 spring steel with gun black finish.
Handle from Black ivory and stst.
OAL445mm
Your work is amazing, absolutely beautiful. Now if i could get my hands on some hippo teeth. I also really enjoy the effect of the gun-black. I my need to try it on something.
That is just one nice bunch of big ol Bowies. Thank for sharing the build along.
Jerry Fisher
This has been fun to watch, I am particularly impressed with that massive slab of elephant bone... that's something you don't see every day.
Beautiful work sir!
Sounds good to me... B)
It is allways a little surprising to watch a creation go through all the stages of ugliness , then become a thing of beauty as well as function . Very nice work , ( as usual )
Shots of sheath construction.
You don't slow down, do you :D
Awesome job, all the packages look very pleasent and flowing. Love those sheath imprints!
Thanks for the bump to the Stickies
The whole package. I had fun making these blades. They are with their proud new owners now.
A really good step-by-step with pics usually ends up stickie'd. Thanks for doing a good job! B)
Hi Stu
I have been experiencing some car problems, but as soon as I have those sorted out, I will take you up on that offer of a visit.
Awesome work!
Wayne
