quench oil aging
GEzell
I have some 12 year old canola oil that has had at least 50 blades quenched in it over the years... :rolleyes:
During that time I was focusing on 5160 as my primary steel, so I was not really concerned with my oil breaking down as 5160 will just about harden in a cool breeze. I edge-quench too, so this oil has been abused....
Just for the heck of it, I still quench in it on occasion when the steel doesn't need a fast quench. I have noticed something interesting. I had assumed as it aged and broke down that it would become slower and slower, however, just the opposite seems to have happened. I recently quenched a fairly long, wedge-shaped blade in it and got sori... not a nose dive as I would expect in oil, but the tip actually raised a bit. The last time I used it, the blade cracked in several places. I haven't cracked a blade in years, and then only in a brine or water quench.
I think it has gotten faster, not slower. Is this typical as oil breaks down? Could it have absorbed enough moisture over the years that it now behaves more like a water quench than an oil quench?
What are the effects on quench speed as oil ages?
Note: I am now using parks50 for 1095/w2 and fresh canola for 1080 and 5160. But I am curious.
George Ezell, bladesmith
Buffon
view some of my work
RelicForge on facebook
I've heard rumors that Canola actually gets faster with age. There's a long running flame war going on over at BF about canola being a viable quenchant regardless. Personally I use it for medium speed applications, as opposed to buying something like Fastquench, or AAA, but I use Park 50 for W2, 1095, etc. due to ease.
Interesting thing about the vegetable based oils is the apparent lack of vapor jacket, which is the slow heat transference first phase of the quench, with water or petro based oils, although the boiling phase is apparently less important than the convection stage, I wonder how this plays out once the oil ages. Oil will take on water and supposedly with petro based oils hydration as much as .05% can affect performance, supposedly negatively, but who knows. Perhaps over time, hydration and oxidation of the vegetable based oils (which are generally considered less stable), takes on enough water to increase the secondary phase of the quench, of which from my understanding, canola is already considered to be extremely fast initially, then slower in the second stage when fresh.
Hopefully someone with more knowledge than ourselves will enlighten us? ;)
At 12 years and dozens of quenches, it's time for this oil to move on to it's next career: salad dressing. Some vinegar, iron filings, and herbs and you'll have something special.
Edited by tgdula
www.toddblades.com
"Geometry says how sharp, steel says how long." - Roman Landes, Ashokan 2009
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
- George Orwell
That's my thinking too, time to retire it... I know a fellow who makes bio-diesel that might like it.
I am curious as to why it is cooling steel fast enough to crack it, though, but I am now almost certain it is due to taking on moisture. What I don't understand is that oil and water should not mix without separating, and this shows no sign of it.
Buffon
  • 1 month later...
The only oil that I know of that absorbs moisture from the air is Brake Fluid
Dry boiling point
Wet boiling point
DOT 3
205 °C (401 °F)
140 °C (284 °F)
DOT 4
230 °C (446 °F)
155 °C (311 °F)
DOT 5
260 °C (500 °F)
180 °C (356 °F)
DOT 5.1
270 °C (518 °F)
190 °C (374 °F)
Hope this helps
To error is human To really ****up you need a computer. BTW I hate computers. Knowledge is Power, what You do with it either makes you a leader or a dictator
My oil certainly got faster! Then I discovered that the bottom 1/3 was now water! Once we got rid of the water, the "oil" went back to normal speed! :blink:
[font="Book Antiqua"][color="#0000FF"][size="5"][b]Perfection[/b][/size]
[i][size="3"]is achieved not when there is nothing left to add, but when there is nothing left to take away.[/size][/i][/color][/font]
  • 1 month later...
Canola will get faster if there is water present. It will not separate as canola or vegetable oil is hydrophillic (likes water).
Oil that contains more than 1000 ppm of water can be a serious fire hazard as the water turns to steam and pushes the oil out. Often the oil ignites from the hot part. Then you have a real mess with flaming oil over everything
D. Scott MacKenzie, PhD
