Kip Kaiser Posted October 17, 2011 Share Posted October 17, 2011 I'v been thinking of buying a jewelers saw and was wondering if any one has tried one and is it worth the investment? A man is no better than his word! Check out the web site @ www.thekaisercustomknives.com Link to comment Share on other sites More sharing options...
MAtthew Boston Posted October 17, 2011 Share Posted October 17, 2011 i use mine all the time. ALL the TIME so its a good investment . i use it for bronze, al. , and copper. so id go for it . i paid a total of $12 for it Link to comment Share on other sites More sharing options...
Alan Longmire Posted October 17, 2011 Share Posted October 17, 2011 I've been using them for about ten years now and while I hate them as fickle, fragile, evil pesky things I can't live without 'em. They do work on steel, but you need great patience, a steady hand, and a large stock of very good blades in the proper size. If you get one, get the smallest frame that will fit what you want to do. They come in 2" deep, 5" deep, 6" deep, and even larger for working on big thin sheet, but the shallower frames are more rigid and result in less blade breakage. Buy the best blades you can afford from a jewelry supply place, not a knife supply place. The only tricks are knowing what blade to use (must have at least three teeth in the cut at all times, but not more than six if you want to get it done), and being able to hold it perfectly vertical while sawing and applying just enough pressure to cut without bending the blade in any direction. The blades are high carbon, hair-thin, and will happily fatigue and snap at the slightest bad move on your part. Get a copy of Tim McCreight's "The Complete Metalsmith" for some good tips on fine metalwork before you start sawing. It will help you in many ways. Link to comment Share on other sites More sharing options...
Matt Bower Posted October 17, 2011 Share Posted October 17, 2011 Pretty sure lots of folks here use them. I just recently bought one and am likely going to be trying it out very soon. Link to comment Share on other sites More sharing options...
son_of_bluegrass Posted October 17, 2011 Share Posted October 17, 2011 I've got 2 a cheap one and a good one. Don't bother wasting your money on a cheap one, if you can't afford a good one (still not much) don't bother. The cheap one I got from a knife supply place. The good one from a jewelry supply place. With a little practice you can dull blades before they break. A jewelery cutting v block helps. (I think that is the right terminology). ron Having watched government for some time, it has become obvious that our government is no longer for the people. If the current trend continues, it won't be long untill armed rebellion is required. Link to comment Share on other sites More sharing options...
J.Arthur Loose Posted October 17, 2011 Share Posted October 17, 2011 You want a nice, German saw and good blades. A jewelry bench pin (the V-block above,) is the ticket. Saw straight up and down, turn your piece and not the saw, sit with your sawing shoulder in line with the piece, sit lower than you normally do and with a little practice you should be able to saw through anything short of hardened steel. jloose.com Link to comment Share on other sites More sharing options...
JDWare Posted October 18, 2011 Share Posted October 18, 2011 I'm planning to try one of these: http://www.knewconcepts.com/saws.php I have no affiliation with them, but heard good things. here's a video review: Link to comment Share on other sites More sharing options...
Patrick Hastings Posted October 18, 2011 Share Posted October 18, 2011 They are not a costly investement and there usefulness will have much to do with your temperment. If you are patient meticulous type person they are invaluable IMO. I have been using them for about 20 years now. I cut steel plate with them frequently... It takes a great deal of patience and very good form to optimize, but you can do some great stuff with a $15 frame. Jewelers saw project Patrick Link to comment Share on other sites More sharing options...
GEzell Posted October 18, 2011 Share Posted October 18, 2011 Impressive work, Patrick... I find mine useful for slotting guards on the rare occasion I make a knife with a guard. I drill 2 holes and saw out the excess between them with the jewelers saw, and then touch it up with a thin file. It seems to be more foolproof for me than other methods I've tried. George Ezell, bladesmith" How much useful knowledge is lost by the scattered forms in which it is ushered to the world! How many solitary students spend half their lives in making discoveries which had been perfected a century before their time, for want of a condensed exhibition of what is known."Buffonview some of my work RelicForge on facebook Link to comment Share on other sites More sharing options...
Kip Kaiser Posted October 18, 2011 Author Share Posted October 18, 2011 Wow thanks for all the input every one that makes it a no brainer. Patrick the pic's were amazing thank you I can' wait to try for myself. Kip A man is no better than his word! Check out the web site @ www.thekaisercustomknives.com Link to comment Share on other sites More sharing options...
Ben Dawson Posted October 19, 2011 Share Posted October 19, 2011 A trick I learned in school was to wax the blade. Just saw gently on a harder chunk of wax to coat the blade. You will get a little more forgiveness when you apply pressure in a non-desired direction. You will break a few less blades. Once you get the hang of it, the wax becomes unnecessary. Link to comment Share on other sites More sharing options...
Art Lawrence Posted October 24, 2011 Share Posted October 24, 2011 (edited) Thanks to this topic I once again tried cutting the slot for my guard with a jewelers' saw. Oh my gosh!, it worked. This time I built a bench pin. It made all the difference. It only took me about 15 or 20 minutes and the slot was cut. Another few file and fit, file and fit tries and I had a tight fit. Oh my gosh!!! Thanks all, Art Edited October 24, 2011 by Art Lawrence "My sword and my shield are at your command" Link to comment Share on other sites More sharing options...
PS_Bond Posted January 31, 2012 Share Posted January 31, 2012 I'm planning to try one of these: http://www.knewconcepts.com/saws.php I use mine a fair bit; the only caveat on Lee's saws is if you're doing a lot of piercing (cutting out internal shapes) then the standard screw top is very slow to undo & redo (for an eternity ring I completed a wee while ago, I ended up swapping back to one of my older sawframes because of that). The lever tensioner version gets around that. The rigidity of the frame is very good, but is particularly noticeable in the larger sizes, where frame flex is a lot worse on the more traditional designs. As for blades - buy the best (usually the more expensive ones!). The cheap selection packs that you see around are invariably not terribly good; they either break quickly or blunt. All the Swiss ones I've used have been very good; if you're cutting steel (for tsuba for example) then I've found blades meant for platinum work are good. Buy lots, you'll break them Do lube the blade - although I find that if I cut into the block of wax with the blade, the teeth end up packed with wax + filings, so I always lube the back & sides of the blade. Doesn't need much, just an occasional wipe. Above all, don't force the saw - let it cut under its own weight, more or less; if you want to change direction, march the saw in place and turn it gradually so it cuts its way around to the new direction. Peter Link to comment Share on other sites More sharing options...
Stephen Olivo Posted April 16, 2012 Share Posted April 16, 2012 Just chiming in my little bit but as with all saws, files, and chisels it is handy to keep it well oiled to remove friction and make your life a lot easier. I tend to follow the mutton pot example and use types of lard/bacon fat to lubricate things and protect them from rust. It will make your life so much easier with both wood and metal. Let the saw do the work your just moving it up and down it does the cutting. "Remember to live life to the fullest and without regret for the joy of life is that it ends." Me http://ipneto.deviantart.com/ Link to comment Share on other sites More sharing options...
Grant Dorangrichia Posted April 19, 2012 Share Posted April 19, 2012 Spend the extra couple bucks and pick up some burr life http://www.riogrande.com/Product/Stick-Bur-Life-Lubricant/117003?pos=1 It's well worth it. Grant Link to comment Share on other sites More sharing options...
Hÿllyn Posted April 20, 2012 Share Posted April 20, 2012 (edited) Re: Knew concept saw frame There's only one guy who uses it and endorses it that I can say I like his work. However, don't fool yourselves guys. The tool alone doesn't do the work. Learning the correct technique and doing a lot of practice does. The person I'm referring to is James Miller FIPG http://hartquotes.blogspot.co.uk/2008/05/june-2008.html As you can see in the picture, he's using a regular traditional pattern saw frame, however he's been endorsing the Knew concept frame for a while. As PS Bond mentioned, I have heard plenty about how slow it is to change blades, and there's a big difference in price for the convenience that should have already come included if you are claiming to make sawing easier! Also, the red colour, what nonsense. Why didn't they anodize their titanium frame (their most expensive hand model) if the colour was that important? To go with that marketing charade they should offer Digital camo and Multicam paint jobs for it I will probably get one of the small ones one day to try it out, but trust me, I will paint it a different colour. Also, I doubt that if swapping blades is that much of a hassle, that I will swap my vintage German and English saws for this. Maybe will keep it for cutting 4-6mm mild steel fitting blanks. Also, did I mention they are expensive? Edited April 20, 2012 by Hÿllyn Grey hair and alopecia are signs of age, not of wisdom... Rósta að, maðr! Link to comment Share on other sites More sharing options...
Patrick Hastings Posted April 21, 2012 Share Posted April 21, 2012 Re: Knew concept saw frame There's only one guy who uses it and endorses it that I can say I like his work. However, don't fool yourselves guys. The tool alone doesn't do the work. Learning the correct technique and doing a lot of practice does. The person I'm referring to is James Miller FIPG http://hartquotes.blogspot.co.uk/2008/05/june-2008.html As you can see in the picture, he's using a regular traditional pattern saw frame, however he's been endorsing the Knew concept frame for a while. As PS Bond mentioned, I have heard plenty about how slow it is to change blades, and there's a big difference in price for the convenience that should have already come included if you are claiming to make sawing easier! Also, the red colour, what nonsense. Why didn't they anodize their titanium frame (their most expensive hand model) if the colour was that important? To go with that marketing charade they should offer Digital camo and Multicam paint jobs for it I will probably get one of the small ones one day to try it out, but trust me, I will paint it a different colour. Also, I doubt that if swapping blades is that much of a hassle, that I will swap my vintage German and English saws for this. Maybe will keep it for cutting 4-6mm mild steel fitting blanks. Also, did I mention they are expensive? I have had a chance to use three different models now. The first generation versions were very awkward IMO. Any advantages from the stiffer frame were burned away by slow awkward blade changes. The tensioning mechanism often simply falling apart and was fussy to put back together. The newer cam tension models I have used both the aluminum and titanium versions. Both of these were the deeper throat models. I have to say that the stiffer frame makes itself much more felt and appreciated in the deeper frames. Still the quality of construction and precision of the components seems rather low grade. In my class one of my generous students offered to donate a brand spanking new one to me. As much as I like free stuff I declined. My $15 German frame saw has too many advantages over the new fangled versions. One issue is the pin hole type blade mount. These get clogged with blade lube metal dust and broken blade bits are difficult remove Not an issue with the flat plate type vise on my saw. Mounting and tensioning the blade on the concept saw is two to three different actions. The screws that hold the blades in the concept saw have weak little plastic handles cast over a steel screw. These don't look like they will hold up IMO. In my experience the plastic always breaks off tensioning levers like this. Also I find there is not enough leverage to tighten the screws enough for the amount of tension I like so blade pop loose on me. I really did not like the look of the cam axis. The shaft or tube this pivots on has plastic plugs on either end. I am not sure what purpose these serve, but they are just smashed in there and it looks sloppy. If i pay $50 to $200 for a saw frame I want the thing to look and feel qualitative and to last a lifetime. This saw just does not inspire me with confidence. I have been using my German saw frame for over 20 years now and I have never had maintenance it ever. I think if you need an ultra deep frame that the concept saw is worth looking into. In the sizes I like 5 inch or smaller I personally prefer a standard frame. Patrick Link to comment Share on other sites More sharing options...
Hÿllyn Posted April 21, 2012 Share Posted April 21, 2012 I concur Patrick. I was thinking of a deep frame to cut lengths for blanks and other larger formats. There's something I do about the clogging issue, and that is to pierce a piece of nitrile or similar with the blade and then just use it as a bib. Admittedly that grobet that requires the bib is my least favourite of my saws and thus I use it very rarely. Sometimes when I pick it up, it is because I put blades on all my saws, so if one breaks I cycle through two of them at least. My vintage ones are just a dream and further make the point about over engineering not being the answer if you will cock it up during manufacture by making poor material and procedure choices. Grey hair and alopecia are signs of age, not of wisdom... Rósta að, maðr! Link to comment Share on other sites More sharing options...
