Small Tatara Firing Schedule
Dan O'Connor
I found a blog by a lady teaching English in Japan. She attended a demo Tatara put on for a elementary school conducted by Kihara-murage-san.
She got some pretty good pictures and made a decent write up.
Part one
Part two
One of the pictures was of their firing schedule. Most of it is apparent but can anybody translate the Japanese on the sheet. Particularly what do the numbers mean after the weight of the iron sand and charcoal charges?
One column increases from 7.9 to 27.9. The other 49 to 71????
I also thought the temp recordings of the top and bottom of the stack a good catch.
Jesus is right:
>>7.9 to 27.9. The other 49 to 71????<<
is probably the second page of their recordings
putting in 0.8kg of ironsand (later 1kg!) to 1kg of charcoal each time (showing the totals in the next column)
the lady described the procedure, but sometimes used wrong terms, like mentioning "steel" coming out the tatara, which was actually "slag", you can see from its flow how good the smelt is going on, reducing the Fe0x to Fex (with some C in it as well = steel),
the temps described are rather low, though
so they did not have a smith around who could have worked on that nice lumb of iron/steel
too bad
Edited by Jokke
Jokke
Thanks for the links. Unfortunately my browser does not display the images for that website.
Those columns show "running sums" 累計
Well Duh,
That makes sense now. So the charcoal column is the total charcoal loaded in this furnace from the beginning before any iron sand was loaded?
Jesus
I saved the pictures and will post them when I get home later today.
too bad
Jokke,
I believe they will bust it up and separate it out into the various parts (high carbon steel, low carbon steel, cast iron etc.) Then work those individually.
yep,
normally they do that
but not this time in the description of the lady
as far as I understood they left the big chunk for looking at it (not good enough for swords?! as she puts it in the end)
you can take a look here:
http://www.messerforum.net/showthread.php?t=86207
where Achim Wirtz describes his version of a tatara he ran in Germany last year
I had the oportunity to be there, when they opened the tatara and took out over 400kg of steel
that mostly looked like this:
http://www.messerforum.net/showthread.php?t=96993
and you can bet that this was used for blades!
Jokke
This appears to be the same situation as Kihara San ran twice in Minnesota in 2004.
He is a knowledgeable man who loves the steel.
Jokke,
Why are the air tubes angled up in Achim's furnace? Seems counter productive and will lead to a rather porous kera.
Ric
Richard Furrer
Door County Forgeworks
Sturgeon Bay, WI
Dan,
Thanks for sharing the links, I find the building of the furnace most interesting.
Jan
yep,
I forgot she said it would not be used for swords.
I wonder what is not good enough about it?
Jesus here are the pictures.
All pictures form the blog Adventures Abroad
Iron sand
Separating sand
Tatara base
Building Tatara
Chopping charcoal
Collage
Tatara side
Firing
Charcoal load
Wide view
Loading
Slag
Lecture
Extracting Bloom
Cooling Bloom
Kera
I wonder why your not seeing them Jesus?
You likely have seen these before though. I know I had a while back.
Nice little square stack, about the size of a 12 in tile rig. It looks like they had 3 tuyere ports all on one side.
Mark
Mark Green
(cptn. Mal)
I am using Google Chrome. May some compatibility problem. But a kind hand has send the pictures to my email address. :D This looks like the kodai tatara that was demonstrated by Kihara here years ago and that he demonstrates to middle school children in Japan year round.
Enjoy life!
