"draw file finish"
Scott A. Roush
I have a blade in which I want a draw filed finish. I've seen mention of swords finished that way for sort of a rustic look. But unless you go into the quench in a finished state... how do folks do this? Are there any carbide tooth files/rasps out there? I suppose a hand rubbed finish at a coarse grit approximates it enough...
Just found this on ebay: http://www.ebay.com/itm/Tungsten-Carbide-Grit-File-Shape-Ceramic-Steel-Concrete-/320744258900?pt=LH_DefaultDomain_0&hash=item4aadd8fd54
Might as well give it a shot.. might save me money on the files I go through on guard fitting. But what will it do to my carbide liner on my file guide!?
This sounds like you are asking how to file a sword after heat treat. A sword generally is tempered enough it can be filed without a problem. Or are you working on a knife that you plan on leaving hard enough a file won't work?
ron
Edited by son_of_bluegrass
Having watched government for some time, it has become obvious that our government is no longer for the people. If the current trend continues, it won't be long untill armed rebellion is required.
Although it's called a "file" being "grit" it's really a coarse abrasive stick. Smooth draw filing is done with a mill file and can give a very smooth surface especially if followed with a scraper (one-tooth file).
[font="Book Antiqua"][color="#0000FF"][size="5"][b]Perfection[/b][/size]
[i][size="3"]is achieved not when there is nothing left to add, but when there is nothing left to take away.[/size][/i][/color][/font]
well.. this is actually for a sword and I haven't heat treated it yet. This is my first sword (1075) and I suppose I wasn't thinking yet about much I would draw it back. My knives would typically be too hard for standard files. but.. yeah... I suppose swords are generally drawn back to a softer temper... Gotcha. Thanks for that.
we posted at the same time...
sure... I draw file quite a bit and actually like it. I just normally do it before heat treat. But I often start with a coarse file and then go to the fine mill file. Haven't tried the one tooth yet though..
Seems like the tungsten thing should hog pretty well though! Anyway... I'm assuming I will draw back enough that my standard files should work...
Scott,
If you are doing sword bevels by hand, I highly recommend you carefully read Don Fogg's tutorial: http://www.dfoggknives.com/handwork.htm
He has put on lots of sword making classes in which he teaches his hand shaping techniques, so they are tried, true and refined.
Although he spends a lot of time on Eastern blades, the techniques he uses are easily used on European blades as well.
Luck!
--Dave
http://stephensforge.com
