ZebDeming 4 Posted January 17, 2012 Share Posted January 17, 2012 I've been using a rr track for an anvil, while looking for a "proper" anvil. Today I was at the local steel supplier and just asked about some heavy chunks of steel, he pointed me to the back shed where he said there was some big chunks of d2 that they had picked up along the way somehow. There was probably 10 tons of the stuff there im various shapes, the biggest chunk was about 18x12x8 (didn't have a tape measure) I could barely roll the thing up on edge. Now I know that it would be heavy enough, but would d2 make a good anvil? He didn't give me a price but said that his boss would give me a good deal on it, but before I pay anything for it I want to know if it would give me any problems. Thanks Zeb Link to post Share on other sites
Alan Longmire 2,752 Posted January 17, 2012 Share Posted January 17, 2012 Yes. D2 is a VERY tough steel, highly abrasion resistant, and darned near stainless due to chromium content. The only question would be how hard is it in its present state? You don't want it too hard is the thing. Link to post Share on other sites
Doug Lester 282 Posted January 17, 2012 Share Posted January 17, 2012 There's probably no such thing as a anvil being too heavy but you could do just as well with a smaller piece. I got a block of H13(?) 8.25X7.25X4.25 that weighs in at 87lbs and it really moves steel. If you get that piece, mount it so that it's 18" high to keep as much of the mass as possible under your work. Make sure that you round the edges and corners a bit. That block of mine out works a 110lb European style anvil by a wide margin even though it rebounds less. A good block like you're looking at will make you want to turn your railroad track anvil into a boat anchor. Doug Link to post Share on other sites
SonnyDuong 0 Posted January 17, 2012 Share Posted January 17, 2012 if u get a good price on it wouldnt that stuff make some great knives? Link to post Share on other sites
ZebDeming 4 Posted January 18, 2012 Author Share Posted January 18, 2012 Thanks guys! I'm assuming that it's annealed as it looks like it's been saw cut. They really don't know more than that it's D2 steel, it came from a local stamping plant that closed it's doors, they used it for the die's. Will it work well in it's annealed state or should it be heat treated? A file should be able to tell me approximately how hard it is, correct? If it will make a good knife I'll pick up some smaller pieces of it as well. There was all kinds of it there, I'm gonna find out how much it is before I decide on the huge piece, Doug thanks for the dimensions of a block that will work well. Again, thanks for all the help. Zeb 1 Link to post Share on other sites
Dan O'Connor 25 Posted January 18, 2012 Share Posted January 18, 2012 if u get a good price on it wouldnt that stuff make some great knives? I tried that once with block of D2 much smaller than the one Zeb is looking at. Cheaper and way easier to buy d2 knife stock rather than paying for bandsaw blades and the time to do it. Link to post Share on other sites
Geoff Keyes 522 Posted January 18, 2012 Share Posted January 18, 2012 You should not buy it, except to send to me . I've got a 5 x 6.5 x 33 piece of as-found 4140 that I use and it's great, better in fact than my Fisher for knife making. Give it a rap with a hammer, to check for rebound and to check on how it marks. Unless it has no rebound at all and takes marks really easily (or chips), I'd go for it. Mount it with the longest axis under the hammer and figure a way to attach it to a block or stand and you'll probably be very happy with it. D2 is tough stuff, tough to work too. You might want to check out what the HT is like before you go all in on a bunch of stock. Go thou, and pound! Geoff Link to post Share on other sites
JDWare 7 Posted January 18, 2012 Share Posted January 18, 2012 I also wouldn't plan on forging it. It can probably be done, but it's an air hardening steel and best for stock removal. It's an excellent blade steel when properly heat treated, very tough and very stain resistant. Sounds like a potential great anvil too. J JD WARE KNIVES Link to post Share on other sites
Howard Clark 3 Posted January 18, 2012 Share Posted January 18, 2012 Even dead soft annealed it will make fine anvil as long as you do hot work on it. If it is a good deal, get it, and use it. You won't regret it. For bladesmithing, a bit rectangular block is great. I use the horn doing some other stuff, but rarely (almost never) miss it making blades. I use a big block of steel that came with my power hammer as a saddle die, the face is 5" X 13" and it works great. Link to post Share on other sites
SonnyDuong 0 Posted January 18, 2012 Share Posted January 18, 2012 didnt know it was that tough to work. sounds like good anvil metal. Link to post Share on other sites
ZebDeming 4 Posted January 18, 2012 Author Share Posted January 18, 2012 Thanks for all the help fellas. I did pick up a piece of it today 10x10.5x6 The price was pretty fair for what it was (1$ pound) here's a pic of it Now on to building a base for it. It's definatly in a soft state, a file will doesn't skate across it, just will barely dig in on a corner of it, and if I hit it really hard with a 2 lb hammer I can just barely ding it Link to post Share on other sites
ZebDeming 4 Posted January 19, 2012 Author Share Posted January 19, 2012 I got a base built tonight, after a bit of research I decided to set the face of it at a few inches above knuckle height. Wow what a difference from the rr track. No more ringing just a solid whack. Making the anvil face at the right height made a big difference too. Thanks for all the help Link to post Share on other sites
Doug Lester 282 Posted January 22, 2012 Share Posted January 22, 2012 That railroad track anvil a boat anchor yet? Doug Link to post Share on other sites
ZebDeming 4 Posted January 22, 2012 Author Share Posted January 22, 2012 Ha, it's well on it's way Doug, the big chunk of D2 has been getting some use in the past couple days. I'm trying to talk a friend of mine to get into bladesmithing, but he's on the fence, I may give him the RR track and an old brake drum forge I have that I don't use. It would be a cheap way to get your feet wet, but I'll include some ear plugs in the deal I never realized how loud that dang track was until I started using something proper. Thanks again for all the advice! Zeb Link to post Share on other sites
Doug Lester 282 Posted January 23, 2012 Share Posted January 23, 2012 Well a European type anvil can ring pretty loud too. The thud of the steel block doesn't carry as far as the ring of the anvil. Doug Link to post Share on other sites
justin carnecchia 67 Posted January 23, 2012 Share Posted January 23, 2012 Nice score. Should make a great anvil. Heat treating it won't be an option, d2 requires long soak times at specific temps, and that is for knife blade sizes. It should work harden some though. Even annealed it is harder than red hot steel, the mass is what's important. Have fun, -Justin Link to post Share on other sites
Patrick Hastings 1 Posted January 26, 2012 Share Posted January 26, 2012 Nice score. Should make a great anvil. Heat treating it won't be an option, d2 requires long soak times at specific temps, and that is for knife blade sizes. It should work harden some though. Even annealed it is harder than red hot steel, the mass is what's important. Have fun, -Justin I have an electric furnace that it would just fit in. I would not be able to stop myself from attempting HT. It still requires quite a bit of prep and forethought. You would need a very sure effective way to unload the furnace and move it. It would need a place that could take all that radiant heat. 1850F+ in a block that size will burn your skin from 5 feet away LOL... Nice block regardless. The good thing about leaving it as is... you can resurface it as many times as you like and you have many faces to use before you even have to worry about it. Looks like a life time anvil to me... good score. Patrick Link to post Share on other sites
Rory Carter 0 Posted January 28, 2012 Share Posted January 28, 2012 I have an electric furnace that it would just fit in. I would not be able to stop myself from attempting HT. It still requires quite a bit of prep and forethought. You would need a very sure effective way to unload the furnace and move it. It would need a place that could take all that radiant heat. 1850F+ in a block that size will burn your skin from 5 feet away LOL... Nice block regardless. The good thing about leaving it as is... you can resurface it as many times as you like and you have many faces to use before you even have to worry about it. Looks like a life time anvil to me... good score. Patrick I am a toolmaker and we use d2 for making progressive dies. Normally we are talking cross sections of no more than 2 inches. We just put in in a stainless bag (to prevent scale) and put it in the furnace when the furnace is cold and have it heat it to 1850 F and then hold it at 1 hour per inch of the thinnest cross section. We then remove it from the oven and let it air cool and temper it at 400 F. This usually achieves 55-60 rockwell. I have never had any problems with this steel. Link to post Share on other sites
Ramzi 0 Posted August 29, 2017 Share Posted August 29, 2017 On 1/17/2012 at 7:10 PM, ZebDeming said: Thanks guys! I'm assuming that it's annealed as it looks like it's been saw cut. They really don't know more than that it's D2 steel, it came from a local stamping plant that closed it's doors, they used it for the die's. Will it work well in it's annealed state or should it be heat treated? A file should be able to tell me approximately how hard it is, correct? If it will make a good knife I'll pick up some smaller pieces of it as well. There was all kinds of it there, I'm gonna find out how much it is before I decide on the huge piece, Doug thanks for the dimensions of a block that will work well. Again, thanks for all the help. Zeb Hi Zeb, I know this post is kind of Old, but I was wondering if you can please let me know which local steel supplier you went to to get this piece. I live in Michigan and I am hoping this place is near by for me. Link to post Share on other sites
