melting copper and nickel
ryanwrath
i have been playing with melting copper and nickel, just pennies and nickels(5c piece) but after it cools, if i so much as look at it wrong it breaks like grainy glass into many peices.....the symptoms tell me im overcooking it, but even when i get the metal to just molten, quick stir with a stainless rod, and out, let cool, tap with hammer, shatter....how do i overcome that or is it even possible. thanks.
one thing i forgot: i have a larg cast iron ladle that is my container for the melting material, and my propane forge is the heat.
Edited by ryanwrath
Try covering the melt with charcoal. Your problem is likely oxygen uptake. the charcoal will keep out the O.
I have never tried copper/nickel smelts. I see that the new nickels are copper & nickel.
I'm not sure they would work in a water cast, but maybe. That would help a lot with the oxygen uptake.
Wait, nevermind, new pennies are mostly zinc. That is likely the big problem. And for sure will not water cast. New penniees are 97.5% zinc.
Skip the pennies, add just pure copper. That should help a lot. Still use the charcoal.
1962-1985 pennies make a very nice brass. 95% copper 5% zinc.
Mark Green
(cptn. Mal)
Mark's right, the nickel coin is already a copper/nickel alloy. If you want copper, get some heavy copper wire. You might also consider a carbon or ceramic crucible for melting. That's generally what is recommended for melting and casting metal with a higher melting point. Cast iron ladles are mostly use for lead, pewter, and other white metals.
It was 1982 that pennies went from copper to zinc
1982 pennies can be either zinc OR copper
AHHHHHHH ok ty ty..........i knew there was something VERY wrong with the pennies.......i got seriously bad yellow powder, this really strange white fuzz, all the same crap i get when i am forced to weld already glavanized steel..............no i did not breath it i know better))...........but the 90+zinc .........ok ty now i know
edit:
ty for advice adding charcoal.........i will do that next time, this is not the first time i had brittle metal, i turned a 4x4 angle iron into a V shape, welded square plates on the ends to form a very rude triangluar mold, and melted down a ton of copper pipe into it..............that stuff was very nice copper, at least it burned w/o all the crappy colors from different elements in it...(it was about 70 yrs old)from a demo prodject, and had intended to put accents on a custome stairway i built, but it was SO damn brittle, like glass , just would not work for me, hope the charcoal works, that will be awesome.........ty
gah, re-edit:
what sir mark is a water cast? ty in advance)
Edited by ryanwrath
