Karl B. Andersen 17 Posted November 11, 2012 Share Posted November 11, 2012 It's always been a struggle to properly and evenly heat longer blades with my 12 inch forge. So, I lengthened one. Rather than just go larger in diameter and vastly increase the volume to heat, I used the same 12" body but welded in 6 inch webs to effectively lengthen the heat zone. Now my Bowies and Fighter get heated right. Here's the constructed forge body: And here is the forge AFTER! it has been running at welding temp for 15+ minutes. It's lined with 2" ceramic blanket and heavily coated with Satanite. 1" wool on the floor covered with 4" of clay cat litter to catch flux. 2" wool in the ceiling: Link to post Share on other sites
dan pfanenstiel 1 Posted November 11, 2012 Share Posted November 11, 2012 Hey! Glad to see I'm not the only one doing the "limo stretch" on forges. Mostly a space saver for me, but the forges seem to work well, so no downside. Dan Link to post Share on other sites
Steven Gillespie 0 Posted November 11, 2012 Share Posted November 11, 2012 That's pretty cool, definitely more space saving than a barrell forge. Are you running a single burner? Link to post Share on other sites
MLenaghan 57 Posted November 11, 2012 Share Posted November 11, 2012 Cool forge Karl, glad to see you moved in and got the new shop up and running! wish I could hug my forge like that Link to post Share on other sites
Karl B. Andersen 17 Posted November 11, 2012 Author Share Posted November 11, 2012 Are you running a single burner? Yes - this is the picture of the exact burner I am using in the 12 inch forge. This was in my old shop, and I have shortened it some, but still the same basic assembly. I use it in both forges. Link to post Share on other sites
DJPratt 0 Posted November 12, 2012 Share Posted November 12, 2012 How is your fuel economy? I am liking my T-rex but it dosnt have the raw power my old blown forge had..... but my old forge ate a 40 pound tank in less than 8 hours and i can run for over 24 on my new burner. I am wondering if it was a design flaw on my part.... Thanks! ~~DJ Link to post Share on other sites
Karl B. Andersen 17 Posted November 12, 2012 Author Share Posted November 12, 2012 I really have no idea. I've been running that burner for maybe four years. I use a 100 gallon tank. 1 fill lasts 7-8 months. How is your fuel economy? ~~DJ Link to post Share on other sites
Wayne Suhrbier 0 Posted November 27, 2012 Share Posted November 27, 2012 The fuel consumption of a burner is only dependent on how high you run it. It is easier to run a forced air burner higher, but they can be set very low also. Wayne Suhrbier Link to post Share on other sites
Steven Gillespie 0 Posted November 27, 2012 Share Posted November 27, 2012 They also tend to run hotter then a venturi, my little burner has been running off a 100lb tankbfor a few months so far, I like mine, but it sound like a jet turbine. My forge will burn you if you touch it, and its got the same amount of lining on it as yours, 2" of kaowool, and about 7.5 lbs of satanite and bubble alumina. I used 2.5 lbs of the bubble alumina on the floor. And 5 lbs of satanite on the body. What did you use for your forge shell? Link to post Share on other sites
