Doug Ward 1 Posted December 10, 2012 Share Posted December 10, 2012 I found some belts on Craigslist the other say, 2X48 Zirc 100-120. Paid $1 a pop and brought them home. Gonna have to re-rig the grinder to use them so I tossed one on and started calculating the tensioner. WTF ? The belts are wider then the contact wheel by about 3/8". 2 3/8 ??? You guys think this will be a problem running ? I know I can trim them but sometimes they fray when you do that.This thing is screaming at 3650. What do you guys think ? Run'em,no problem?Trim? Cut in pieces for hand work ? Buy a pet rock and forget knives ? Thanks Link to post Share on other sites
DJPratt 0 Posted December 10, 2012 Share Posted December 10, 2012 I run belts over the edge of my contact wheel all the time. As long as you are careful not to dig that part of the belt in to your piece you should be fine i would think. On the other hand if you lean to much to that side you might cause some deep belt gouges in the piece. ~~DJ Link to post Share on other sites
Doug Lester 280 Posted December 10, 2012 Share Posted December 10, 2012 Do you have a garbage can? Those belts aren't going to last you long enough to be worth the headache of trying to figure out how to used them. I'd just toss them and chalk it up to experience. Doug Link to post Share on other sites
Steven Gillespie 0 Posted December 10, 2012 Share Posted December 10, 2012 Use them for hogging off forge scale. If it get worn out, then they're not $5 each, so its okay to just toss out, or even chop some for sanding blades. Link to post Share on other sites
Doug Ward 1 Posted December 10, 2012 Author Share Posted December 10, 2012 I'll probably just burn them up removing paint, rust and maybe sharpening shovels or machetes for my gardeners.....all while wearing a full face helmet, some Carhartts and a leather jacket and welding gloves.I'm still trying to figure out where a 2 13/32 belt came from ? Some Nicaraguan probably lost his tape measure and winged it during the manufacturing process.I suppose I should whack one and check the length before I proceed. Link to post Share on other sites
