Jokke Posted December 25, 2012 Share Posted December 25, 2012 (edited) Hi, an old friend asked, if I could make a new blade for his old pocket knife with a worndown blade, it needed some restoration, so I got an idea, and since I had fun making it, I took some pics to show them here this is how it came to me: so I found a piece of damasc for it. It is damascus with 500 layers, made from 1.2510 and 75Ni8 by my friend Micha Schick. I cut out a piece and started with shaping the blade. I used files and worked slowly, which was easy since the damasc was very soft super annealed, quite astonishing for me, since I normally hotwork the steel I use, nearly to endform. It was easier than I first thought... My first pocket knife blade ever... so I kept on filing with different files to get the blade right so it took on the right dimensions and here you can see how worndown the old blade was (in my eyes no wonder, because of the steel, stainless, a bit too soft to hold a good edge long had to see to it that the thickness was right,too Edited December 26, 2012 by Jokke Jokke Link to comment Share on other sites More sharing options...
Jokke Posted December 25, 2012 Author Share Posted December 25, 2012 (edited) So it took some evenings, since I worked rather slowly, but then the blade was ready for hardening, this is how it come out of 830°C and into lukewarm oil: and the parts to be put back together I wondered if I did everything right, you can see that the main pin was all that needed to be removed to get the old blade out and the new one in. You need to take a good look, to see from which side the pin is more narrow and then to slowly force it out. Back into the holes carefully the same way back... so I tried the fittings: needed some adjustments and more filing, which was quite hard on the hardened blade and the steelspring on the back Edited December 26, 2012 by Jokke Jokke Link to comment Share on other sites More sharing options...
Jokke Posted December 25, 2012 Author Share Posted December 25, 2012 (edited) I sharpened the blade on a belgian waterstone, gave it a shaving sharp edge, the steel is about 60 -61 HRC after an hour in the oven with 170°C had to see to it, that is was tight and smooth, too there is no glue on the brass fittings, normally you would simply use a small hammer to flatten the pin on both ends. That would give the strength to hold it all together tight if you wonder about the loose brass fittings, Axel will want to fix them by himself I did not want to hammer on the sides to fasten the bronze pin so this is it now so I keep it in my pocket for a while, bevore I send it back to Axel, just for the feeling of it it feels good, I must admit and it is fun to see it done by the way, it is an old piece from G.Grafrath, Solingen Germany hope ye had fun looking best seasons greetings from Germany! Edited December 26, 2012 by Jokke Jokke Link to comment Share on other sites More sharing options...
Mike T Smith Posted December 25, 2012 Share Posted December 25, 2012 Great work and quite an improvement on that knife Link to comment Share on other sites More sharing options...
Mark Green Posted December 25, 2012 Share Posted December 25, 2012 Awesome!!! Mark Green I have a way? Is that better then a plan? (cptn. Mal) Link to comment Share on other sites More sharing options...
Troy Christianson Posted December 25, 2012 Share Posted December 25, 2012 Frohe Weihnachten! Vielen Dank für den Austausch eine sehr interessante Taschenmesser Restaurierung. Ich hoffe, Ihnen und den Ihrigen haben einen fröhlichen Urlaub. Troy Allen Christianson is NOT a "Licensed Bladesmith" so you may treat his posts with the contempt they deserve. Link to comment Share on other sites More sharing options...
Jokke Posted December 26, 2012 Author Share Posted December 26, 2012 Vielen Dank, Troy and Mike and Mark Frohe Weihnachten und ein Gutes Neues Jahr, best seasons greetings from over here and best whishes for you and your families! Jokke Link to comment Share on other sites More sharing options...
