The Catalan forge... "Farga Catalana"
miquel
  • Replies 138
  • Created
  • Last Reply
Top Posters In This Topic
Miquel,
That is quite amazing! I cannot agree more with your statement " Any excuse to learn something new and experiment with something interesting". That path may be a little slower, but much more valuable.
Jan
To tell you the truth, we made many mistakes but we learned a great deal from them.
miquel.
Metal molds, in my limited expirence, have been tricky. I have seen some folk smoke the mold to leave a thin layer of carbon, but they were on thicker steel molds and not sheet metal. Maybe even a thin painting of ceramic slip may help?
Zeb
Fascinating. Truly a pity that there's so much to learn and only so much time on this earth to learn it!
Can't wait to see how this pans out. I would never have guessed that the square tube was better, and not just an example of artistic license or easier manufacturing with the technology of the day.
I'm thinking that sooting the inside of the mold might help prevent sticking of the copper. What about using a wax with a lot of coal dust mixed in?
Or, pour a thick flat sheet of copper and then work it around a mandrel to make a hollow cone......
When reason fails...
I just thought I'd add a quick comment about moisture and iron oxides. Ancient Greek potters used an oxidation/reduction/oxidation firing to get their black and red ware. The reducing atmosphere was produced by closing the flues and piling in green wood. The wood not only burned incompletely, but let vast quantities of moisture into the kiln which causes a reaction turning FeO to Fe3O4.
Thank you for your comments. We can talk about this later after we present the final results.
miquel.
1
----- ZebDeming
Posted Yesterday, 08:23 PM
Zeb
--------='VaughnT' date='09 January 2013 - 04:54
All those precautions are good, but the problem with the copper soldering to the metal is not the only trouble of using metal molds that we encountered.
miquel.
Edited by miquel
For the next attempt we use a sand mold with an iron core.
We prepared the sand for the mold using silica sand, bentonite clay 8%. We mixed everything dry then added water with constant agitation to promote good mixing and being careful to add just the minimum amount of water that would produce a mixture that could be compacted easily by hand.
We made a container out of wood in two halves. The dimensions of the tuyere were 2.75" inches diameter at one end and 1.75" at the other with a total length of 20".
We dusted the tuyere positive with talc powder to keep the sand from sticking to it when creating the negative.
100_8543.JPG?psid=1
miquel.
Edited by miquel
Due to the stress during the contraction of the copper upon cooling over an incompressible iron core, the copper shattered in several places.
100_8530.JPG?psid=1
miquel.
Edited by miquel
Upon reaching this point we came to the realization that we only had one other option which was to use a core made of silica sand. We were advised to use a mix of silica and sodium silicate hardened using CO2. It sounded complicated to build but after a few tests we went for it.
We made a negative mold of the iron core using plaster.
We used it to measure how much silica sand we needed for the core.
100_8536.JPG?psid=1
Edited by miquel
We weighted the sand calculating the addition of 7% of sodium silicate and mixed those two components in a bag.
100_8537.JPG?psid=1
miquel.
Edited by miquel
Then we packed the mix in each half of the plaster mold.
100_8538.JPG?psid=1
100_8540.JPG?psid=1
100_8541.JPG?psid=1
You can't see it in the pictures but each half is reinforced with a wire from one end to the other. We also set a string through the center when packing the sand. This string will be removed later and we will use the tunnel left by the string to flow CO2 to harden the mix.
miquel.
Edited by miquel
Then we joined the two halves together and gently tapped on then to promote the joining of the two halves. Insert them in a plastic bag and pump CO2 inside, wait 15 minutes then the mold can be taken apart carefully.
100_8548.JPG?psid=1
miquel.
We were very surprised to see how solid the core was. We also considered using a vertical mold but we were advised by experts to use a horizontal one. The molten metal flows more evenly that way and the gases exit the mold with more ease.
miquel.
