Posted
It sounds like you are starting to burn your steel.  Maybe you might want to cut things back just a tad and see how it still welds.  My experience, little that it is, is that forge welding will eat up your gas.
Posted
I'd dial back the air, then the fuel.  Sparks mean too much air.  And yeah, maybe a smaller burner tube too.  350ci isn't that big.  That said, two solid days of welding will drink a full 100lb tank.
Posted
Thanks for the quick suggestions.
The sparks came after the third fold and the weld wasn't really taking, so I went a little overboard with it. But I'll try backing off a little bit the next time I'm at it, and if it still seems high I'll probably give a smaller tube a shot.
Posted
Simple equation. More heat takes more fuel + getting hot faster takes more fuel = running hotter and faster takes more fuel.
But, what's already been said, if you are throwing sparks you are running too hot with too much air.
This actually points out something, as a venturi guy, that I believe. A blown burner is not automatically more fuel efficient than a venturi. There are so many variables that it would take an expensive testing lab and a lot of time testing both designs until they were both optimized, in forges optimized for each type in order to find ANY significant difference. Without that testing IMO it is a matter of initial building issues, tuning, and personal preference, rather than any empirical choice.  With the variables involved in all of our various forges it's more a matter of what the individual THINKS they're getting and their motives for the choice. If it keeps people forging then it's all good anyway.
  • 7 months later...
Posted
I have had a forge of the same design for several years now. I used to be able to get clean welds with it but I cannot anymore due to an oxidizing atmosphere. I've re-lined it with new kaowool and castable  refractory. Idk what the deal is. Does anyone know how to prevent an oxidizing atmosphere?
Thanks, Chris
Rich-en your mixture, when it's oxidizing there isn't enough fuel in the mix for a neutral
environment...........feed it some more beans, or cut some air flow.................;)
Edited by Clifford Brewer
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
Posted
Thanks Clifford, I'll give it a whirl.
Posted
Make sure you have a decent amount of dragon breath from the mouth of the forge. This is a good indicator of a neutral or slightly reducing atmosphere. And if your running low on fuel I wouldn't even attempt a weld. But too much flame from The mouth of the forge and your just dumping carbon monoxide in the room.
  • 2 years later...
Posted
This might be a dumb question… and I apologize if it is.
This is a burner I bought a while back when I was just using a simple brick forge for heat treat. Currently building a new forge with a blown burner.
If I were to use this line and regulator for the propane tank attachment, would I be able to attach that to the needle valve? Or maybe I could somehow use that part I’ve circled in red as that’s what the hose connects to?
Sorry, I don’t know anything about all of the fittings and connections being used.
Having spent FAR too much time replacing all of the fittings on my copies of that circled item... Learn From My Fail :)
That is a 3/8" 90 degree male NPT to 3/8" male flare elbow.
NPT is what most of us would consider a "normal" pipe - slightly tapered so it gets tighter as you go, but otherwise looks straight.
Flare is that weird beveled thing.
I would strongly recommend you get a parts list from someone who's figured out the easier way to do it or you run a high risk of spending a lot more money than you intended and end up with a bucket of oddly shaped brass parts that you will very likely never use again.  Wayne keeps nudging you for a reason ;) If I'd have known about his site, I would have donated less money to various suppliers of brass parts.
But if you want a steampunk forge, you can adapt that thing you circled in red - there is a certain fun look to what you get at the end. It did take a lot of soapy water and re-tightening to get it right, though. (and one stupid valve put the wrong way by mistake *sigh*)
Edited by Ted Stocksdale
Posted
Thanks for the heads up Ted! I appreciate you clearing that up for me.
After looking over Wayne’s site, I’m considering giving the ribbon burner a go! And I’ll source what parts I can from him.
Posted
Ted's right, that's a flare fitting, and to use one properly you need a flare tool for copper line.
That said, your current regulator and hose should screw right into your needle valve.  If said needle valve is what connects the gas line to the burner tube, you're now good to go.  Blown burners are great because there's no need for tiny orifices, aligning gas jets, and so on. Just dump gas into the tube and away you go! Most folks just use 1/4" to 1/8" copper refrigeration or brake line with a compression fitting like on a refrigerator icemaker line.  You will also want a 1/4-turn WOG-rated ball valve between the forge and the regulator.  This is a safety thing, since if something goes wrong you just slap the handle closed and boom!  No boom. ;)
Posted
Thanks guys, I was trying to come up with a way of saying what you just said, except I would have used a bunch more words and still been not as clear.
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
Thanks Alan! I appreciate the tip on the ball valve. I’m overly cautious with all of this because I have a somewhat irrational fear of explosions. Not quite a phobia.. but enough to make me cautious and somewhat nervous of building my own burner. Anyway, I appreciate any additional safety tips.
The more I read, the more I’m starting to appreciate the simplicity of a blown burner. It makes me feel more confident building one.
You're taking pressurized flammable gas, lighting it on fire, and then supercharging it.  No shame in being careful.  It's even ok to be slightly afraid (aka terrified) the first couple times you light it up!
Edited by Alex Middleton
  • Haha 2
Posted
Actually, it's when you stop being slightly intimidated to light it that you should start to worry.
-Brian
  • 5 months later...
Posted
Just converted from a venturi to blown and woah buddy, it made a huge difference in the temp I'm getting.  I was able to get steal up to melting with ease.  (May or may not have been intentional.:unsure:)  Looks like I'll be relining the forge this weekend.
Posted
I'm glade that worked out for you.  Post a picture of your setup, please, as a help to the next guy.
g
I said that.
Grant Sarver
  • 4 weeks later...
Posted
Here's what the set-up looks like.  I used a blower that I got from a grooming salon that went out of business and did things a little different due to power access.
My burners started life as Zoeller sidearms and I just removed the mig tips and plumbed the air right into them.  There's an air dump just before where the line splits that has an added boon of giving me a great place to stand when I get a little too warm.
IMG_20211023_083744232.jpgspan widgepan widget
Posted
I have now used my new forge enough to be able to calculate, we have tanks which are 33 kg or in your units round 72 pounds.  That actually was enough for two solid days of welding or in my calculations of 15 hours where I didnt attempted to spare fuel.  I have put a choke into the gas line, drilled 2,5 mm.  My thinking = original double T rex forge had injectors from 1 mm mig tips.  2 holes 1 mm diameter are about 6X less than  one 2,5 mm.  When I was welding I was cranking them 1,5 bar or almost 2 bars. Now I register about 0,4-0,5 bar on my ventil against that choke, that is 6Xless through area six times as big when I run the forge white hot. It makes it easy to set up the gas, when I actually have readable pressure.  However, this forge can litrally melt the billet and ruin it, the old one was always little too cold, because the jet flames were actually ventilating the heat out of the oven.
  • 2 years later...
Posted
After nearly 20 years of use, my gas forge was getting tired and was having trouble getting to welding temps so a rebuild was in order.  Having a small shop, I also decided that I would move the plumbing/blower assembly to the top of the forge to reduce the footprint a bit so I broke the welds from the old compressor tank to the angle iron support frame and rotated 90 degrees .  The forge was built using plans I got from William Fiorini and has worked well until the rebuild/reconfiguration and I wonder what change have caused the problem.  The ceramic blanket came from Amazon and is nearly twice as thick as what was in there so I figured that is good.  The gas supply is through 1/4" copper and I probably added 2 or 3 feet of it during the rebuild due to "improved" configuration since before the regulator was was hanging in the breeze and supported only by the copper tube.  The forge was lit after allowing the refractory sufficient time to cure and all seemed good until I powered up the fan.  No more distinctive roar like I was used to!  I fiddled with the line gas pressure and the needle valve to see if I could get the roar back but no luck.  Then I tried removing the duct tape from the fan inlet (I had to tape it all closed in the previous configuration to get everything to work) and opened the inlet all the way which blew the fire out.  I lit the forge again and did some more fiddling but no joy.  In my haste to get it going again I melted the power cord to the fan which tripped the circuit breaker so I shut it all down to fix that.  After a bit I noticed the fan smoking and realized that with the plumbing coming out through top it is a natural chimney so that is where the heat goes when the fan is not running and the residual heat finds its way out.
I'm wondering if I need to change to 3/8" copper tube and will definitely relocate the fan.  The gas inlet which is cast refractory into the forge body also changed and could be the problem but I don't think so.  Do you folks have any ideas what the problem may be?
Posted
So your forge will run without the fan?  If I don't have the fan running mine just has a soft, billowy flame out the door with no usable heat being produced.
What is the pressure from the tank?  You should not need more than the 1/4" lines that you're using (since they worked before).
Have you added anything to the setup in the move, or did you just rotate the whole thing 90 degrees?
First I would check the needle valve and the shutoff valve and the rest of that to make sure that you did not introduce something that is blocking the gas.
Then I would check the gas inlet to make sure that all of that is open and clear.
The more I think about it, the more I think it's a gas delivery issue.  A setup like this should run on 1-3 psi before the needle valve and around .5-1 psi being injected into the forge.  When you opened up the air, it blew the fire out, so your air delivery is fine (or will be when you've replaced the fan)
I would prefer to have the pressure meter on the tank side of the gas line, that way you would know what your tank pressure is.  If you know the tank pressure, you can infer the injector pressure.
A lot of what I wrote is me thinking out loud (so to speak).  I think you have plenty of air (or did), so the issue has to be on the gas side.  I would check to make sure that you didn't obstruct the line somewhere.  I'm a little confused that you seem to be saying that the forge runs without the fan.  That doesn't make sense to me, but perhaps I misread something.  In the future I would get in the habit of either leaving the fan running for a few hours after a session, or putting a shutoff valve between the fan and the forge and closing that at the end of the day.  If you put a gate valve in, you could dispense with the duct tape,
I'm not wild about all of the pieces that make up your gas system, but if it worked before, there is not reason that it shouldn't work now.
Let us know how you get on, I'm a little stumped right now.
I said that.
Grant Sarver
Posted
Thanks for the reply and appreciate your stream of consciousness comments!
Things that changed;
Rotation of the forge body 90 degrees
New ceramic blanket with rigidizer
cast refractory/stainless steel gas nozzle (apprx the same size as before)
cast refractory floor which replaced the old busted up one
added length maybe 2' or more of 1/4" copper tube due to moving the gas regulator to the front
shortened the fan/air pipe
Originally, I thought followed the plans that I had and also relied on my memory from using forges at Haystack and Peters Valley. I was surprised about the fan thing myself.  Before the rebuild reconfiguration with just the gas running, there is good swirling flame but certainly not enough to heat anything to forging temp.  Turn the fan on and the forge would begin to roar and would get hot enough to make it uncomfortable to look at the inside of the forge.  I had put a sheet metal cover over the fan inlet so that I could control the air intake but found that I  had to cover it all with tape to get the most heat but still needed the fan running to get good heat.  Didn't make any sense to me but that is what worked before my rebuild.
Presently, the gas bottles are tied together by a manifold which the goes to the regulator which can be seen below the small shelf at the front.  The gas out or line then goes to the collection of fittings at the top which includes a needle valve.  Somewhere in there is an orifice or jet.  The hose clamps cover an air inlet thing and can be adjusted to control the air.  I do not believe that has been touched since I built the forge some 20 years ago until yesterday when I was moving/adjusting things around to see if I could get it burning right.
Tomorrow I'm going to disassemble all the fittings on top to be sure that there are no bits of teflon tape or other junk in there that might obstruct gas flow.  I also need to make something to hold the fan power cord out of the heat.
I did dig out the plans and have to assume there are pages missing!    Only bits and pieces look like what I built.
More tomorrow.
Posted
For a fan driven system you don't need a jet, volume not pressure is the most important thing.  It may be that you ended up with some sort of hybrid, semi venturi effect.  If it's not too much trouble, I would pull the jet and see if that doesn't fix the issue.
My setup is just the line from the manifold (I run 3 different forges off a single manifold) to a needle valve, to the forge.  I open the valve from the manifold, turn the fan on, hold a torch in front of the door, and crack the needle valve.  When I shut down I close the valve to the manifold, let the fire go out, close the needle valve and shut down the fan.
G
I said that.
Grant Sarver
