Posted
I took all the plumbing apart to make sure there were no blockages and did find the jet was partially blocked with something but don't know if it happened during the disassembly work.  The jet is the brass part with the hose clamp on it and from the looks of it, it was something I made - its certainly not an off the shelf item.  Then I cut the welded steel pipe parts off and am adding more length to the blower which will hang off the side so that the power cord will not be near the heat.   Then my well pump crapped out (again) so my efforts are now directed to domestic issues.  Seems everything breaks at once.
Posted
I'm betting that the crudded up jet is the issue.  As I said, you don't need it.
You have to have water, no question.
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
So, I added about 6-7" of blower pipe, a gate vale and hung the blower over the side.  Also added a variac to the blower motor and put it all back together with the jet/orifice since I knew that it worked before.  I think it is good to go now but have not tried to weld anything in it yet and the cause was most likely the bit of crud in the jet.
Thanks for your comments and support!
Posted
Happy to help
g
I said that.
Grant Sarver
  • 2 years later...
Posted
Thread revival!
I have had it with the cheap venturi burners, taking LONG time to heat to welding temperature (if at all) and being a bit inflexible regarding air mix. And the forge Satanite is spalled which needs some work, anyway. Thus I am rebuilding the forge with a blown burner according to the recipe here.
I will try a cheap variable speed 12V blower first with an alleged capacity of 100 cfm (may be a very optimistic spec, though). If insufficient, I will switch to a typical 120V blower.
Given my setup, I would really like to install the blower below the gas mixing fitting (much cleaner install). I understand the risk of gas seeping into the blower feed tube and housing but I am planning to install an air flow sensor from a pool heater and a propane solenoid so that gas can only be injected when the blower fan makes pressure in the manifold.
Sounds reasonable? Or still risky?
Posted
No, it's probably fine.  In fact, once you have it together you should post the parts list so that others can try it as well.   My builds have all been low tech, 'cause I'm pretty low tech.  But that doesn't mean that the rest of you need to be.
g
I said that.
Grant Sarver
Posted
@Gert Burkhardt I don't want to take anything away from Geoff's excellent thread here helping people get blown burners up and going.  This thread has been a mainstay for years.
Given your appetite for some complexity, have you considered a ribbon burner?  They are more effort to fabricate, but have a more even heat distribution and are quieter to operate.
-Brian
Posted
One thing I'll add that I haven't seen in this thread yet (at least after a relatively quick scan of the pages) is that when using an electric fan for air supply in the forge, it's a good idea to install a NC (normally closed) solenoid valve in the propane line in case of a power loss to the blower.
One should keep in mind,
we are all both the blacksmith
and iron in the fire...
as always
peace and love
billyO
On 8/4/2026 at 6:28 AM, billyO said:
.......it's a good idea to install a NC (normally closed) solenoid valve in the propane line in case of a power loss to the blower.
This is how the system works. In case of a 120V power loss (or if it gets unplugged), the solenoid also loses power and the gas is shut off immediately. The air flow sensor is rather intended to monitor if the blower is actually working, power or not. Such problem can happen due to bearing failure, burnout or similar. I have now tried that and it works, but only when the blower is running at full speed. When running slower, the air pressure in the manifold is not sufficient to activate the sensor, which kind of defeats the purpose of the blower speed control. Got to work on that...
I have now put it all together, and in principle it does work. But the flame is a bit sputtering and I would like to get an expert opinion in that is all normal or if changes are needed. e.g. if there is enough air flow to start with (or too much), if the feeder nozzle to the forge is too big or whatever.
When the needle valve is opened too far, there is a mighty dragon breath and very unstable flame. When closed more to get a more stable flame it is quite blue and I would suspect rather oxidizing (see video clip further down).
Edited by Gert Burkhardt
Posted
I would pull the solenoid and the the air flow sensor and try to run it that way.    That should tell you if those components are causing issues.
What is the CFM of the fan?  It does seem as if the fan might be an issue.  Try blocking the intake of the fan with your hand and see if your burn improves.  I've got a flap on my fan (the steel case lets me use a sheet of magnetic sign material) and I block all but a sliver of the intake.
I will try to get a video of my forge running.
I approve of the safety improvements, but except for the one issue, I've never had the power fail while forging.  I have accidentally shut the fan off once or twice, but that is operator failure.  Keeping the fan low makes for a cleaner installation, but I'm not sure the additional complexity is warranted.  OTOH, I won't tell you not to be safe, you have to choose.
I said that.
Grant Sarver
I did remove the air flow sensor since it is useless for the variable speed blower. While every gas water heater and pool heater has one, their blowers run a constant speed and they are designed for that pressure level.
But I did keep the solenoid so that the gas is turned off instantly when the fan power is turned off. Just a matter of convenience and one less thing to remember when turning off the system.
Without that sensor I could reduce the blower speed and it appears that the air flow at full speed was just too much. The flame becomes more stable and the forge heats up all around more evenly at medium to low speed (no idea how many CFM that is). At full air speed, the incoming gas flow even created a dark "cold spot" on the forge floor.
Maybe next few days I will try to forge a piece and see how that compares to the venturi setup.
Posted
On 8/4/2026 at 5:45 AM, Brian Dougherty said:
@Gert Burkhardt ...have you considered a ribbon burner?  They are more effort to fabricate, but have a more even heat distribution and are quieter to operate.
I read about making one but don't tempt me!
I guess that would probably mean a new and optimized forge housing. Well, maybe next year...
Posted
I agree with this. To me, the sputtering means the velocity of the air from the fan is higher than the flame face at the burner can keep up with, so it is burning, then blowing off the end of the burner, then re-igniting at the end of the burner, then blowing off, (repeat ad infinitum). It's too early to judge if it is too rich or too lean, because you can see it in the video changing from rich to lean between sputters.
So, lower fan speed = more time for fuel and air mixing (propane really needs to be coaxed to mix with air thoroughly) and a velocity of fuel/air mix that matches the velocity of the flame face at the burner.
Once you've got that sorted you can start to adjust the amount of air travelling at that speed to get a rich, lean, or just right mix.
Cheers,
Jono.
Posted
I just had another look at the layout of your build. I haven't built a blown burner myself, so take this with a grain of salt, but to promote better fuel mixing and stable flame at lower air velocities you could try switching where your air and gas come in. If the blower was first, and the gas joined the airstream at 90 degrees, then the whole mix went around the 90-degree elbow, you would get more turbulence and thus more mixing.
I did see in your earlier post that you wanted it in the order you have now, but if just varying the fan speed isn't enough, it could be an appropriate next step?
Cheers,
Jono.
Posted
1 hour ago, Jono Pukallus said:
.....To me, the sputtering means the velocity of the air from the fan is higher than the flame face at the burner can keep up with, so it is burning, then blowing off the end of the burner, then re-igniting at the end of the burner, then blowing off....
I think you hit the point of the matter. When I turned down the fan speed (see my previous post) the situation improved a lot.
I just did not consider that the cheap 12V fan might move the air/gas mix faster than the flame can consume when blasted from a 1" pipe. But fortunately I can turn it down to reasonable speed. I am looking forward to use this thing.
Posted
Nice!
Sorry, I read the earlier posts more thoroughly and missed that in your last one! 😄
Geoff's other suggestion still stands for finer adjustments. If control of fan speed makes it more reliable and stable, you can still adjust how much air the fan blows at said speed to make it richer or leaner.
Posted
I think I got it to work now. At least better than the venturi style burner(s) I had before. Based on my original setup, I used the front tap of the forge vessel only and plugged the other two taps.
This tap happens to be aimed sideways for some flame swirl but also rearward to encourage the exhaust to exit to the rear door opening. So that would be the dragon fart, I guess. As you can see from the video below, that seems to work but is obviously also dependent on how far the rear and front doors are opened.
