jonathan creason Posted February 18, 2013 Share Posted February 18, 2013 This one is made out of 1084 steel, edge quenched. It's 9.25" OAL, with 4.5" of sharp. The scales are walnut, with copper pins. I'd love any critiques or criticisms before I finish it out. Link to comment Share on other sites More sharing options...
Troy Christianson Posted February 18, 2013 Share Posted February 18, 2013 (edited) I'd give you the old schtick "It's hideous,send it to me for proper disposal." But that is getting old. It is an awesome job! The edge quench really does it for me. I can't express it better but it adds "ZING!" Makes a good knife Great! p.s. what did you etch it with to bring out the contrast? Edited February 18, 2013 by Troy Christianson Troy Allen Christianson is NOT a "Licensed Bladesmith" so you may treat his posts with the contempt they deserve. Link to comment Share on other sites More sharing options...
Geoff Keyes Posted February 18, 2013 Share Posted February 18, 2013 In general I like it. The shape is a good one and the edge quench is cool. On he bad side, the plunge cut is a little wonky (OTOH, I've done worse) and the tearout around the pin holes is unfortunate. There are a number of ways to avoid it. One way is to under size the hole, that way you can drill the proper sized hole from the outside. Another way is to leave yourself enough material so that you can grind past the tearout. Or you could take the handle slabs as a single piece, clamp them to the tang and drill the holes. Now cut the block into slabs and put the tearout on the inside. Some times a piece of masking tape will minimize the problem, or tape a thin piece of sacrificial material to the slab and then drill. The thin piece will support the handle slab and any tearout will happen in the shim. There must be other ways, too. Thanks for showing, Geoff "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
jonathan creason Posted February 18, 2013 Author Share Posted February 18, 2013 I appreciate it, guys. I think that I may have enough material left to go back and hog around the pins some more and try to get below the tear outs. I generally try to drill with the inside of the scales on the table of my drill press, but just had a brain fart on this one. I think the plunges can mostly be attributed to my craftsman grinder. I think I'll have it tracking nice and even and then, "Bam" it's wondering all over the place. I bought the steel to start on my NWG Friday, so hopefully that'll be taken care of soon. Troy, nothing special on the etch. I soaked it for a couple of hours in vigaroon, taking it out a few times to wipe off the oxides. Then I gave it a couple of quick dips in dilute ferric. Link to comment Share on other sites More sharing options...
Steven Gillespie Posted February 18, 2013 Share Posted February 18, 2013 Clean up the plunge cuts with a file? I keep a cheap file on hand I ground the teeth of on flat and one side. It only cuts the plunge that way, and the grind when I want to clean it up. I use a craftsman as well, but I made a plunge guide to stop the plunge from doing that. Link to comment Share on other sites More sharing options...
Richard van Dijk Posted February 18, 2013 Share Posted February 18, 2013 (edited) Have you tried to soak the handle in a mixture of boiled linseed oil and turpentine (I use gum turpentine available in art shops) it will bring the walnut alive. I pump a vacuum while the wood is submerged but if you leave it for 2 or 3 days in the oil you get a simular result. Richard Edited February 18, 2013 by Richard van Dijk Richard van Dijk My link Link to comment Share on other sites More sharing options...
jonathan creason Posted February 19, 2013 Author Share Posted February 19, 2013 I haven't tried that, Richard. Thanks for the tip, I've got tons of walnut leftover from dad's cabin project so I'll be sure to give it a try soon. Link to comment Share on other sites More sharing options...
jonathan creason Posted February 22, 2013 Author Share Posted February 22, 2013 Finally finished. The sheath is deer rawhide over veggie tanned leather, with some buckskin and snakeskin added for fun. Link to comment Share on other sites More sharing options...
sandpile Posted February 23, 2013 Share Posted February 23, 2013 Jonathan Nice shape, good quench line and etch I glue one slab, drill that side then glue the other and drill it. This leaves plenty of wood to grind past your 'Oops' with the hastily drilled holes.. Plunge cut guard is one answer. The knife and sheath came out good. Chuck Link to comment Share on other sites More sharing options...
JasperDielemans Posted February 26, 2013 Share Posted February 26, 2013 nice knife! I like the plainless of it http://www.jrd-artistry.deviantart.com Link to comment Share on other sites More sharing options...
jonathan creason Posted February 26, 2013 Author Share Posted February 26, 2013 Thanks gentlemen, much appreciated. Link to comment Share on other sites More sharing options...
