Podmajersky Posted April 18, 2013 Posted April 18, 2013 Alrighty, as promised a while ago, here is a tutorial for how I do color case hardening. First off just to get it out of the way.. remember hot stuff... flying embers.. steam... use this stuff as needed:First off we need something to Color Case Harden. In this case I'll be treating a batch of 6 Thor's hammers ground out of 1018. Yes I know there are 7 in that bin but the one down in the lower corner is Wrought Iron that is going to get etched instead. A note on surface finish; 320 - 400 grit or trizac a45 seems to be about right. You don't want it too shiny to start with. I haven't done a lot of experimenting with the level of finish as I have been really happy with the results I get and all my research suggests this is the finish level to use. Also the pieces must be oxide free, clean and degreased. I handle them with nitrile gloves and wipe them down with acetone. A good soap and water wash with hot water and drying also works.Now we need a retort to put them in. Here is what I use.I welded it up out of pipe and plate and made sure to leak test it. The criteria are that it be air tight able to withstand 1400 degrees F and allow you to open it easily while hot. Since I made this out of pipe it went ovoid while welding so the lid only slips on and off easily in one orientation which can be a pain but it hasn't caused me too much grief yet. Next time I might use square tube if I can find appropriate sizes, but I had the pipe and plate sitting around. Air tight is important as you don't want the charcoal burning while it sits in the Kiln. Charcoal, the all important carbon source We want a 50/50 mix by volume of Bone charcoal and Hardwood charcoal.For the bone charcoal just buy it from Brownell's. I tried cooking my own out of bone meal once, dang what a stench. I think it is easier just getting the bucket of it shipped in. I think this bucket will probably last me quite a few years.For the hardwood Charcoal I just use the natural lump charcoal I find at the home improvement store. You will also notice in the photo an old hand crank grinder. I use this to grind up the hardwood charcoal, which is then sifted through window screen to remove the fines. We DO NOT want fines in the retort for reasons I'll explain later. I get about 50% fines 50% usable small bits from the grinder with the medium plate on it. (I'm setting the fines aside for experiments with homemade crucibles for Wootz which I hope to start later this summer).Mix the 2 together:Now to pack the retort. You want about a half of an inch between the pieces and the wall/top/bottom and each other. Also thin items, long items or things that might distort when quenched need to be attached/wired to an armature or otherwise constrained. Once everything is arranged and in the retort, fill it to the top and pack it down. I use the lid to smush the last bit in. You cannot have any airspace in the top of the retort. If you need to take up extra space use the cheap wood charcoal just make sure you have a half an inch of the good mix over the pieces.Set the retort aside at this point and get the quench set up. the important things here are COLD AERATED water and some way to catch the pieces and keep them off the bottom of the tank. For the tank I use a cat litter bucket because I have a bunch sitting around. I also happened to have a bicycle basket sitting around that wedges perfectly into the bucket with the bottom about half way down.We also need a way to aerate the water. I found a 5 inch round air-stone at the pest store in the aquarium department. I added a length of hose, a ball valve and a quick connect fitting. I also needed to zip tie it to a bar of metal to keep it at the bottom of the bucket.Fill the bucket with water. You want enough water so that your basket has enough room for the parts and a decent amount of water but probably not so much that when the air is turned on it splooshes all over the place. I use about this much:Earlier I said the water needed to be cold. In the winter the water out of the tap here is about 55 degrees F. This is what I generally aim for although a few degrees warmer probably won't make too much difference and colder is fine. If your water is above 60 I'd say put some ice in it to cool it down. Cold water holds more air. At this point the basket is put in the bucket, the air-stone hooked up to my 30gal compressor, the regulator set to 30 psi and the ball valve cracked open till I get what I call a medium dome in the water surface. I don't like so much air that the dome is moving about and spitting water out, and since we are tying to get as much air in the water as possible I don't want the dome too low. This is what it generally looks like:At this point I put the retort into the cold Kiln and input the following program into the digital controller:Number of steps: 1Ramp Rate: fullSet Temp: 1400 FHold time: 1hr 35 minAnd hit start.You could probably use a gas kiln the main requirements are that it heat well and be able to hold temperature without too much fluctuation.While it cooks let me take a minute to talk about what might be different about how I do it from what some other sources may list. I start from a cold kiln, it takes my kiln about 30 min to get up to 1400 F. I do this so that I'm certain I get an even soak on everything for the duration of the hour and a half hold time. I run my program 5 min beyond where I pull things out I feel it helps balance out the thermal shock of opening the door and pulling out the retort/steel/whatever. I don't have evidence one way or the other it is just what I do. Yes it means the coils are live and touching them with metal would be bad. I also start aerating my quench water before I start the kiln. This program takes my kiln about 2 hr 10 min to run currently (as the kiln ages it will take longer naturally). One of the keys to getting good color is lots of dissolved gasses in the water. I'd rather err on the side of running the air too long than not enough. This causes my air compressor to run every 10-15 min for about a minute or so. I'm sure there are other ways to pump air through the stone, but this is what I had when i set up to do this and I'm not going to change too many variable at this point since I really like the results I get. When the hold time is getting near the end I put a fireproof board behind the bucket and I fit a window screen "canopy" over it. I also turn the air up till the dome just starts to move around the surface This is what it looks like:The reason for the canopy and fire proof board is that the air is going to blow some 1400F charcoal (in other words burning embers) up from the bucket. The screen catches most of them. This is also why we separated out the fines from our ground hardwood charcoal. Due to the nature of the next step and the fact I don't have 3 arms and 2 heads I don't have picture for the next little bit.Once the hour and a half soak time is up have your face shield and gloves on. A pair of tongs in hand and a pair of pliers or second pair of tongs at the ready. I also have a safe place near the bucket where I can set the hot retort if needed.Quickly and carefully take the retort out of the kiln, hold it right over the water, remove the lid and dump the contents into the bubble stream from as close as possible to the water's surface. The dump should be a single motion. The idea is to get the parts into the water without them touching the air or losing any heat.Embers will fly, it will be spectacular. At this point I usually put the retort back in the kiln to cool so I won't accidentally touch it and burn myself.Reach into the basket, pull out the now cold parts and hose them off with water displacing oil.Wipe them down. I generally wax them pretty heavily at this point with something like Briwax or RenWax. Here they are, fronts and backs.Hope folks found this useful. -Dietrich 1
Alan Longmire Posted April 18, 2013 Posted April 18, 2013 The air stone is ingenious! Thanks for this, it is on my one-of-these-days list of things to do.
harry_r Posted April 18, 2013 Posted April 18, 2013 very cool, great tutorial. Thanks much. I need to study case hardening more. As an aside, what do you do with these hammers? Are they pendants or such? Regards
Podmajersky Posted April 18, 2013 Author Posted April 18, 2013 Alan, It sat on my to do list for quite a while also. I've always loved the colors and the oganic nature of the patterns. Now if I just stopped adding 2 or 3 new items for each thing I mark off the list. Harry, yes they are pendants. I put a silver or bronze jump ring through them and string them on leather cord like this (quick and dirty cell phone picture):
Howard Clark Posted April 20, 2013 Posted April 20, 2013 Excellent tutorial. Thank you. I have a special project coming up that I need to do this for.
GEzell Posted June 13, 2013 Posted June 13, 2013 Wonderful tutorial, thank you very much. I vote for pinning this topic... George Ezell, bladesmith" How much useful knowledge is lost by the scattered forms in which it is ushered to the world! How many solitary students spend half their lives in making discoveries which had been perfected a century before their time, for want of a condensed exhibition of what is known."Buffonview some of my work RelicForge on facebook
