Gerald Boggs Posted October 8, 2013 Posted October 8, 2013 Alan, this has been both informative and entertaining. Thank you for all the work you've done. A most excellent job :-) <p>Gerald Boggs <a href="http://www.geraldboggs.com">www.geraldboggs.com</a></p>
Julius Saccucci Posted March 2, 2014 Posted March 2, 2014 Awesome tutorial Alan! One question for you, have you ever had a weld fail from use?
Alan Longmire Posted March 2, 2014 Author Posted March 2, 2014 Thanks! No, if the weld is going to fail it does it when drifting or when fitting the handle. I also test them by inserting the drift and whacking the side of the anvil before HT. If it survives that it will survive most abuse. I have never had one returned, so that test seems pretty conclusive.
Eddie Eggleston Posted March 2, 2014 Posted March 2, 2014 wow those are incredible Mr Alan. your a true craftsman.
JenniferP Posted November 2, 2019 Posted November 2, 2019 Great thread and tutorial Alan. Nicely done. 1 Facebook: https://www.facebook.com/jlpsinc Facebook photos: https://www.facebook.com/pg/jlpsinc/photos Youtube channel: https://www.youtube.com/channel/UC8WRbArfgi8kSaDek7kh_1Q?view_as=subscriber Google Photo's: https://goo.gl/photos/jNR8MRdz5TSU3Nm47
Larry Pyne Posted November 3, 2020 Posted November 3, 2020 Wow. Just WOW! I'm excited to start a project like this sometime soon. I've never forge welded that this tutorial was great! Thank you!
KenH Posted October 9, 2021 Posted October 9, 2021 Alan, each time I read one of your WIPs, I'm even more impressed. WoW - what a job you did on this project. We all really appreciate not only your skills, but the time 'n effort you take to share with us mere mortals so we can learn. WOW - this is impressive work, the tomahawk but the WIP also. Ken H> 1
Aaron Gouge Posted August 27, 2022 Posted August 27, 2022 I know this is a very old thread but I’ve had it saved for a while looking towards the time when I would make a wrapped hawk. So my one big question at this point Alan is I see no real mention of sanding or cleaning the metal before forge welding. Looking at the pictures and just common sense tells me you’ve had this hot enough that you have scale buildup on the metal. Everything I know about forge welding says clean clean clean metal. In my situation I didn’t have any quarter inch mild steel bar so I forged down some three eights. Do I really need to grind this down to a flat clean surface again before attempting the forge weld? Aaron
Alan Longmire Posted August 27, 2022 Author Posted August 27, 2022 That depends on your confidence level and your forge atmosphere. It doesn't have to be flat, as long as there are no hollows to form pockets of trapped flux. If you use flux, that is. I know folks who don't, but you have to manage your forge atmosphere to keep a slightly reducing fire to prevent scale buildup. I work in coal for these, so it's fairly easy to keep it neutral to slightly reducing. If I'm using 1018/1020 or wrought iron, I typically don't remove the scale. If I'm forced to use A36, I do knock it off right before wrapping, using a 36 grit cup stone on an angle grinder. I do this hot right out of the forge and sprinkle a little flux on the newly cleaned surface. Take no chances with A36. Don't use it at all if you can help it. I also use a mix of anhydrous borax and cast iron powder as flux. When you have the head wrapped and you're ready to start the weld, get it HOT. Remember mild and wrought need almost white heat to weld happily. When you get to the edge steel, weld at the heat it likes. 5160 is good for this. Stuff with higher carbon adds to the cracking risk if you get it too hot, and you don't want or need higher carbon for this application anyway. That said, I do use 1075, 1084, W-1, and sometimes old files. You just have to temper them way back.
Aaron Gouge Posted August 28, 2022 Posted August 28, 2022 Thanks Alan!! That was helpful! Have you ever used 80CRV2 for the bit? So this is how my day ended! I believe it was successful! I used 1.5” x .25 1018 that I forged down to size. I used 1080 for the bit. I somehow missed that you use 1.25 bar stock but that gives me more room to grind away imperfections!;-) I feel like the bit is sloped up on the top, not at a 90 from the eye. Check out the pic, I have the drift centered on a vertical line and the back of the eye even with a horizontal line. You can see where the top edge of the bit falls. The tear drop bit is new to me and maybe it’s just throwing off my eye? I think my cutting edge will end up about 2.5”. I had hoped for bigger but I am limited by the chamber in my forge.
Alan Longmire Posted August 28, 2022 Author Posted August 28, 2022 That looks good for a first attempt! If you're feeling brave you can correct the eye angle by drifting it some more. You'll want it a bit larger anyway if you use premade handles. If you do that, do it sideways with the blade clamped hard in the vise! And do it with the eye at full welding heat. Drifting to stretch the eye after welding is an excellent way to break the weld... I have never used 80CrV2 for anything. It should work fine for this application, though. 1
Aaron Gouge Posted August 28, 2022 Posted August 28, 2022 So like this? I than can tap the thinner part of the drift down to straighten the eye socket out. Then drift it more to reshape and enlarge?
Alan Longmire Posted August 28, 2022 Author Posted August 28, 2022 Exactly! Glad you could figure out what I was talking about. You don't even need to tap the end down, just drift a little to enlarge and it should straighten out. If it doesn't, then consider tapping the small end down. Or forge on the upper half of the eye with the drift in place. That will stretch it a bit without threatening the weld. I might actually recommend that, then drifting in the vise. 1
Aaron Gouge Posted September 3, 2022 Posted September 3, 2022 Thanks once again Alan! I got I stretched out and running 90* from the top of the bit. Here’s where it’s at so far!
Aaron Gouge Posted September 28, 2022 Posted September 28, 2022 So I need some more help on my Hawk! When I initially forged it and finished it you could see maybe a 3/16 line at the beginning of the blade where the forge weld didn’t take. I wasn’t too concerned at the time. It seemed like a small spot and within tolerances of my first welded hatchet. I put a handle to it and started using it. The crack grew may be 1/8” in length and opens just a tuch with use. I hung the hawk on the post that supports the front porch of my Forge. It hung there for about a week. When I took it down this is what I found! I threw it a little more and the crack widened more but didn’t grow in length. So I do appreciate all the tips or tricks for re welding this! Aaron
Alan Longmire Posted September 28, 2022 Author Posted September 28, 2022 That's why I don't throw them. Seriously though, that shows the weld didn't take at the eye. At this point I'd call that one a learning experience and make a new one, but you can certainly try to re-weld it. Use a lot of flux and work from the blade back towards the eye if you choose to try. If all you're wanting to do is throw it, you can also just clamp it tight and arc weld the seams top and bottom, then grind flush. Assuming you have access to a welder. Stick, MIG, TIG, or oxy-acetylene all work fine for that purpose.
Aaron Gouge Posted September 28, 2022 Posted September 28, 2022 Thanks Allan! Should I be concerned of possible forge scale or contaminants on the metal? If so is there something I could soak it in to help clean the surface before trying to re forge? Throwing is rough on it! But that’s part of the fun of a tomahawk! That said I’m sure it would’ve still suffer the same fate if I was just using it to chop with. If my welding was good it shouldn’t be an issue though! I do have access to stick welder. I think I will stick it back in the Forge to try re forge welding. Then I may also lay bead of weld in the point of the eye just for added insurance. Thanks Aaron
Alan Longmire Posted September 28, 2022 Author Posted September 28, 2022 It should be fairly clean, or least clean enough that flux will take care of any issues. Use as reducing a fire as you can manage to minimize scale, and don't hit too hard and thin it out too much. That's what usually happens to me if I try to save one that didn't stick the first time. I give them three tries during the initial forging, and one rescue attempt if it splits while drifting. Beyond that, it goes on the pile under the forge. I think for your purposes the added spot weld is a good thing. Good luck!
Aaron Gouge Posted October 6, 2022 Posted October 6, 2022 (edited) Well I believe I was 90% successful in re forge welding. But I still layed a bead of weld in the point of the eye with the stick welder. Time will tell. Aaron Edited October 6, 2022 by Aaron Gouge 1
