Warg tooth Seax WIP
Luke Shearer
Beneath the beams of the super moon a few nights ago, my Muse stirred within me to forge a seax. The idea was to make a mid-sized knife, mabey 14" long in the blade, composed of many strands, forged in the old way, with the teeth of wolves, and eddies of swirling life-blood.
I was reminded of Proffessor Tolkien's borrowed word "Warg" meaning wolf, in Old Norse. This was not the common word for "wolf" (ulfr), but a special word, with demonic connotations, often reserved for outlaws.
So My friend, Ryan Stevens and I forged out some bars, patterned them, and have begun to weld them together....
Twisting up a core
billets...
To forge in the teeth, I mark out every centimeter with an angle grinder, and then we use a special fullering tool to forge them in. (Turns out the tool was too sharp and we sliced through a few of the layers instead of compressing them...)
Grrrr!
Meticulously fitting up the teeth. Its easy to make flaws if this is not done correctly.
We decided to weld it up in two separate billets initially, one with the twists framed by wrought iron, and one for the wolf tooth, so we could keep an eye on it and give it special treatment if needed.
“Then something Tookish woke up inside him, and he wished to go and see the great mountains, and hear the pine-trees and the waterfalls, and explore the caves, and wear a sword instead of a walking-stick.”
  • Replies 83
  • Created
  • Last Reply
Top Posters In This Topic
One trick I have learned to get flux into the joint earlier is to heat the
piece to around 700 degrees and spoon borax saturated water onto it. I
don't know if it really helps, but I like to think it does.
Wire brushing...
Welding...
Warg teeth emerge....
Scrubbed mostly clean...
Next step is to stick these two together and forge into a blade.
WAY awesome, Luke.
Best of luck going forward.
Mark Green
(cptn. Mal)
yaaahhh awesome love the teeth!!
but dude shorts and forge welding .... ouch
The blacksmith and the artist reflect it in their art.
They forge their creativity,closer to the heart.
I'm just glad to see he has shoes on for once.... ;-)
Edited by Andrew C.
He that will a good edge win must forge thick, and grind thin.
-Colin Sampson
Ha, I burned my foot pretty bad stepping on an RR spike head a couple days ago...hence the feet coverings. No way I could wear jeans though... I'd melt.
That's just too cool luke
Dion Grethen
D. Grethen Hand Forged Iron
https://facebook.com/DGrethenHandForgedIron
"In fire iron is born, by fire it is tamed"
"Never touch the blacksmith's hammer . . . or his daughter."
Well seems youve moved up to your big boy britches with this project ! even tho you forgot to put em on! HOT BORAX SQUIRTS OUCH!! Very cool design cant wait to see the done deal!
www.hoyfamily.net
Isa 54:16 Behold, I have created the smith that bloweth the coals in the fire, and that bringeth forth an instrument for his work; and I have created the waster to destroy.Lu 22:36 Then said he unto them, But now, he that hath a purse, let him take it, and likewise his scrip: and he that hath no sword, let him sell his garment, and buy one. Mr 8:36 For what shall it profit a man, if he shall gain the whole world, and lose his own soul?
nice one, Luke. Lot of work so far. wish the best, looking forward to seeing this develop.
kc
Great start Luke. When I was starting out I use to play with super saturated borax as a method of getting flux on early, but I soon gave up the effort. If you are looking to get flux melted sooner you can add some Boric Acid to your Borax, but even easier than that is to simply flux your work quickly and back into the forge. I have also found it beneficial to not place your steel back in the forge with any unmelted borax, the amount that melts on the surface is all you need and it will save the borax from bubbling off your steel and collecting on the bottom of the forge.
I also like to keep all my bars the same length for welding, and then cutting the tip back, but you seem to have got good welds so power to you.
Keep up the good work.
  • 4 weeks later...
Bit of an update:
there's more on my Facebook page
https://www.facebook.com/media/set/?set=a.676799389012306.1073741830.674361129256132&type=1
