Daniel J. Luevano 4 Posted August 2, 2013 Share Posted August 2, 2013 I've got some good maple wood I would like stabalized, problem is, I have no idea how haha. Any help would be greatly appreciated Link to post Share on other sites
Scott Wheeler 0 Posted August 2, 2013 Share Posted August 2, 2013 There is a hundred different ways stabilize, pentacryl is a product Iuse on on wet or dry wood. You can get it any woodworking store or do ainternet search. Link to post Share on other sites
Theodore An. 20 Posted August 2, 2013 Share Posted August 2, 2013 I get the idea for my system from this video so i find this unit and i use this old freezer motor as a vacuum pump with a big 5 lt jar... I use polyurethane base oil because here in Greece i can't find special tung oils.. I have very good results some wild olive wood scales and my system at work Link to post Share on other sites
Doug Lester 293 Posted August 2, 2013 Share Posted August 2, 2013 Unless I was going to stabilize wood on a regular basis, it's best just to send it out. If you really want to do it yourself, there's a product known as Cactus Juice that's rather new on the market. Do an online search for it and you may find the seller who carries it and the pressure vessels and air pumps that you will need. Doug Link to post Share on other sites
Dave Armour 38 Posted August 2, 2013 Share Posted August 2, 2013 I never tried to do it myself, but I've had wood stabilized by Woodlab and was thrilled with it. Link to post Share on other sites
Scott Wheeler 0 Posted August 2, 2013 Share Posted August 2, 2013 Cactus Juice does work but you will need a vacuum chamber and a pump, if your going to do multiple pieces it would be worth the investment. Pentacryl needs no special equipment and works similar to Cactus Juice, it does takes a little longer to work since your just soaking the pieces. I'm not promoting it, just a satisfied customer, I have done multiple pieces of spalted Maple with great results. Link to post Share on other sites
