Specifications
United States: AISI 6150, AMS 6450, AMS 7301, ASTM A322 (6150), ASTM A519 (6150), ASTM A829, SAE J1397 (6150) , SAE J412 (6150), AMS 6448, AMS 6455, ASTM A29 (6150), ASTM A331 (6150), ASTM A752 (6150), MIL. S-8503, SAE J404 (6150), UNSG 61500
International: DIN 50CrV4, EN 50CrV4,
Chemistry
Crucible: Carbon 0.50, Manganese 0.80, Silicon 0.30, Chromium 1.00, Vanadium 0.15
Metal Ravne: Carbon 0.51, Manganese 0.90, Silicon max. 0.40, Chromium 1.09, Vanadium 0.18,
Metal Suppliers Online: Carbon 0.48-0.53, Manganese 0.7-0.9, Silicon 0.15-0.35, Chromium 0.8-0.9, Vanadium 0.15 min.
Principle Design Features
6150 is a fine grained, highly abrasion resistant carbon-chromium alloy steel. Very good shock resistance and toughness are also key properties of this alloy in the heat treated condition.
Forging Range
Forge between 2200 and 1600 degrees Fahrenheit. Note that welding temperature is around 2300 degrees Fahrenheit. You pretty much want to be forging this stuff at a welding heat and be sure to stop hitting it before it gets too cold. The first heat you take will require a definite soak time, from 10-30 minutes, before you start forging.
Critical
1360-1380 degrees Fahrenheit
Normalize
Cycle 1 - Make it good and hot, around 2200 degrees Fahrenheit, soak 10-30 minutes, air cool.
Cycle 2 - Get it to 1600 degrees Fahrenheit, soak 10-30 minutes, air cool.
Cycle 3 - Heat to 1550 degrees Fahrenheit, soak10-30 minutes, air cool.
Hardening
Preheat to 1200-1250 degrees Fahrenheit and equalize.
Heat to 1500-1650 degrees Fahrenheit, soak 10-30 minutes.
Quench
Oil quench to hand warm (150 degrees Fahrenheit). Temper Immediately.
Temper
2 hours minimum soak at temperature. Cross sections thicker than 2 inches require 1 hour per inch of thickness, round any fractions up. Knives from 6150 will get tempered cooler than you are used to, Here is a clue from an old post (Tempering 6150) "I heat treated a forged blade made of 6150, quenched it in oil and tempered twice at 375 for an hour each time. It Rc tested at 58."
Do your own research! Find out, for yourself, all of the information I left out! Here are links to some of the sources used for the information herein:
Crucible Selector - AISI 6150 Alloy Steel
Metal Ravne Steel Selector - Steel VCV150 (Mat. No. 1.8159, DIN 50CrV4, AISI 6145/6150)
Metal Suppliers Online - 6150 Ally Steel
Hmm, this seems interesting. When is this steel useful? It seems like it is more work than 5160 to work with, but doesn't provide hugely increased performance, if at all.
"I have surprised myself with what I can make with simple tools when a definite need arose. I don't think a man knows what he actually can do until he is challenged."- Dick Proennke
This steel is useful when you need an extremely tough blade. The 6150 will take even more abuse than 5160 and just shrug it off. I've been having trouble finding any useful comparison between 6150, 5160 and 9260 in the hardened condition. Of the 3 alloys, 6150 is reputed to be the toughest.
The other point is that I (and possibly others) work with this alloy occaisonally and it is useful to have this information gathered in one spot here. Yes, the 6150 is more effort to work with than 5160 but, not too terribly different than other alloys that require a soak such as W2 or 1095.
~Bruce~
Hmm, I was thinking that but personally I have never seen a need for a tougher blade than 5160 will provide. It seems like it would have more of a place in a hammer head or anvil then in a blade.
