First Knife! Mid-sized clip point hunter! Trackrock Hammer-In 2013 WIP(?)
Caden_Vekk
I've been a stalker of knife making forums for years now, I've always been meaning to make a small forge and just start beating some metal 'til I can't feel my hands anymore. I still haven't made a forge, but I did go to Trackrock Hammer-In in the North Georgia mountains this past weekend and I've FINALLY gotten back into forging. I did some ornamental blacksmithing when I was 14-15 and have always been into the whole idea behind taking some bit of metal and making something useful out of it.
I drove up to the mountains and not an hour into me being there a guy by the name of John, I believe, handed me a 1.5x6x 1/8th(?)in piece of 1095.
1231253_10151879890926506_572315768_n.jp
He just let me swing away and would answer any questions he could if I had any.
1377071_10151879891066506_2146568401_n.j
Not a bad forging job for my first time forging in about 10yrs.
A guy helped me through the heat treating since it was 1095, as it stands, It's been through quenching and a stabalization cycle, I still need to do a tempering cycle and see what comes of it. If that all works out I should be golden to start on the draw filing.
Here's what it looks like as it stands
1383719_10151884563671506_883516859_n.jp
The stats are as follows:
4 5/8 Long
1 5/8 Wide
2 1/4 Clip
4mm spine
I think it may be too hard to draw file when it is tempered. They are for me, anyway. It may file a little, at most. will probably ruin your file, though.
looks good so far.
Welcome. Thanks for posting. Looking forward to the progress.
kc
Yeah, as a general rule you want to have every step completed that involves cutting steel with steel (drilling and filing) finished before you harden the blade. You are likely limited now to sandpaper and stones for shaping and finishing. Degrease the blade and let it soak in vinegar overnight, this will loosen up the scale.
I like the shape, but that tang looks a bit skinny... here's how mine are usually shaped.
George Ezell, bladesmith
Buffon
view some of my work
RelicForge on facebook
Those are some gorgeous blades GEzell. The tang is so skinny because I got a bit slap-happy with the guillotine. It's not often I feel French.
I have diamond stones, Japanese waterstone, and I forged the bevels down to 1mm (or so), so it'll be slow going with the filing, but as it's my first knife...I'm totally ok with slow.
Any way, progress is I bought some bloodwood (2x2x12in) and and lightly figured walnut (3x2.5x9.5in). I'm going to a buddy's house to use the jointer, planer, and table saw to get the roughs out of the walnut to see just how much figure I have one the walnut before choosing which wood to use.
OK, say I was going to start with a squared up piece of would for the handle, I have 4-5in in length, what would the other two dimensions be on a typical knife of this size? Another way to ask would be what dimensions of starting lumber would be too big for a knife handle?
Well, it depends...:)
One to one and a half inches, by three quarters, by around five inches long, works pretty good for a straight handle, wider is useful especially if you want some curve to the handle... I like a somewhat flattish handle cross-section, perhaps from carrying a spyderco for 15 years, a flattened egg-shape cross-section is my personal favorite. Take some time to look at various handle shapes that others have used, even make a mock-up handle out of softwood to see how it feels to you. Drill and fit the tang in the wood block, then rasp away until it fits your hand just right, then sand and finish. Guards, guard plates, and butt-caps are optional and will require some pre-planning...
Buffon
Some progress pics
Did some draw filing today. Defintely should have done this before HT...1095 is tough, BUT it's coming along and is fairly close to ready to be sharp. I also bought an old No. 5 jack plane and went to town for a bit to get the initial surface down, no long shavings yet, but I just put in a new iron that is shavey sharp. So tomorrow, we'll see if I can't dial it in.
1385308_10151905705466506_303490692_n.jp
1381462_10151905705541506_1420304848_n.j
1209391_10151905705616506_1773966533_n.j
946034_10151905939766506_1033509114_n.jp
1391573_10151905708331506_589470945_n.jp
  • 6 months later...
WELL! After too long not working on the knife I've gotten a good bit done. My hiatus has been setting up a little smithy and getting my smithing techniques down before screwing around with other projects for fun.
Here are a few pics of the progress,.
10268679_10152366328771506_2127575287601
10175014_10152366328846506_3887750456484
1800491_10152366337171506_57151917827734
10170919_10152366337266506_7299682618971
And the copper finger guard was my original idea....but it's just not doing well and doesn't look how I'm wanting it to look. So I've cut a 2.25x1x0.5in bit of mild steel and I will be doing some drilling and stock removal on that for a beefier guard, I might use the copper as a spacer between the mild steel and the curly walnut as well as the butt plate for when I pein the tang.
I slathered some boiled linseed oil/turpentine mix on the handle to see the grain a bit. Once I get crackin on the finger guard I'll have to reshape the handle to match, but oh well.
I want to see this at the Spring Hammer-in.
Anyone who has never made a mistake has never tried anything new. - Albert Einstien
The most recent was March. The next one will be mid august. I think they post the dates on the georgia knifemaker's guild website, but they aren't very good at updating it.
I don't know where Carl's shop is, or where you are.
Does anyone have any suggestions for sealing walnut? Is it necessary?
It is necessary, walnut is pretty porous. I use boiled linseed oil followed by car wax once the oil has cured (about a month). You could use any kind of sanding sealer followed by oil, or just use Tru-Oil and rub it back if you don't want a gloss finish. Or shellac, sand level, then oil or wax. Lots of ways to do it.
Sounds great. I've got my trusty BLO/Turpentine/Beeswax "Axe Wax", do you think that'd do as well?
Tru-OIl sounds like a good way to go as well. The local Home-Deepa got a stash hidden away. And I really like the way it looks on the walnut gunstocks
Nice looking handle! It deserves a good finish! (I'd go with the tru-oil)
To become old and wise... You first have to survive being young and foolish! ;) Ikisu.blogsot.com. Email; milesikisu@gmail.com mobile: +27784653651
