Guest guest T
pen knife wip
Guest guest T
I started making a small pen knife from a 3/16 inch thick spring. I got it forged, filed, quenched, and tempered but it snapped when I bent it. today I am going to make another one with more care in quenching and tempering. it was tempered at 450 for 1 hour.
keep on trying , you'll learn a new thing every time you fail. So it really isnt a failure just a delayed accomplishment.
Wasn´t it T.A. Edison who said to the journalist interviewing him about the light-bulb: No, I didn´t fail. I simply invented 10.000 ways how not to make a light-bulb! :)
Keep at it :) !
Guest guest T
thanks for the support, I just finished forging the new blade and am going to start filing it.1291804_533259333410558_1593632897_o.jpg
Guest guest T
I got the overall shape filed now I am going to grind the bevels. the flat edge will be the blade1380064_533265033409988_740660429_n.jpg
That grain is pretty big, indicating it was too hot somewhere along the line. On the next one, normalize three times (that means bring it just to critical and allow to cool in still air) before you harden. No amount of tempering can save overlarge grain.
If you're having trouble judging critical temperature, look at my post about 1084 in the Heat Treating by Alloy subforum, http://www.bladesmithsforum.com/index.php?showtopic=26523 to see what I mean. Using a pipe is very helpful for small parts in an open fire.
Good luck on the next one!
your grain size looks pretty big, and you don't mention normalising (heating to critical and letting air cool) prior to quenching - you want to do this 3 times to get the grain size to where you want it before heating and quenchin, or else the blade will be brittle.
edit - or what Alan said...
Edited by jake cleland
Guest guest T
I normalized it only once and I think that I quenched it while it was too hot. I finished filing the new blade and now for normalizing, hopefully I will be able to evely heat it better now that I cleaned all of the ash out of my forge. I will try normalizing 3 times and heat treating the blade multiple times.
Guest guest T
the second blade is in the oven now. here is a close up of the grain structure of the first blade.1278015_533293996740425_59799931_o.jpg
i'd leave off the multiple quenches - it may help some steels, it will definitely hurt others, and it increases your chances of warping/cracking. heat treatment is not as mysterious as it's often made out to be, just a series of steps that each serve a purpose. lern to see decalescence and recalescence and use a magnet to check that you're in the ballpark...
Guest guest T
unfortunatly some of the edge was lost to scale when I was normalizing. it is going to take a while to sand out.
Guest guest T
heat treating finished and sharpening went well. now I am gluing the handle on.
Guest guest T
I just finished carving the handle and so far I am pleased with the results. thank you all for helping, you all inspire me to keep trying even after I make mistakes.
this knife is definetly more flexible than the last though I am reluctant to test it too much. I think this project is done until I can get some leather to start making sheaths.
edit: I forgot to mention that the handle was entirely carved by my last knife: http://www.bladesmithsforum.com/index.php?showtopic=27569
Edited by Tre Asay
